7.3 fan on a 6.0???wtf? - Page 26 - Ford Powerstroke Diesel Forum
 60Likes
post #251 of 307 Old 11-07-2014, 05:58 AM
FJuanfiddy mod
Dave's Avatar
Quoted: 12 Post(s)
I know how you feel about a radiator change in a parking lot.
Freakin blows. Especially if you dont have the trans line quick disconnect tool with you
Email:
2006 F250 ECSB Lariat 4x4
Edge Insight CTS
Coolant filter
Dave is offline
post #252 of 307 Old 11-07-2014, 06:10 AM
Not a fun job. Hardest part was finding water pump pulley. I was about 70 miles from the nearest town of any size. I had to change radiator, pulleys, water pump, radiator hose, and belt. It was a long couple of nights. Oh, I had to change fan blade also.
groovelow is offline
post #253 of 307 Old 11-07-2014, 06:16 AM
FJuanfiddy mod
Dave's Avatar
Quoted: 12 Post(s)
It took me longer to get the quick disconnect than anything. The radiator swap took 30 minutes once I had that
Email:
Edge Insight CTS
Coolant filter
Dave is offline
post #254 of 307 Old 11-07-2014, 06:25 AM
I rebuilt the top end about 50k ago and put in a new radiator, condenser, and all the hoses. So it wasn't to bad. I carry all the tools with me to work on the truck. I'm on the road year around and average about 60k a year. Have to be ready for anything.
post #255 of 307 Old 05-20-2015, 01:20 AM
j.flow's Avatar
Quoted: 4235 Post(s)
I've had my 7.3 clutch on since last summer when my fan ate it's own guts. Works great, but idk what others say about not setting the cel. It set mine immidiately. Not that I care, but in this commi state that will make me fail emissions. It's not until august but I'd like to address it sooner than later.
64.7mm stg2 powermax
175/30 holders diesel injectors
WPE ported intake manifold
Airdog 165 4G
Beans sump
O-ringed UCF heads
H-11 headstuds
4" turbo back exhaust
Mishimoto intercooler/radiator/charge pipes
BPD 58v ficm
BPD HD cooler with filter relocation
7.3 fan clutch
Amsoil bypass
Leece-Neville 230a alternator
22x14 american force burnout
warren diesel trans
Yukon 4.56s and Truetrac
j.flow is offline
post #256 of 307 Old 06-01-2015, 09:53 AM
What temp does the 97 fan clutch kick in at?
Baja1972 is offline
post #257 of 307 Old 01-06-2016, 11:12 AM
Quoted: 3 Post(s)
Smile
j.mo, did you have any issues with smog? I am assuming you are in CA as well? I was about to order this adapter and new fan clutch with the rest of my BPD order but was worried it would throw a code. I spoke to John over at BPD and he informed me it is possible it will throw a code but he was not sure what years/model it would do so. I have an 05 Excursion that is about to be bulletproofed with all the BPD components and I would love this fan upgrade.
Anyone in CA with this upgrade care to chime in? Thanks in advance.
sw20td06 is offline
post #258 of 307 Old 01-15-2016, 10:46 AM
FJuanfiddy mod
Dave's Avatar
Quoted: 12 Post(s)
It will throw a min of one code. for fan signal not detected
Email:
Edge Insight CTS
Coolant filter
Dave is offline
post #259 of 307 Old 01-26-2016, 12:18 PM
kbliss05's Avatar
Quoted: 4 Post(s)
Garage
i was just curious a lot of you guys have the bpd oil cooler kit i was looking on there site but they have quite a few kits whats the best kit to run? also having stock oil cooler would i benefit from this fan?
kbliss05 is offline
post #260 of 307 Old 01-26-2016, 12:46 PM
Master_Chase's Avatar
Quoted: 520 Post(s)
For their air to oil cooling kits, I think the best is the HD option with the cold weather bypass (what I have) and it is overkill for me. I choose the HD option because I didn't ever have to worry about my oil temp in traffic when it's 100F+ out. The downside I have now is that it take my oil a lot longer to heat up when it's cold out.
The Fan clutch will benefit a 100% stock truck because it works off temperature and not some overly complicated computer program.
EDIT: and the clutch is on my long to-do list.
E̶a̶r̶l̶y̶ ̶2̶0̶0̶3̶ ̶6̶.̶0̶ ̶E̶x̶c̶u̶r̶s̶i̶o̶n̶ ̶f̶u̶l̶l̶y̶ ̶b̶u̶l̶l̶e̶t̶p̶r̶o̶o̶f̶e̶d̶,̶ ̶1̶5̶5̶/̶3̶0̶ ̶i̶n̶j̶e̶c̶t̶o̶r̶s̶,̶ ̶K̶C̶ ̶S̶t̶a̶g̶e̶ ̶2̶,̶ ̶a̶n̶d̶ ̶a̶ ̶l̶o̶t̶ ̶o̶f̶ ̶o̶t̶h̶e̶r̶ ̶s̶t̶u̶f̶f̶.̶ Cummins swap in progress. Thanks to everyone on the forum I have learned a lot.
The EGR does to your engine what smoking does to your lungs.
Remember you can always improve on a design until the EPA gets involved.
Master_Chase is offline
