NUC Oil Bypass Filtration Kit Install. PICS! - Page 5 - Ford Powerstroke Diesel Forum
 8Likes
post #41 of 89 Old 03-21-2013, 04:50 AM
Why did you go through the trouble of putting on sensors to get the oil and coolant temp from there ?
Is there any benefit to doing it this way as opposed to just getting the values from the obd port where the edge gets its info from ?
I am assuming you have an edge, and not some other method of reading pid's.
Joe
Originally Posted by dfuzz78 View Post
Here you go. You need two all female 1/8 tee fittings. You need two 1/8 to 1/4 45 degree pressure fittings to attach the oil lines. Two 1/8 male to 1/8 male fittings to thread the tee fittings into the filter base. Then one male 1/8 valve for the oil sampling. The gauge temp sensor is a 1/8 male, so it just screws into the female tee fitting. With so many possibilities and fittings, this was the best plan I came up with to fit my needs.
4realestate is offline
post #42 of 89 Old 03-21-2013, 08:26 AM
Can't speak for dfuzz, but many of us like having individual gauges. Not only for the appearance, but I'd rather not rely on Fords sensors. (The Ford Oil Pressure gauge is an idiot light, tranny temp is a joke, useless.) And I prefer to keep my OBD2 port open and available without a cord plugged in.
rdezs is offline
post #43 of 89 Old 03-21-2013, 09:01 AM Thread Starter
Suck, Squish, Bang, Blow!
dfuzz78's Avatar
Quoted: 2 Post(s)
Joe
It wasn't any trouble...
I have a Scangauge II for monitoring the actual temps.
I did it to be sure that they are still functioning and flowing.
If they have temp, they are working, and I can tell right in the cab!
I can also sample the oil with the valve.
Denis "Lt. Sled"
2006 F-350 Crew Cab Long Bed Dark Shadow Gray
462hp / 927ft-lbs Corrected
ARP Head Studs, NUC Motorsports Oil Bypass, CFM+ Intake Elbow, Wicked Wheel 2
Bullet Proof Diesel FICM w/Atlas 40, SCT SF3 w/SPD by TSD! Grover Fire Truck Horns
Cab Light Mod, Blue Spring Mod, Zoodad Mod, High Idle Mod, Lost EGR Mod
dfuzz78 is offline
post #44 of 89 Old 03-21-2013, 06:44 PM
Because I don't have a scan gauge this may be a silly question, but, is it something that you plug into the obd port ?
If so, i guess you only plug it in periodically, since you want to keep the port available/open. As far as the oem sensors go, i understand that the gauges themselves may not respond quickly or are not very accurate, but when plugged into my edge it responds very quickly, and seems accurate.
post #45 of 89 Old 03-21-2013, 07:03 PM Thread Starter
dfuzz78's Avatar
Quoted: 2 Post(s)
Yes, the Scangauge II stays plugged into the obd port.
It reads the data in real time.
Denis "Lt. Sled"
dfuzz78 is offline
post #46 of 89 Old 03-22-2013, 08:14 AM
Your 6.0 doesn't come equipped with a real oil pressure gauge, therefore no device can be used to read it off the OBD2 port. The gauge on the dash is just an idiot light, the needle goes to the middle when you have 7 psi of pressure, at reads nothing when you have less than 7 psi. (At pressures just above that, you will have engine damage with no warning!)
Tranny temp is similar, but different. It will read in the middle within 3 minutes of driving, and won't register overheating until it's too late and the tranny is fried.
So...we have gauges.
rdezs is offline
post #47 of 89 Old 03-22-2013, 08:40 AM
I completely understand the gauge thing.
What I am trying to say is, my edge insight reads trans temp, oil press and temp and so on. If it is getting these values from sensors in the engine, then they must be correct, right ? I know the factory gauges suck, but the sensors they get info from are good, no ? Are the sensors you are using better ?
post #48 of 89 Old 03-22-2013, 10:38 AM
MrOneEyedBoh's Avatar
Quoted: 28 Post(s)
Feedback Score: 11 reviews
Im wondering the same thing...
MrOneEyedBoh is offline
post #49 of 89 Old 03-22-2013, 11:05 AM
spoonfedblue's Avatar
Even though the dash gauges are just idiot lights, the PCM still looks at the actual values from the trans temp, oil temp, oil pressure and coolant temp sensors. That's why the Edge displays those values. What rdezs is saying is that the factory gauges are not an accurate method of monitoring temps and pressures. HOWEVER, barring a sensor failure, using an Insight is a perfectly acceptable way to monitor those things, unless, like he said you wanted to keep the DLC open.
ASE Certified Master Tech A1-A9
L1 Advanced Level Specialist
yours
2006 F-250 SCSB 6.0 FX4 Lariat
285/70R17 Nitto Trail Grapplers, Upfitters w/ High Idle, 4" Turbo Back Straight Pipe, AFE 6" Polished Tip, Insight CTS w/ EGT, Blue Spring, IPR Gen 2, CAT ELC, DieselSite Coolant Filter, Cloud Rider Cold Front
spoonfedblue is offline
post #50 of 89 Old 03-22-2013, 11:24 AM
Turbos = Witchcraft
TooMuch03's Avatar
Feedback Score: 3 reviews
That is not the case for the oil pressure. The sending unit is just a pressure switch.
2003 F250 6.0
Originally Posted by Tuscany View Post
Compounds FTW!!!
TooMuch03 is offline
