Peixinho's 700hp streetable, towable, DD build thread - Page 64 - Ford Powerstroke Diesel Forum
 247Likes
post #631 of 725 Old 07-01-2014, 07:29 AM Thread Starter
peixinho's Avatar
Quoted: 346 Post(s)
Wow!!! What a long weekend/past couple of months.
I got my exhaust leaks taken care of. There were some issues with my y-pipes so Kevin sent me out a new set. I got it all back together only to find out I had a huge high pressure oil leak.
Well then I got my high pressure oil leak figured out. My hard line for my twin pump was leaking where it hooks into the back of the hpop test port. That is probably caused by me taking it on and off so many times over the last few months when pulling the motor to do head gaskets. I asked Jess Warren for a new one and he stepped up and overnighted me a new one and paid extra for it to be delivered Saturday morning. I got that all hooked up and taken care of... only to find out my reg return line was leaking.
I dove back in and figured it was a fitting... NOPE... the passenger side line itself was leaking near the y-pipe bellows where it crosses over the top of the motor. I am not sure if it melted/failed/burst... but the metal braid is fine but it leaks really bad and comes out in about a 3 inch section whenever the pressure was on. I wonder if this was what caused my fire last month and the leak finally got big enough for me to notice... or... maybe the fire melted the line??? The world may never know... LOL...
I finally got it all put back together and everything tightened up last night and the truck drives awesome. That y-pipe leak was robbing a ton of power. It is hard for me to test the truck on the street because I have major traction issues. Anytime I try to lay into it I just spin the tires and get major wheel hop. Time to start looking into traction bars and a good LSD in the back. The stock LSD is just not cutting it.
Next track night is Fri 7/11. I am going to drive the heck out of the truck till then and plan on going to the event. Also I am going to try to set up some dyno time over the next week to get a baseline for the new Stage X turbo testing. Wish me luck!
ODAWG714 likes this.
KC Turbos
Warren Diesel Dealer
My Current Build Thread
Current Setup 190/30 and KC 64mm Stage 2 turbo
peixinho is offline
post #632 of 725 Old 07-01-2014, 07:37 AM
Bump To Pass!!
toren302's Avatar
Quoted: 2586 Post(s)
You can re-build the stock LS to hold better Charlie. It wont be as good as say a true-trac or full locker but definitely better then the factory build. I need to service the rear diff in mine and think I am just going to pull it and re-build it then. I am also debating on just getting a true-trac at this point. Ran one if my f150 on 38's and it was awesome. Plus in the true-trac there are no clutches to wear out.
peixinho likes this.
toren302 is offline
The Following User Says Thank You to toren302 For This Useful Post:
peixinho (07-01-2014)
post #633 of 725 Old 07-01-2014, 07:45 AM Thread Starter
peixinho's Avatar
Quoted: 346 Post(s)
Thanks... I have thought about that. I know a ford tech that was telling me something about sticking extra clutches in there. He said it will really help out the clutches to stick harder... he said it might act like a locker for the first 25 miles or so but then it will be perfect. I was thinking about trying that.
KC Turbos
peixinho is offline
post #634 of 725 Old 07-01-2014, 08:15 AM
Bump To Pass!!
toren302's Avatar
Yep that's the trick I learned from the guy I bought this shop from. He was a ford Senior Master Diesel Tech for as long as they had the program until he quit. You can also not put in the full 8oz amount of friction modifier. Start with like 2oz and see how you like it. Remember that the less you use the harder the clutches will bite. It will act like a locker and may even chatter on slow turns. If too much chatter or you don't like the feel add a little more modifier. If you use the Ford stuff try not to spill it. It STINKS to high heaven and will stain anything it touches. Also the smell doesn't come out easy. Don't step in some that was spilled and then get into the vehicle. We had a kid that did that to a customer car. 3X it went to a detail shop for the carpets to be cleaned and the smell was still slightly there.
toren302 is offline
post #635 of 725 Old 07-01-2014, 02:22 PM
6 L chevy eater's Avatar
[QUOTE=peixinho;
Next track night is Fri 7/11. I am going to drive the heck out of the truck till then and plan on going to the event. Also I am going to try to set up some dyno time over the next week to get a baseline for the new Stage X turbo testing. Wish me luck![/QUOTE]
I'll be waiting.....
Chatham036 likes this.
2004 F250 ccsb
Skint Back Motorsports
Warren-HYBRIDS-- S400
FULL Billet Twisted Diesel Built Tranny
[email protected] on fuel dammit
6 L chevy eater is offline
post #636 of 725 Old 07-02-2014, 08:39 AM Thread Starter
peixinho's Avatar
Quoted: 346 Post(s)
I took the truck on a 400 mile road trip yesterday and it did AWESOME!!! I love finally having my truck back... that 7.3 dog that I was driving was just not cutting it.
I still have one small boost leak but I am trying to fix that... but everything else seems to be doing awesome.
I was talking with Charlie 6 L Chevy eater... and the truck might be seeing some nitrous in the next few weeks. We are working out the details.
KC Turbos
peixinho is offline
post #637 of 725 Old 07-02-2014, 10:42 AM
snafu!'s Avatar
Quoted: 2 Post(s)
Out of curiosity, where were all your boost leaks?
Gonna put the stock bottom end to the test with NOS, excited to see the results.
Cameron
2006 F250 Lariat CCSB
Comp Turbo 64/88 compounds
Warren 285/100
ODAWG ported intake
R&R rods, mahle pistons, stage 2 colt cam
Built Trans
Water/Meth
snafu! is offline
post #638 of 725 Old 07-02-2014, 09:41 PM Thread Starter
peixinho's Avatar
Quoted: 346 Post(s)
I had a bunch of little leaks... but they all added up. My diesel site pressure tester would drop for 20psi to 0 psi in less than 10 seconds... now it will hold for about 45 seconds.
What is also weird is some of the leaks did not even show up until I pressurized the system above 15-20 psi.
Tiny crack in MAP sensor hose
A couple of my boots not clamped tight enough
boost gauge hose leaking at t-connection
Pin hole in my hot side cac pipe
That scares the heck out of me... I really don't wanna tear out the motor again. I just want to enjoy driving it for a little while.
KC Turbos
peixinho is offline
post #639 of 725 Old 07-08-2014, 12:39 PM Thread Starter
peixinho's Avatar
Quoted: 346 Post(s)
Well I have been messing around with tunes all week and learning a lot about tuning. I even got the SCT software and tried to write my own tunes, which is WAY HARDER than I had imagined. It is very interesting to see how ebp, boost, icp, and pw all correlate together.
My setup is a little unique and is just not running the way it should. I believe a lot of it has to do with tuning. So... I am working with a couple of different tuners to try and get it figured out. I met Drew from Back Road Performance and he seemed very willing to go through the effort to try and tweak my tune to the way I like it. I am excited to try some of his tunes.
I also finally got around to installing my PHP FICM tuner. I am going to be messing around with the different levels and getting more data. So far I am VERY impressed. Super easy to install new FICM tunes and only takes about 3 minutes from start to finish (much quicker than SCT tuning)
Another issue is that I was dropping too much fuel pressure. On my low level street tune (about 1.7ms which should be around 175 - 190cc) it ran very clean and fuel pressure was in the 50s. On my race tune it runs super smokey and the power seems to die out. It would dip into the 20s... SO... Thanks to Charlie Keeter... I ordered up an a1000 with a dual filter/water seperator setup. It should be here today. I am just going to tie it into the stock 6.0 HFCM for right now and maybe delete the rest of the stock system/HFCM later.
If all goes well I will be hitting up the track this Friday Night
KC Turbos
peixinho is offline
post #640 of 725 Old 07-08-2014, 01:58 PM
Quoted: 176 Post(s)
I know the feeling... It still makes my stomach turn thinking about the sound of a busted bottom end
Chatham036 is offline
Tags
kaboom
