NUC Oil Bypass Filtration Kit Install. PICS! - Page 4 - Ford Powerstroke Diesel Forum
 8Likes
post #31 of 89 Old 04-01-2012, 05:27 AM Thread Starter
Suck, Squish, Bang, Blow!
dfuzz78's Avatar
Quoted: 2 Post(s)
Originally Posted by onebadcoastie View Post
Got any pics of that, or any specific info on that particular mod??
Here you go. You need two all female 1/8 tee fittings. You need two 1/8 to 1/4 45 degree pressure fittings to attach the oil lines. Two 1/8 male to 1/8 male fittings to thread the tee fittings into the filter base. Then one male 1/8 valve for the oil sampling. The gauge temp sensor is a 1/8 male, so it just screws into the female tee fitting. With so many possibilities and fittings, this was the best plan I came up with to fit my needs.
Denis "Lt. Sled"
2006 F-350 Crew Cab Long Bed Dark Shadow Gray
462hp / 927ft-lbs Corrected
ARP Head Studs, NUC Motorsports Oil Bypass, CFM+ Intake Elbow, Wicked Wheel 2
Bullet Proof Diesel FICM w/Atlas 40, SCT SF3 w/SPD by TSD! Grover Fire Truck Horns
Cab Light Mod, Blue Spring Mod, Zoodad Mod, High Idle Mod, Lost EGR Mod
dfuzz78 is offline
post #32 of 89 Old 04-01-2012, 11:14 AM
onebadcoastie's Avatar
Quoted: 10 Post(s)
That's awesome man. Thanks again! I'm teetering between this and the BPD bulletproof kit. lol..
Shack
2016 F-350 CC Dually
2005 F250 CC FX4Ö.SOLD
onebadcoastie is offline
post #33 of 89 Old 04-02-2012, 07:44 AM Thread Starter
dfuzz78's Avatar
Quoted: 2 Post(s)
Dude, that's apples and oranges. But you know that now, judging by the other thread.
Denis "Lt. Sled"
dfuzz78 is offline
post #34 of 89 Old 04-02-2012, 07:56 AM
Quoted: 10 Post(s)
I'm going to get the BPD one...just because of the stuff folks are telling me. Rumor is there offer 10% for us military folk too...lol Guess I'll just max that credit card out...again...I don't have a wife to yell at me so it's ok I guess..
Shack
post #35 of 89 Old 04-10-2012, 12:02 PM
turbotibbo's Avatar
Installed my Oil Bypass Filtration Kit from www.nucmotorsports.com. Had to move the location of my Sinister Coolant Filter to the Oil Bypass Filter bracket that is bolted to the alternator. I also added fittings to the oil bypass kit so I have the ability to sample oil and monitor oil temperature. So for all those folks who have a coolant filter, it is possible to mount both in that location.
Note: Temp sensor wires will be connected tonight and be neatly loomed and protected. Also, the coolant filter hose resting on the bracket will be protected from wear somehow. Haven't figured it out yet...
looks great , did you do it your self and how long did it take ...
2006 ford f350 xlt cclb
blue spring mod
6.4 banjo bolts
gogo direct cluth solenoid
Insight cts with pyro
str8 pipe , fuel pressure gauge
air raid cold air
zoodad mod
high idle mod
sinister coolant filter kit ec-1 rated
58 volt ficm
powermax turbo , sinister y pipe
egr delete
sct x3 with running looney wild , spd early lock up
arp studs , updated stc fitting ,stand pipes,
dummy plugs , new oem injectors
turbotibbo is offline
post #36 of 89 Old 04-10-2012, 12:12 PM Thread Starter
dfuzz78's Avatar
Quoted: 2 Post(s)
Thanks, yes I did it myself. It took about an hour. I think I spent more time in the hardware store deciding how to do it and what fittings to use.
Denis "Lt. Sled"
dfuzz78 is offline
post #37 of 89 Old 04-14-2012, 09:04 AM
Paintingman's Avatar
Heres my kit this is the only photo i have though i got it at Diesel Oil bypass filtration & Coolant kits Ford Powerstroke 6.0 Chevy 6.6 Dodge 5.9 Parts Filters Aluminum oil filter caps Powerstroke Crankcase vent - Diesel 6.0 Oil bypass filtration systems Powerstroke 6.0 billet aluminum filter cap Cummi</a> </div> <!-- / message --> <!-- attachments --> <div style="padding:0px"> <fieldset class="fieldset"> <legend>Attached Thumbnails</legend> <div style="padding:3px"> <!-- BEGIN TEMPLATE: postbit_attachmentthumbnail --> <!-- 1 --> <a href="https://www.powerstroke.org/forum/attachments/6-0l-performance-parts-discussion/36769d1334419316-nuc-oil-bypass-filtration-kit-install-pics-397105_186263091477434_178808612222882_229502_1351619028_n.jpg" rel="Lightbox_3026115" id="attachment36769" target="_blank"><img class="photo thumbnail" src="/forum/images/Powerstroke_org_2015/misc/spacer.gif" data-original="attachment.php?s=65f590ce193e28d1d23fcc5676ea1ba8&attachmentid=36769&stc=1&thumb=1&d=1334419316" border="0" alt="Click image for larger version Name: 397105_186263091477434_178808612222882_229502_1351619028_n.jpg Views: 3394 Size: 19.6 KB ID: 36769" /></a>   <!-- END TEMPLATE: postbit_attachmentthumbnail --> </div> </fieldset> </div> <!-- / attachments --> <!-- BEGIN TEMPLATE: vbseo_likeshare --> <div class="text_wrapper vbseo_buttons" id="lkbtn_1.246552.3026115"> <div class="alt2 vbseo_liked" style="display:none"></div> </div> <!-- END TEMPLATE: vbseo_likeshare --> <!-- sig --> <div class="vs_sig"> <hr class="sig"> 04 F250 PSD Every day work truck<br /> 3000 Watt inverter/Jotto desk laptop and printer<br /> 180cc injectors 70hp+/powermax turbo<br /> Stage 1 fuel lines/58 volt FICM from swamps diesel<br /> ARP studs/black onix head gaskets<br /> ATS intercooler/CFM+/Airaid intake<br /> Fluidamper/200 Amp alternator<br /> SCT X3 innovative diesel<br /> 4" turbo back MRPB duals<br /> Mag-Hytec diff./trans covers </div> <!-- / sig --> </div> </div> </div> <!-- end text_wrapper --> <div class="text_wrapper postbit_legacy_wrapper postbit_legacy_wrapper_bottom"> <div class="alt2 picture main-column-picture status-icons" > <!-- BEGIN TEMPLATE: postbit_onlinestatus --> <span class="sprite inlineimg user_offline" title="Paintingman is offline">Paintingman is offline</span> <!-- END TEMPLATE: postbit_onlinestatus -->   </div> <div id="td_post_1162" class="main-column-text-wrapper buttons buttons-postings"> <div class="main-column-text"> <div class="right"><!-- controls --> <a href="https://www.powerstroke.org/forum/newreply.php?do=newreply&p=3026115" rel="nofollow"><span class="sprite button quote">Quote</span></a> <a href="https://www.powerstroke.org/forum/newreply.php?do=newreply&p=3026115" rel="nofollow" id="qr_3026115" onclick="return false"><span class="sprite button quickreply">Quick Reply</span></a> <!-- / controls --> </div> </div> </div> </div> <!-- end text_wrapper --> </section> <!-- BEGIN TEMPLATE: post_thanks_box --> <div id="post_thanks_box_3026115"></div> <!-- END TEMPLATE: post_thanks_box --> <!-- post 3026115 popup menu --> <!-- / post 3026115 popup menu --> <!-- AMS BELOW 37 POST --> <!-- END TEMPLATE: postbit_legacy --> </div> <!-- / post #3026115 --> <!-- END TEMPLATE: postbit_wrapper --><!-- BEGIN TEMPLATE: postbit_wrapper --> <!-- post #3026125 --> <div id="edit3026125" style="padding:0px 0px 0px 0px"> <!-- this is not the last post shown on the page --> <!-- BEGIN TEMPLATE: postbit_legacy --> <section id="post3026125" class="tborder vbseo_like_postbit user-post" itemscope itemtype="http://schema.org/Comment"> <div class="text_wrapper postbit_legacy_wrapper_thead thead" > <span class="post-count"><a href="https://www.powerstroke.org/forum/6-0l-performance-parts-discussion/246552-nuc-oil-bypass-filtration-kit-install-pics-4.html#post3026125" id="postcount3026125" name="38" title="permalink"><strong>post #38</strong> of 89</a> </span> <!-- status icon and date --> <a name="post3026125"><span class="sprite inlineimg post_old">Old</span></a> <span itemprop="dateCreated">04-14-2012, 09:15 AM</span> <!-- / status icon and date --> </div> <div class="text_wrapper postbit_legacy_wrapper"> <div class="alt2 picture main-column-picture"> <div id="postmenu_3026125" itemprop="contributor"> <a rel="nofollow" class="bigusername" href="https://www.powerstroke.org/forum/members/112378-strokin6l.html">strokin6L</a> </div> <div class="smallfont">Compression Ignition Addict</div> <div class="smallfont">  <br /><a rel="nofollow" href="https://www.powerstroke.org/forum/members/112378-strokin6l.html"><img class="photo avatar" src="/forum/images/Powerstroke_org_2015/misc/spacer.gif" data-original="customavatars/avatar112378_1.gif" width="100" height="75" alt="strokin6L's Avatar" border="0" /></a> </div> <div class="smallfont">  <br /> <div>Join Date: Apr 2011</div> <div>Location: springville NY</div> <div> Posts: 2,626 </div> <!-- BEGIN TEMPLATE: post_thanks_postbit_info --> <div>Thanks: 24</div> <div> Thanked 56 Times in 51 Posts </div> <!-- END TEMPLATE: post_thanks_postbit_info --><!-- BEGIN TEMPLATE: dbtech_usertag_postbit --> <div>Mentioned: 1 Post(s)</div> <div>Quoted: 4 Post(s)</div> <!-- END TEMPLATE: dbtech_usertag_postbit --> <!-- BEGIN TEMPLATE: dto_garage_postbit_userinfo --> <!-- END TEMPLATE: dto_garage_postbit_userinfo --><div class="smallfont">Feedback Score: 1 reviews</div> <div> </div> </div> </div> <div id="td_post_3026125" class="main-column-text-wrapper alt1"> <div class="main-column-text"> <!-- message --> <div id="post_message_3026125" itemprop="text"> Looks good. I've got the amsoil kit for now, but plan on getting the RCD relocation bypass kit in the future. Here's my amsoil setup. I mounted the filter on the passanger side frame rail. </div> <!-- / message --> <!-- BEGIN TEMPLATE: vbseo_likeshare --> <div class="text_wrapper vbseo_buttons" id="lkbtn_1.246552.3026125"> <div class="alt2 vbseo_liked" style="display:none"></div> </div> <!-- END TEMPLATE: vbseo_likeshare --> <!-- sig --> <div class="vs_sig"> <hr class="sig"> 2004 F-350 SC 4x4, XLT, 4" dual Magnaflow, AFE intake, No Limit piping, spearco intercooler, water injection, ARP studs, hypemax o-ringed heads, SCT tuned by Innovative Diesel, tuned FICM, Hellman's sump, FASS, Fuelab, regulated return, 190/75 injectors, KC/MTW 68 w/.72ar, suncoast trans w/billet input, edge insight CS with dakota digital gauges, amsoil by-pass, BD exhaust manifolds </div> <!-- / sig --> <!-- edit note --> <div class="smallfont"> <hr class="dividing-line" /> <em> Last edited by strokin6L; 11-09-2013 at <span class="time">08:22 AM</span>. </em> </div> <!-- / edit note --> </div> </div> </div> <!-- end text_wrapper --> <div class="text_wrapper postbit_legacy_wrapper postbit_legacy_wrapper_bottom"> <div class="alt2 picture main-column-picture status-icons" > <!-- BEGIN TEMPLATE: postbit_onlinestatus --> <span class="sprite inlineimg user_offline" title="strokin6L is offline">strokin6L is offline</span> <!-- END TEMPLATE: postbit_onlinestatus -->   </div> <div id="td_post_1162" class="main-column-text-wrapper buttons buttons-postings"> <div class="main-column-text"> <div class="right"><!-- controls --> <a href="https://www.powerstroke.org/forum/newreply.php?do=newreply&p=3026125" rel="nofollow"><span class="sprite button quote">Quote</span></a> <a href="https://www.powerstroke.org/forum/newreply.php?do=newreply&p=3026125" rel="nofollow" id="qr_3026125" onclick="return false"><span class="sprite button quickreply">Quick Reply</span></a> <!-- / controls --> </div> </div> </div> </div> <!-- end text_wrapper --> </section> <!-- BEGIN TEMPLATE: post_thanks_box --> <div id="post_thanks_box_3026125"></div> <!-- END TEMPLATE: post_thanks_box --> <!-- post 3026125 popup menu --> <!-- / post 3026125 popup menu --> <!-- AMS BELOW 38 POST --> <!-- END TEMPLATE: postbit_legacy --> </div> <!-- / post #3026125 --> <!-- END TEMPLATE: postbit_wrapper --><!-- BEGIN TEMPLATE: postbit_wrapper --> <!-- post #4164530 --> <div id="edit4164530" style="padding:0px 0px 0px 0px"> <!-- this is not the last post shown on the page --> <!-- BEGIN TEMPLATE: postbit_legacy --> <section id="post4164530" class="tborder vbseo_like_postbit user-post" itemscope itemtype="http://schema.org/Comment"> <div class="text_wrapper postbit_legacy_wrapper_thead thead" > <span class="post-count"><a href="https://www.powerstroke.org/forum/6-0l-performance-parts-discussion/246552-nuc-oil-bypass-filtration-kit-install-pics-4.html#post4164530" id="postcount4164530" name="39" title="permalink"><strong>post #39</strong> of 89</a> </span> <!-- status icon and date --> <a name="post4164530"><span class="sprite inlineimg post_old">Old</span></a> <span itemprop="dateCreated">02-23-2013, 08:54 AM</span> <!-- / status icon and date --> </div> <div class="text_wrapper postbit_legacy_wrapper"> <div class="alt2 picture main-column-picture"> <div id="postmenu_4164530" itemprop="contributor"> <a rel="nofollow" class="bigusername" href="https://www.powerstroke.org/forum/members/144729-rdezs.html">rdezs</a> </div> <div class="smallfont">Banned</div> <div class="smallfont">  <br /> <div>Join Date: Dec 2012</div> <div> Posts: 976 </div> <!-- BEGIN TEMPLATE: post_thanks_postbit_info --> <div>Thanks: 0</div> <div> Thanked 6 Times in 6 Posts </div> <!-- END TEMPLATE: post_thanks_postbit_info --><!-- BEGIN TEMPLATE: dbtech_usertag_postbit --> <div>Mentioned: 0 Post(s)</div> <div>Quoted: 0 Post(s)</div> <!-- END TEMPLATE: dbtech_usertag_postbit --> <!-- BEGIN TEMPLATE: dto_garage_postbit_userinfo --> <!-- END TEMPLATE: dto_garage_postbit_userinfo --><div class="smallfont">Feedback Score: 0 reviews</div> <div> </div> </div> </div> <div id="td_post_4164530" class="main-column-text-wrapper alt1"> <div class="main-column-text"> <!-- message --> <div id="post_message_4164530" itemprop="text"> Just stumbled across this thread.....I did a similar thing a couple weeks ago, but I wanted the two filter heads level with each other. I drilled and tapped the back side of the Sinister filter head. I love NUC's bracket, very, very sturdy.<br /> <br /> <img src="http://i1093.photobucket.com/albums/i424/rdezsofi/2006%20Ford%206%20Liter%20Powerstroke/2013-01-22170241_zps5a50f8da.jpg" border="0" alt="" onload="NcodeImageResizer.createOn(this);" /><br /> <br /> <img src="http://i1093.photobucket.com/albums/i424/rdezsofi/2006%20Ford%206%20Liter%20Powerstroke/2013-01-22170256_zps05f6db05.jpg" border="0" alt="" onload="NcodeImageResizer.createOn(this);" /><br /> <br /> This was right after install. I've since put some wire wrap around the oil lines so they don't scratch the Sinister filter head. </div> <!-- / message --> <!-- BEGIN TEMPLATE: vbseo_likeshare --> <div class="text_wrapper vbseo_buttons" id="lkbtn_1.246552.4164530"> <div class="alt2 vbseo_liked" style="display:none"></div> </div> <!-- END TEMPLATE: vbseo_likeshare --> </div> </div> </div> <!-- end text_wrapper --> <div class="text_wrapper postbit_legacy_wrapper postbit_legacy_wrapper_bottom"> <div class="alt2 picture main-column-picture status-icons" > <!-- BEGIN TEMPLATE: postbit_onlinestatus --> <span class="sprite inlineimg user_offline" title="rdezs is offline">rdezs is offline</span> <!-- END TEMPLATE: postbit_onlinestatus -->   </div> <div id="td_post_1162" class="main-column-text-wrapper buttons buttons-postings"> <div class="main-column-text"> <div class="right"><!-- controls --> <a href="https://www.powerstroke.org/forum/newreply.php?do=newreply&p=4164530" rel="nofollow"><span class="sprite button quote">Quote</span></a> <a href="https://www.powerstroke.org/forum/newreply.php?do=newreply&p=4164530" rel="nofollow" id="qr_4164530" onclick="return false"><span class="sprite button quickreply">Quick Reply</span></a> <!-- / controls --> </div> </div> </div> </div> <!-- end text_wrapper --> </section> <!-- BEGIN TEMPLATE: post_thanks_box --> <div id="post_thanks_box_4164530"></div> <!-- END TEMPLATE: post_thanks_box --> <!-- post 4164530 popup menu --> <!-- / post 4164530 popup menu --> <!-- AMS BELOW 39 POST --> <!-- END TEMPLATE: postbit_legacy --> </div> <!-- / post #4164530 --> <!-- END TEMPLATE: postbit_wrapper --><!-- BEGIN TEMPLATE: postbit_wrapper --> <!-- post #4174370 --> <div id="edit4174370" style="padding:0px 0px 0px 0px"> <!-- BEGIN TEMPLATE: postbit_legacy --> <section id="post4174370" class="tborder vbseo_like_postbit user-post" itemscope itemtype="http://schema.org/Comment"> <div class="text_wrapper postbit_legacy_wrapper_thead thead" > <span class="post-count"><a href="https://www.powerstroke.org/forum/6-0l-performance-parts-discussion/246552-nuc-oil-bypass-filtration-kit-install-pics-4.html#post4174370" id="postcount4174370" name="40" title="permalink"><strong>post #40</strong> of 89</a> </span> <!-- status icon and date --> <a name="post4174370"><span class="sprite inlineimg post_old">Old</span></a> <span itemprop="dateCreated">02-24-2013, 12:29 AM</span> <!-- / status icon and date --> </div> <div class="text_wrapper postbit_legacy_wrapper"> <div class="alt2 picture main-column-picture"> <div id="postmenu_4174370" itemprop="contributor"> <a rel="nofollow" class="bigusername" href="https://www.powerstroke.org/forum/members/122633-tuscany.html">Tuscany</a> </div> <div class="smallfont">WWW.COMPIGNTECH.COM</div> <div class="smallfont"><img src="https://www.powerstroke.org/forum/images/badge_rotm.gif" alt="" border="" /><br /><img src="https://www.powerstroke.org/forum/images/misc/badge_military_member.gif" alt="" border="" /></div> <div class="smallfont">  <br /> <div>Join Date: Oct 2011</div> <div> Posts: 8,735 </div> <!-- BEGIN TEMPLATE: post_thanks_postbit_info --> <div>Thanks: 98</div> <div> Thanked 119 Times in 93 Posts </div> <!-- END TEMPLATE: post_thanks_postbit_info --><!-- BEGIN TEMPLATE: dbtech_usertag_postbit --> <div>Mentioned: 10 Post(s)</div> <div>Quoted: 30 Post(s)</div> <!-- END TEMPLATE: dbtech_usertag_postbit --> <!-- BEGIN TEMPLATE: dto_garage_postbit_userinfo --> <!-- END TEMPLATE: dto_garage_postbit_userinfo --><div class="smallfont">Feedback Score: 10 reviews</div> <div> </div> </div> </div> <div id="td_post_4174370" class="main-column-text-wrapper alt1"> <div class="main-column-text"> <!-- message --> <div id="post_message_4174370" itemprop="text"> Any updates on oil change intervals?<!-- AMS TENTH IN POST --> </div> <!-- / message --> <!-- BEGIN TEMPLATE: vbseo_likeshare --> <div class="text_wrapper vbseo_buttons" id="lkbtn_1.246552.4174370"> <div class="alt2 vbseo_liked" style="display:none"></div> </div> <!-- END TEMPLATE: vbseo_likeshare --> <!-- sig --> <div class="vs_sig"> <hr class="sig"> <div align="center"><b>l BRYAN l</b></div><br /> <div align="center"><b><br /><span class="smallfont"><i>To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.</i></span><br /></b></div><br /> <div align="center"><b><br /><span class="smallfont"><i>To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.</i></span><br />COMPIGNTECH .COM</b></div><br /> <div align="center"><b>Look us up on Facebook</b></div><div align="center"><b>COMPRESSION IGNITION TECHNOLOGIES</b></div><br /> <div align="center"><b><font color="Silver">l 2005 l Ford F250 l FTX l</font></b></div><div align="center"><b><font color="silver">[A Few Odds-N-Ends]</font></b></div><br /> [CENTER]DLR </div> <!-- / sig --> </div> </div> </div> <!-- end text_wrapper --> <div class="text_wrapper postbit_legacy_wrapper postbit_legacy_wrapper_bottom"> <div class="alt2 picture main-column-picture status-icons" > <!-- BEGIN TEMPLATE: postbit_onlinestatus --> <span class="sprite inlineimg user_offline" title="Tuscany is offline">Tuscany is offline</span> <!-- END TEMPLATE: postbit_onlinestatus -->   </div> <div id="td_post_1162" class="main-column-text-wrapper buttons buttons-postings"> <div class="main-column-text"> <div class="right"><!-- controls --> <a href="https://www.powerstroke.org/forum/newreply.php?do=newreply&p=4174370" rel="nofollow"><span class="sprite button quote">Quote</span></a> <a href="https://www.powerstroke.org/forum/newreply.php?do=newreply&p=4174370" rel="nofollow" id="qr_4174370" onclick="return false"><span class="sprite button quickreply">Quick Reply</span></a> <!-- / controls --> </div> </div> </div> </div> <!-- end text_wrapper --> </section> <!-- BEGIN TEMPLATE: post_thanks_box --> <div id="post_thanks_box_4174370"></div> <!-- END TEMPLATE: post_thanks_box --> <!-- post 4174370 popup menu --> <!-- / post 4174370 popup menu --> <!-- AMS BELOW LAST POST --><div id="9999999" class="vs_dfp_standard_postbit_container" style="padding:0px 0px 0px 0px; "> <table class="tborder vs_dfp_standard_postbit_ad" cellpadding="0" cellspacing="0" border="0" width="100%" align="center"> <tr> <td class="thead" style="line-height:1.4em;" colspan="2"> <div> <span style="float:right;font-weight:normal"><a href="https://www.powerstroke.org/forum/register.php">Remove Advertisements</a></span> </div> Sponsored Links </td> </tr> <tr valign="top"> <td class="alt2" width="175px"> <div><a class="bigusername" href="https://www.powerstroke.org/forum">PowerStroke Forum</a></div> <div class="smallfont">Advertisement</div><div> <br /></div> </td><td class="alt1" > <table cellpadding="2" cellspacing="2" border="0" width="100%" align="left"> <tr> <td align="left"><div id="Powerstroke_org_300x250_PostbitLower_AUTO_Forum" style="width:auto; height:auto;"> <script type="text/javascript"> googletag.cmd.push(function() { deployads.push(function() { deployads.gpt.display("Powerstroke_org_300x250_PostbitLower_AUTO_Forum"); }); }); </script> </div></td> <td></td> </tr> </table> </td> </tr> </table></div><!-- AMS BELOW 40 POST --> <!-- END TEMPLATE: postbit_legacy --> </div> <!-- / post #4174370 --> <!-- END TEMPLATE: postbit_wrapper --><!-- AMS BOTTOM SHOWTHREAD LINK UNIT --><table class="tborder" cellspacing="1" cellpadding="3" border="0" align="center" width="100%"><tr><td class='tcat bottomtextunit' align='center'><div id="Powerstroke_org_600x24_BottomTextLink_AUTO_Forum" style="width:auto; height:auto;"> <script type="text/javascript"> googletag.cmd.push(function() { deployads.push(function() { deployads.gpt.display("Powerstroke_org_600x24_BottomTextLink_AUTO_Forum"); }); }); </script> </div></td></tr></table><div style="padding-bottom: 5px"></div><div id="lastpost"></div></div> <!-- start content table --> <!-- / start content table --> <!-- controls below postbits --> <table cellpadding="0" cellspacing="0" border="0" width="100%" style="margin-top:3px" class="text_wrapper"> <tr valign="top"> <td class="smallfont"><a href="https://www.powerstroke.org/forum/newreply.php?do=newreply&noquote=1&p=4174370" rel="nofollow"><span class="sprite button reply">Reply</span></a></td> <td align="right"><!-- BEGIN TEMPLATE: pagenav --> <div class="pagenav" align="right"> <table class="tborder" cellpadding="0" cellspacing="0" border="0"> <tr> <td class="vbmenu_control" style="font-weight:normal">Page 4 of 9</td> <td class="alt1 firstpage" nowrap="nowrap"><a rel="start" class="smallfont" href="https://www.powerstroke.org/forum/6-0l-performance-parts-discussion/246552-nuc-oil-bypass-filtration-kit-install-pics.html" title="First Page - Results 1 to 10 of 89"><strong>«</strong> First</a></td> <td class="alt1 prevpage"><a rel="prev" class="smallfont" href="https://www.powerstroke.org/forum/6-0l-performance-parts-discussion/246552-nuc-oil-bypass-filtration-kit-install-pics-3.html" title="Prev Page - Results 21 to 30 of 89"><span class="sprite lesser-than"><!-- --> </span></a></td> <!-- BEGIN TEMPLATE: pagenav_pagelink --> <td class="alt1"><a class="smallfont" href="https://www.powerstroke.org/forum/6-0l-performance-parts-discussion/246552-nuc-oil-bypass-filtration-kit-install-pics-2.html" title="Show results 11 to 20 of 89">2</a></td> <!-- END TEMPLATE: pagenav_pagelink --><!-- BEGIN TEMPLATE: pagenav_pagelink --> <td class="alt1"><a class="smallfont" href="https://www.powerstroke.org/forum/6-0l-performance-parts-discussion/246552-nuc-oil-bypass-filtration-kit-install-pics-3.html" title="Show results 21 to 30 of 89">3</a></td> <!-- END TEMPLATE: pagenav_pagelink --><!-- BEGIN TEMPLATE: pagenav_curpage --> <td class="alt2"><span class="smallfont" title="Showing results 31 to 40 of 89"><strong>4</strong></span></td> <!-- END TEMPLATE: pagenav_curpage --><!-- BEGIN TEMPLATE: pagenav_pagelink --> <td class="alt1"><a class="smallfont" href="https://www.powerstroke.org/forum/6-0l-performance-parts-discussion/246552-nuc-oil-bypass-filtration-kit-install-pics-5.html" title="Show results 41 to 50 of 89">5</a></td> <!-- END TEMPLATE: pagenav_pagelink --><!-- BEGIN TEMPLATE: pagenav_pagelink --> <td class="alt1"><a class="smallfont" href="https://www.powerstroke.org/forum/6-0l-performance-parts-discussion/246552-nuc-oil-bypass-filtration-kit-install-pics-6.html" title="Show results 51 to 60 of 89">6</a></td> <!-- END TEMPLATE: pagenav_pagelink --> <td class="alt1 nextpage"><a rel="next" class="smallfont" href="https://www.powerstroke.org/forum/6-0l-performance-parts-discussion/246552-nuc-oil-bypass-filtration-kit-install-pics-5.html" title="Next Page - Results 41 to 50 of 89"><span class="sprite greater-than"><!-- --> </span></a></td> <td class="alt1 lastpage" nowrap="nowrap"><a class="smallfont" href="https://www.powerstroke.org/forum/6-0l-performance-parts-discussion/246552-nuc-oil-bypass-filtration-kit-install-pics-9.html" title="Last Page - Results 81 to 89 of 89">Last <strong></strong></a></td> </tr> </table> </div> <!-- END TEMPLATE: pagenav --> <br> </td> </tr> </table> <!-- / controls below postbits --> <!-- BEGIN TEMPLATE: ad_showthread_beforeqr --> <!-- AMS FOOTER --> <!-- END TEMPLATE: ad_showthread_beforeqr --><!-- Taboola Content --> <div id="taboola-below-article-thumbnails-white"></div> <script type="text/javascript"> window._taboola = window._taboola || []; _taboola.push({ mode: "thumbnails-c", container: "taboola-below-article-thumbnails-white", placement: "Below Article Thumbnails White", target_type: "mix" }); </script> <!-- /Taboola Content --> <!-- ajax errors table --> <table class="tborder" cellpadding="0" cellspacing="0" border="0" style="display:none; position:absolute" id="ajax_post_errors"> <tr> <td class="thead"> <span style="float:right"><input type="button" class="button" value=" X " onclick="vB_QuickEditor.hide_errors()" id="ajax_post_errors_closebtn" /></span> vBulletin Message </td> </tr> <tr> <td class="alt2" colspan="2" id="ajax_post_errors_message"> </td> </tr> <tr> <td class="tfoot" colspan="2" align="center"><a href="https://www.powerstroke.org/forum/6-0l-performance-parts-discussion/246552-nuc-oil-bypass-filtration-kit-install-pics-4.html#" onclick="vB_QuickEditor.abort(); return false;">Cancel Changes</a></td> </tr> </table> <!-- / ajax errors table --> <!-- scripts for quick reply and quick edit --> <!-- BEGIN TEMPLATE: editor_clientscript --> <!-- Editor Scripts --> <script type="text/javascript"> <!-- var fontoptions = new Array(); var sizeoptions = new Array(); var smilieoptions = { }; var istyles = { }; var ltr = 'left'; var smiliewindow_x = 240; var smiliewindow_y = 280; var ignorequotechars = 1; var allowbasicbbcode = true; // vB Phrases vbphrase["wysiwyg_please_wait"] = "Please wait for the WYSIWYG editor to finish loading..."; vbphrase["wysiwyg_initialized"] = "WYSIWYG Editor initialized for %1$s in %2$s seconds."; vbphrase["wysiwyg_command_invalid"] = "This command is invalid or not implemented."; vbphrase["moz_must_select_text"] = "Mozilla requires that you must select some text for this function to work"; vbphrase["moz_edit_config_file"] = "You need to edit your Mozilla config file to allow this action."; vbphrase["enter_tag_option"] = "Please enter the option for your %1$s tag:"; vbphrase["must_select_text_to_use"] = "You must select some text to use this function."; vbphrase["browser_is_safari_no_wysiwyg"] = "The Safari browser does not support WYSIWYG mode."; vbphrase["enter_option_x_tag"] = "Enter the option for the [%1$s] tag:"; vbphrase["enter_text_to_be_formatted"] = "Enter the text to be formatted"; vbphrase["enter_link_text"] = "Enter the text to be displayed for the link (optional):"; vbphrase["enter_list_type"] = "What type of list do you want? Enter '1' for a numbered list, enter 'a' for an alphabetical list, or leave blank for a list with bullet points:"; vbphrase["enter_list_item"] = "Enter a list item.\r\nLeave the box empty or press 'Cancel' to complete the list:"; vbphrase["must_enter_subject"] = "You must enter a title / subject!"; vbphrase["message_too_short"] = "The message you have entered is too short. Please lengthen your message to at least %1$s characters."; vbphrase["enter_link_url"] = "Please enter the URL of your link:"; vbphrase["enter_image_url"] = "Please enter the URL of your image:"; vbphrase["enter_email_link"] = "Please enter the email address for the link:"; vbphrase["complete_image_verification"] = "You did not complete the Image Verification"; vbphrase["iespell_not_installed"] = "ieSpell is a spell-checking tool for Internet Explorer.\r\n\r\nIf you would like to download ieSpell, click OK; otherwise click Cancel.\r\n\r\nieSpell can be downloaded from http://www.iespell.com"; vbphrase["click_quick_reply_icon"] = "Please click one of the Quick Reply icons in the posts above to activate Quick Reply."; vbphrase["insert_all"] = "Insert All"; //--> </script> <!-- / Editor Scripts --> <!-- END TEMPLATE: editor_clientscript --> <script type="text/javascript"> <!-- vB_AJAX_QuickEdit_Init('posts'); //--> </script> <!-- / scripts for quick reply and quick edit --> <!-- quick reply --> <br /> <form action="https://www.powerstroke.org/forum/newreply.php?do=postreply&t=246552" method="post" onsubmit="return vbpegp_qr_prepare_submit(this, 10);" name="vbform" id="qrform"> <table class="tborder" cellpadding="0" cellspacing="0" border="0" width="100%" align="center"> <thead> <tr> <td class="tcat" colspan="2"> <a style="float:right" href="https://www.powerstroke.org/forum/6-0l-performance-parts-discussion/246552-nuc-oil-bypass-filtration-kit-install-pics-4.html#top" onclick="return toggle_collapse('quickreply');"><span class="sprite inlineimg collapseimg" id="collapseimg_quickreply"></span></a> Quick Reply </td> </tr> </thead> <tbody id="qr_error_tbody" style="display:none"> <tr> <td class="thead">The following errors occurred with your submission</td> </tr> <tr> <td class="alt1" id="qr_error_td"></td> </tr> <tr> <td class="tfoot" align="center"><span class="smallfont"><a href="https://www.powerstroke.org/forum/6-0l-performance-parts-discussion/246552-nuc-oil-bypass-filtration-kit-install-pics-4.html#" onclick="return qr_hide_errors()">Okay</a></span></td> </tr> </tbody> <tbody id="collapseobj_quickreply"> <tr> <td class="panelsurround" align="center"> <div class="panel"> <div align="left" style="max-width:; width:auto !important; width:"> <div class="smallfont vs_msglabel">Message:</div> <div id="vB_Editor_QR" class="vBulletin_editor"> <script type="text/javascript"> <!-- var threaded_mode = 0; var require_click = 0; var is_last_page = 0; // leave for people with cached JS files var allow_ajax_qr = 0; var ajax_last_post = 1416616344; // --> </script> <!-- BEGIN TEMPLATE: showthread_quickreply --> <div class="controlbar" style="padding-right:8px"> <fieldset style="border:0px; padding:0px; margin:0px"> <textarea name="message" id="vB_Editor_QR_textarea" rows="10" cols="60" style="width:100%; height:200px" tabindex="1" dir="ltr"></textarea> </fieldset> <!--width:480px--> </div> <input type="hidden" name="wysiwyg" id="vB_Editor_QR_mode" value="0" /> <input type="hidden" name="styleid" value="0" /> <script type="text/javascript"> <!-- vB_Editor['vB_Editor_QR'] = new vB_Text_Editor('vB_Editor_QR', 0, '9', '1'); var QR_EditorID = 'vB_Editor_QR'; //--> </script> <!-- END TEMPLATE: showthread_quickreply --> </div> <fieldset class="fieldset"> <legend>Options</legend> <div style="padding:3px"> <label for="qr_quickreply"><input type="checkbox" name="quickreply" value="1" id="qr_quickreply" accesskey="w" tabindex="4" />Quote message in reply?</label> </div> </fieldset> <!-- BEGIN TEMPLATE: vbpegp_registerForm3 --> <style type="text/css"> /* ***** red and green boxes for username verification used during registration ***** */ .greenbox { border: 1px solid #337733; background: #bbffbb; color: #337733; padding: 3px; } .redbox { border:1px solid #773333; background: #ffbbbb; color: #773333; padding: 3px; } </style> <link type="text/css" rel="stylesheet" href="https://www.powerstroke.org/forum/vbpegp/resources/css/register.css" /> <div class="detailsContainer "> <style> table.registration .column_or .block_or {display: none;} .container table.registration .column_or .block_or {display: block;} </style> <table width="100%" cellspacing="0" cellpadding="0" class="registration"> <tbody> <tr> <td width="55%" valign="top" class="" style="vertical-align:top"> <div class="blockrow"> <h2> Register Now </h2> <br> <br> </div> <div class="smallfont" style="margin-bottom:3px"> In order to be able to post messages on the Ford Powerstroke Diesel Forum forums, you must first register.<br /> Please enter your desired user name, your email address and other required details in the form below.<br><br> </div> <div class="smallfont" style="margin-bottom:3px"> <strong>User Name</strong>:<br /> <input class="bginput" id="regusername" type="text" name="username" maxlength="25" value="" /><img src="https://www.powerstroke.org/forum/clear.gif" id="reg_verif_image" onclick="return toggle_collapse('dialog_box')" style="display:none;" alt="" /> <div id="collapseobj_dialog_box"><div id="reg_verif_div" style="display:none;"></div></div> <script type="text/javascript" src="https://www.powerstroke.org/forum/clientscript/vbulletin_ajax_nameverif.js?v=388"></script> <script type="text/javascript"> <!-- regname_verif = new vB_AJAX_NameVerify('regname_verif', 'regusername'); //--> </script> </div> <fieldset class="fieldset"> <legend>Password</legend> <table cellpadding="0" cellspacing="3" border="0" width="400"> <tr> <td >Please enter a password for your user account. Note that passwords are case-sensitive.<Br><br></td> </tr> <tr> <td > Password:<br /> <input type="password" class="bginput" name="password" maxlength="50" value="" /><br><br> </td> </tr> <tr> <td> Confirm Password:<br /> <input type="password" class="bginput" name="passwordconfirm" maxlength="50" value="" /> </td> </tr> </table> </fieldset> <fieldset class="fieldset"> <legend>Email Address</legend> <table cellpadding="0" cellspacing="3" border="0" width="400"> <tr> <td colspan="2">Please enter a valid email address for yourself.<br><br></td> </tr> <tr> <td> Email Address:<br /> <input type="text" class="bginput" name="email" size="25" maxlength="50" value="" dir="ltr" /> </td> <td> <!-- Confirm Email Address:<br /> <input type="text" class="bginput" name="emailconfirm" size="25" maxlength="50" value="" dir="ltr" /> --> </td> </tr> </table> </fieldset> </td> <td class="column_or"><div class="block_or">OR</div></td> <td width="30%" valign="top" class="" style="vertical-align:top"> <div class="blockrow"> <h2> Log-in </h2><br> <br> </div> <table cellpadding="0" cellspacing="3" border="0" width="90%"> <tr> <td class="smallfont" style="white-space: nowrap;"><label for="navbar_username2">User Name</label></td> <td align="right"><input type="text" style="font-size: 11px" name="vb_login_username" id="navbar_username2" size="10" accesskey="u" tabindex="1" value="" onfocus="if (this.value == 'User Name') this.value = '';" /></td> </tr> <tr> <td class="smallfont"><br> <label for="navbar_password2">Password</label><br><br> </td> <td align="right"><br> <input type="password" style="font-size: 11px" name="vb_login_password" id="navbar_password2" size="10" tabindex="1" /><br> <br> </td> </tr> <tr> <td nowrap class="smallfont"><label for="cb_cookieuser_navbar2">Remember Me? <input type="checkbox" name="cookieuser" value="1" tabindex="1" id="cb_cookieuser_navbar2" accesskey="c" /></label></td> <td align="right"><input type="submit" class="button" value="Log in" tabindex="1" title="Enter your username and password in the boxes provided to login, or click the 'register' button to create a profile for yourself." accesskey="s" /></td> </tr> </table> </td> </tr> </tbody></table> </div> <!-- END TEMPLATE: vbpegp_registerForm3 --> <div class="recaptcha_v2"> <input id="hash" type="hidden" name="humanverify[hash]" value="49a6f589637c8715e41e725a94571819" /> <script src="https://www.google.com/recaptcha/api.js"></script> <div class="g-recaptcha" data-sitekey="6LfdilQUAAAAAF2jHnpwUqGyx4SFEGZvKQT0H4Fw"></div> </div> </div> </div> <div class="vs_submit"> <input type="hidden" name="poststarttime" value="" /> <input type="hidden" name="posthash" value="" /> <input type="hidden" name="fromquickreply" value="1" /> <input type="hidden" name="s" value="65f590ce193e28d1d23fcc5676ea1ba8" /> <input type="hidden" name="securitytoken" value="guest" /> <input type="hidden" name="do" value="postreply" /> <input type="hidden" name="t" value="246552" id="qr_threadid" /> <input type="hidden" name="p" value="who cares" id="qr_postid" /> <input type="hidden" name="specifiedpost" value="0" id="qr_specifiedpost" /> <input type="hidden" name="parseurl" value="1" /> <input type="hidden" name="loggedinuser" value="0" /> <input type="button" class="button" value="Post Quick Reply" accesskey="s" title="(Alt + S)" name="sbutton" tabindex="2" id="qr_submit" onclick="clickedelm = this.value; " /> <input type="submit" class="button" value="Go Advanced" accesskey="x" title="(Alt + X)" name="preview" tabindex="3" id="qr_preview" onclick="clickedelm = this.value" /> <div align="center" id="qr_posting_msg" style="display:none; margin-top:6px"> <span class="sprite inlineimg progress">Posting Quick Reply - Please Wait</span> <strong>Posting Quick Reply - Please Wait</strong> </div> </td> </tr> </tbody> </table> </form> <script type="text/javascript"> <!-- // initialize quick reply qr_init(); //--> </script> <!-- / quick reply --> <!-- next / previous links --> <br /> <div class="smallfont" align="center"> <strong>«</strong> <a href="https://www.powerstroke.org/forum/6-0l-performance-parts-discussion/246552-nuc-oil-bypass-filtration-kit-install-pics-prev-thread.html" rel="nofollow">Previous Thread</a> | <a href="https://www.powerstroke.org/forum/6-0l-performance-parts-discussion/246552-nuc-oil-bypass-filtration-kit-install-pics-next-thread.html" rel="nofollow">Next Thread</a> <strong>»</strong> </div> <!-- / next / previous links --> <!-- controls for non-popup browsers --> <table class="tborder" cellpadding="0" cellspacing="0" border="0" width="100%" align="center" style="border-top-width:0px"> <tr> <td class="thead" colspan="2">Thread Tools<a name="goto_threadtools"></a></td> </tr> <tr valign="top"> <td class="alt1" colspan="2"> <!-- thread tools --> <div class="smallfont"> <div><span class="sprite inlineimg printer">Show Printable Version</span> <a href="https://www.powerstroke.org/forum/6-0l-performance-parts-discussion/246552-nuc-oil-bypass-filtration-kit-install-pics-print.html" rel="nofollow">Show Printable Version</a></div> <div><span class="sprite inlineimg sendtofriend">Email this Page</span> <a href="https://www.powerstroke.org/forum/sendmessage.php?do=sendtofriend&t=246552" rel="nofollow">Email this Page</a></div> </div> <!-- / thread tools --> </td> </tr> <tr> <td class="thead" colspan="2">Display Modes<a name="goto_displaymodes"></a></td> </tr> <tr valign="top"> <td class="alt2" colspan="2"> <!-- thread display modes --> <div class="smallfont"> <div><span class="sprite inlineimg mode_linear">Linear Mode</span> <strong>Linear Mode</strong></div> <div><span class="sprite inlineimg mode_hybrid">Hybrid Mode</span> <a rel="nofollow" href="https://www.powerstroke.org/forum/6-0l-performance-parts-discussion/246552-nuc-oil-bypass-filtration-kit-install-pics.html?mode=hybrid">Switch to Hybrid Mode</a></div> <div><span class="sprite inlineimg mode_threaded">Threaded Mode</span> <a rel="nofollow" href="https://www.powerstroke.org/forum/6-0l-performance-parts-discussion/246552-nuc-oil-bypass-filtration-kit-install-pics-4.html?mode=threaded#post3004949">Switch to Threaded Mode</a></div> </div> <!-- / thread display modes --> </td> </tr> </table> <br /> <!-- / controls for non-popup browsers --> <!-- forum rules and admin links --> <table cellpadding="0" cellspacing="0" border="0" width="100%" align="center"> <tr valign="bottom"> <td width="100%" valign="top"> </td> <td class="smallfont" align="right"> <table cellpadding="0" cellspacing="0" border="0"> </table> </td> </tr> </table> <!-- /forum rules and admin links --> <br> <br /> <!-- BEGIN TEMPLATE: forumrules --> <table class="tborder forumrules" cellpadding="0" cellspacing="0" border="0" width="210"> <thead> <tr> <td class="thead"> Posting Rules </td> <td class="thead" align="right"> <a style="float:right" href="https://www.powerstroke.org/forum/6-0l-performance-parts-discussion/246552-nuc-oil-bypass-filtration-kit-install-pics-4.html#top" onclick="return toggle_collapse('forumrules')"><span id="collapseimg_forumrules" class="sprite inlineimg collapseimg"><!-- --> </span></a> </td> </tr> </thead> <tbody id="collapseobj_forumrules" style=""> <tr> <td colspan="2" class="alt1" nowrap="nowrap"><div class="smallfont"> <div>You <strong>may</strong> post new threads</div> <div>You <strong>may</strong> post replies</div> <div>You <strong>may not</strong> post attachments</div> <div>You <strong>may not</strong> edit your posts</div> <hr /> <div><a rel="nofollow" href="https://www.powerstroke.org/forum/misc.php?do=bbcode" target="_blank">BB code</a> is <strong>On</strong></div> <div><a rel="nofollow" href="https://www.powerstroke.org/forum/misc.php?do=showsmilies" target="_blank">Smilies</a> are <strong>On</strong></div> <div><a rel="nofollow" href="https://www.powerstroke.org/forum/misc.php?do=bbcode#imgcode" target="_blank">[IMG]</a> code is <strong>On</strong></div> <div>HTML code is <strong>On</strong></div><div><a rel="nofollow" href="https://www.powerstroke.org/forum/misc.php?do=linkbacks#trackbacks" target="_blank">Trackbacks</a> are <strong>On</strong></div> <div><a rel="nofollow" href="https://www.powerstroke.org/forum/misc.php?do=linkbacks#pingbacks" target="_blank">Pingbacks</a> are <strong>On</strong></div> <div><a rel="nofollow" href="https://www.powerstroke.org/forum/misc.php?do=linkbacks#refbacks" target="_blank">Refbacks</a> are <strong>On</strong></div> <hr /> <div><a rel="nofollow" href="https://www.powerstroke.org/forum/misc.php?do=showrules" target="_blank">Forum Rules</a></div> </div></td> </tr> </tbody> </table> <!-- END TEMPLATE: forumrules --> </div><!-- Close class="showthreadPage" --> <!-- temp --> <div style="display:none"> <!-- thread rate --> <!-- / thread rate --> </div> <script type="text/javascript" src="https://www.powerstroke.org/forum/clientscript/vbulletin_autosave.js"></script> <!-- SlimCut --> <div class="ams-vb-hook ams-1x1_SlimCut" style="width:100%; text-align:center;"><div id="Powerstroke_org_1x1_SlimCut_AUTO_Forum" style="width:auto; height:auto;"> <script type="text/javascript"> googletag.cmd.push(function() { deployads.push(function() { deployads.gpt.display("Powerstroke_org_1x1_SlimCut_AUTO_Forum"); }); }); </script> </div></div> <!-- BEGIN TEMPLATE: vbseo_linkbackmenu --> <div class="vbmenu_popup" id="linkbacktools_menu" style="display:none"> <table cellpadding="4" cellspacing="1" border="0"> <tr> <td class="thead">LinkBack<a name="goto_linkback"></a></td> </tr> <tr> <td class="vbmenu_option"><img class="inlineimg" src="https://www.powerstroke.org/forum/vbseo/resources/images/forum/linkback_url.gif" alt="LinkBack URL" /> <a href="https://www.powerstroke.org/forum/6-0l-performance-parts-discussion/246552-nuc-oil-bypass-filtration-kit-install-pics.html" onclick="prompt('Use the following URL when referencing this thread from another forum or blog.','https://www.powerstroke.org/forum/6-0l-performance-parts-discussion/246552-nuc-oil-bypass-filtration-kit-install-pics.html');return false;">LinkBack URL</a></td> </tr> <tr> <td class="vbmenu_option"><img class="inlineimg" src="https://www.powerstroke.org/forum/vbseo/resources/images/forum/linkback_about.gif" alt="About LinkBacks" /> <a rel="nofollow" href="https://www.powerstroke.org/forum/misc.php?do=linkbacks">About LinkBacks</a></td> </tr> </table> </div> <!-- END TEMPLATE: vbseo_linkbackmenu --> </div> </div> <aside class="noprint" id="sidebar"> <div style="display: none;" class="sidebar-controls "> <span class="sprite inlineimg sidebar-controls-icon"></span> <span class="sprite inlineimg br-creditcheck"></span> <span class="sprite inlineimg br-warranty"></span> <span class="sprite inlineimg br-history"></span> <span class="sprite inlineimg br-shipping"></span> <span class="sprite inlineimg br-escrow"></span> <span class="sprite inlineimg br-tires"></span> <span class="sprite inlineimg br-inspections"></span> <span class="sprite inlineimg br-insurance"></span> </div> <div class="sidebar"> <!-- BEGIN TEMPLATE: adv_portal_search_in_one --> <div class="search-in-one"> <div class="change_btn "><div class="image sprite-google-search"></div> <ul class="search_menu"> <li data-search-type="google-search"><div class="icon sprite-google-search"></div> Google search</li> <li data-search-type="vb-search"><div class="icon sprite-vb-search"></div> VB search</li> </ul> </div> <div class="search-item google-search"> <div class="ams_gtsearch" style="width: 250px; margin:auto;" id="cse_gtsearch_form1"></div> <script> vsamsgtsearches.push("cse_gtsearch_form1"); </script> </div> </div> <!-- END TEMPLATE: adv_portal_search_in_one --><!-- BEGIN TEMPLATE: adv_portal_sponsors --> <section class="text_wrapper ad box-ad"> <div class="ams-vb-hook ams-300x250_TopRight" style="width:100%; text-align:center;"><div id="Powerstroke_org_300x250_TopRight_AUTO_Forum" style="width:auto; height:auto;"> <script type="text/javascript"> googletag.cmd.push(function() { deployads.push(function() { deployads.gpt.display("Powerstroke_org_300x250_TopRight_AUTO_Forum"); }); }); </script> </div></div> </section><!-- AMS ADV PORTAL SPONORS --> <!-- END TEMPLATE: adv_portal_sponsors --> <!-- HotDeals --> <!-- BEGIN TEMPLATE: adv_portal_vs_hotdeals_wrapper --> <table align="center" border="0" cellpadding="0" cellspacing="0" class="cmps-table" width="100%" style="margin-bottom:10px;"> <thead> <tr> <td colspan="0"> <h2 class="title">Hot Deals</h2></td> </tr> </thead> <tbody id="collapseobj_module_167" style=""> <!-- BEGIN TEMPLATE: adv_portal_vs_hotdeals_bits --> <tr> <td class="alt2 columns columns-vs_hot_deals"> <div class="main-column-text-wrapper" style="float:none; margin-left:0px;"> <div class="text main-column-text smallfont" style="border-bottom:1px solid #ececec; display:table; margin-left:0px;"> <span class="text_view_deal" style="display:table-cell; padding-bottom:15px; vertical-align:middle;"> <strong><a rel="nofollow" target="_blank" href="https://www.amazon.com/gp/product/B075YLKDN9/ref=as_li_tl?ie=UTF8&tag=vs-wiseguide-prime-day-2019-20&camp=1789&creative=9325&linkCode=as2&creativeASIN=B075YLKDN9&linkId=51a181440be232656e71d102d62191c8" title="DEWALT" class="hotDealsPostLink1 deals_vendor nolinks norewrite" style="display:inline;">DEWALT</a></strong> / <a rel="nofollow" target="_blank" href="https://www.amazon.com/gp/product/B075YLKDN9/ref=as_li_tl?ie=UTF8&tag=vs-wiseguide-prime-day-2019-20&camp=1789&creative=9325&linkCode=as2&creativeASIN=B075YLKDN9&linkId=51a181440be232656e71d102d62191c8" title="DEWALT" class="hotDealsPostLink1 deals_description nolinks norewrite" style="display:inline;">Plenty of DEWALT tools are on sale during Amazon Prime Day 2019.</a> </span> <span class="btn_view_deal" style="display:table-cell; padding-bottom:15px; padding-left:10px; vertical-align:middle; white-space:nowrap;"> <a rel="nofollow" target="_blank" href="https://www.amazon.com/gp/product/B075YLKDN9/ref=as_li_tl?ie=UTF8&tag=vs-wiseguide-prime-day-2019-20&camp=1789&creative=9325&linkCode=as2&creativeASIN=B075YLKDN9&linkId=51a181440be232656e71d102d62191c8" title="DEWALT" id="hotDealsDealLink1" class="nolinks norewrite"><span class="btn" style="font-size:1.2rem; border-radius:0px !important; -moz-border-radius:0px !important; -webkit-border-radius:0px !important; -o-border-radius:0px !important;">View Deal</span></a> </span> </div> </div> </td> </tr> <!-- END TEMPLATE: adv_portal_vs_hotdeals_bits --><!-- BEGIN TEMPLATE: adv_portal_vs_hotdeals_bits --> <tr> <td class="alt2 columns columns-vs_hot_deals"> <div class="main-column-text-wrapper" style="float:none; margin-left:0px;"> <div class="text main-column-text smallfont" style="border-bottom:1px solid #ececec; display:table; margin-left:0px;"> <span class="text_view_deal" style="display:table-cell; padding-bottom:15px; vertical-align:middle;"> <strong><a rel="nofollow" target="_blank" href="http://www.kqzyfj.com/click-8476550-13632679?sid=wg-autos-rss-20" title="RaceChip USA" class="hotDealsPostLink2 deals_vendor nolinks norewrite" style="display:inline;">RaceChip USA</a></strong> / <a rel="nofollow" target="_blank" href="http://www.kqzyfj.com/click-8476550-13632679?sid=wg-autos-rss-20" title="RaceChip USA" class="hotDealsPostLink2 deals_description nolinks norewrite" style="display:inline;">Save $100 on RaceChip's GTS and GTS Black Premium Chips</a> </span> <span class="btn_view_deal" style="display:table-cell; padding-bottom:15px; padding-left:10px; vertical-align:middle; white-space:nowrap;"> <a rel="nofollow" target="_blank" href="http://www.kqzyfj.com/click-8476550-13632679?sid=wg-autos-rss-20" title="RaceChip USA" id="hotDealsDealLink2" class="nolinks norewrite"><span class="btn" style="font-size:1.2rem; border-radius:0px !important; -moz-border-radius:0px !important; -webkit-border-radius:0px !important; -o-border-radius:0px !important;">View Deal</span></a> </span> </div> </div> </td> </tr> <!-- END TEMPLATE: adv_portal_vs_hotdeals_bits --><!-- BEGIN TEMPLATE: adv_portal_vs_hotdeals_bits --> <tr> <td class="alt2 columns columns-vs_hot_deals"> <div class="main-column-text-wrapper" style="float:none; margin-left:0px;"> <div class="text main-column-text smallfont" style="border-bottom:1px solid #ececec; display:table; margin-left:0px;"> <span class="text_view_deal" style="display:table-cell; padding-bottom:15px; vertical-align:middle;"> <strong><a rel="nofollow" target="_blank" href="http://www.kqzyfj.com/click-8476550-10399910?sid=wg-autos-rss-20" title="Tire Rack" class="hotDealsPostLink3 deals_vendor nolinks norewrite" style="display:inline;">Tire Rack</a></strong> / <a rel="nofollow" target="_blank" href="http://www.kqzyfj.com/click-8476550-10399910?sid=wg-autos-rss-20" title="Tire Rack" class="hotDealsPostLink3 deals_description nolinks norewrite" style="display:inline;">Get up to $70 back on a brand new set of tires from Tire Rack!</a> </span> <span class="btn_view_deal" style="display:table-cell; padding-bottom:15px; padding-left:10px; vertical-align:middle; white-space:nowrap;"> <a rel="nofollow" target="_blank" href="http://www.kqzyfj.com/click-8476550-10399910?sid=wg-autos-rss-20" title="Tire Rack" id="hotDealsDealLink3" class="nolinks norewrite"><span class="btn" style="font-size:1.2rem; border-radius:0px !important; -moz-border-radius:0px !important; -webkit-border-radius:0px !important; -o-border-radius:0px !important;">View Deal</span></a> </span> </div> </div> </td> </tr> <!-- END TEMPLATE: adv_portal_vs_hotdeals_bits --><!-- BEGIN TEMPLATE: adv_portal_vs_hotdeals_bits --> <tr> <td class="alt2 columns columns-vs_hot_deals"> <div class="main-column-text-wrapper" style="float:none; margin-left:0px;"> <div class="text main-column-text smallfont" style="border-bottom:1px solid #ececec; display:table; margin-left:0px;"> <span class="text_view_deal" style="display:table-cell; padding-bottom:15px; vertical-align:middle;"> <strong><a rel="nofollow" target="_blank" href="http://www.anrdoezrs.net/links/8476550/type/dlg/sid/wg-autos-rss-20/https://www.sears.com/craftsman-cm-2.5-ton-low/p-A031074565?plpSellerId=Sears&prdNo=2&blockNo=2&blockType=G2&sid=IAx20050830x000545&aff=Y&PID=1225267&AID=13166739&utm_medium=1122587_1225267_13166739&cjevent=1568ea9993a011e9829600980a1c0e0f" title="Craftsman" class="hotDealsPostLink4 deals_vendor nolinks norewrite" style="display:inline;">Craftsman</a></strong> / <a rel="nofollow" target="_blank" href="http://www.anrdoezrs.net/links/8476550/type/dlg/sid/wg-autos-rss-20/https://www.sears.com/craftsman-cm-2.5-ton-low/p-A031074565?plpSellerId=Sears&prdNo=2&blockNo=2&blockType=G2&sid=IAx20050830x000545&aff=Y&PID=1225267&AID=13166739&utm_medium=1122587_1225267_13166739&cjevent=1568ea9993a011e9829600980a1c0e0f" title="Craftsman" class="hotDealsPostLink4 deals_description nolinks norewrite" style="display:inline;">Get a Craftsman Low-Profile Floor Jack for Just $49.99</a> </span> <span class="btn_view_deal" style="display:table-cell; padding-bottom:15px; padding-left:10px; vertical-align:middle; white-space:nowrap;"> <a rel="nofollow" target="_blank" href="http://www.anrdoezrs.net/links/8476550/type/dlg/sid/wg-autos-rss-20/https://www.sears.com/craftsman-cm-2.5-ton-low/p-A031074565?plpSellerId=Sears&prdNo=2&blockNo=2&blockType=G2&sid=IAx20050830x000545&aff=Y&PID=1225267&AID=13166739&utm_medium=1122587_1225267_13166739&cjevent=1568ea9993a011e9829600980a1c0e0f" title="Craftsman" id="hotDealsDealLink4" class="nolinks norewrite"><span class="btn" style="font-size:1.2rem; border-radius:0px !important; -moz-border-radius:0px !important; -webkit-border-radius:0px !important; -o-border-radius:0px !important;">View Deal</span></a> </span> </div> </div> </td> </tr> <!-- END TEMPLATE: adv_portal_vs_hotdeals_bits --><!-- BEGIN TEMPLATE: adv_portal_vs_hotdeals_bits --> <tr> <td class="alt2 columns columns-vs_hot_deals"> <div class="main-column-text-wrapper" style="float:none; margin-left:0px;"> <div class="text main-column-text smallfont" style="border-bottom:1px solid #ececec; display:table; margin-left:0px;"> <span class="text_view_deal" style="display:table-cell; padding-bottom:15px; vertical-align:middle;"> <strong><a rel="nofollow" target="_blank" href="http://rover.ebay.com/rover/1/711-53200-19255-0/1?ff3=4&pub=5575208979&toolid=10001&campid=5338491044&customid=&mpre=https%3A%2F%2Fwww.ebay.com%2Fe%2Fp%26a%2Fjegs-coupon" title="JEGS" class="hotDealsPostLink5 deals_vendor nolinks norewrite" style="display:inline;">JEGS</a></strong> / <a rel="nofollow" target="_blank" href="http://rover.ebay.com/rover/1/711-53200-19255-0/1?ff3=4&pub=5575208979&toolid=10001&campid=5338491044&customid=&mpre=https%3A%2F%2Fwww.ebay.com%2Fe%2Fp%26a%2Fjegs-coupon" title="JEGS" class="hotDealsPostLink5 deals_description nolinks norewrite" style="display:inline;">Save 10% on JEGS via eBay for a limited time!</a> </span> <span class="btn_view_deal" style="display:table-cell; padding-bottom:15px; padding-left:10px; vertical-align:middle; white-space:nowrap;"> <a rel="nofollow" target="_blank" href="http://rover.ebay.com/rover/1/711-53200-19255-0/1?ff3=4&pub=5575208979&toolid=10001&campid=5338491044&customid=&mpre=https%3A%2F%2Fwww.ebay.com%2Fe%2Fp%26a%2Fjegs-coupon" title="JEGS" id="hotDealsDealLink5" class="nolinks norewrite"><span class="btn" style="font-size:1.2rem; border-radius:0px !important; -moz-border-radius:0px !important; -webkit-border-radius:0px !important; -o-border-radius:0px !important;">View Deal</span></a> </span> </div> </div> </td> </tr> <!-- END TEMPLATE: adv_portal_vs_hotdeals_bits --> </tbody> </table> <script type="text/javascript"> var hotDealsPostLink1 = document.getElementsByClassName("hotDealsPostLink1"); for(var i = 0; i < hotDealsPostLink1.length; i++) { (function(index) { hotDealsPostLink1[index].addEventListener("click", function() { _gaq.push(["_trackEvent", "hotDealsPostLink1", "https://www.amazon.com/gp/product/B075YLKDN9/ref=as_li_tl?ie=UTF8&tag=vs-wiseguide-prime-day-2019-20&camp=1789&creative=9325&linkCode=as2&creativeASIN=B075YLKDN9&linkId=51a181440be232656e71d102d62191c8", "true",,true]); }) })(i); } document.getElementById("hotDealsDealLink1").addEventListener("click", function() { _gaq.push(["_trackEvent", "hotDealsDealLink1", "https://www.amazon.com/gp/product/B075YLKDN9/ref=as_li_tl?ie=UTF8&tag=vs-wiseguide-prime-day-2019-20&camp=1789&creative=9325&linkCode=as2&creativeASIN=B075YLKDN9&linkId=51a181440be232656e71d102d62191c8", "true",,true]); }) var hotDealsPostLink2 = document.getElementsByClassName("hotDealsPostLink2"); for(var i = 0; i < hotDealsPostLink2.length; i++) { (function(index) { hotDealsPostLink2[index].addEventListener("click", function() { _gaq.push(["_trackEvent", "hotDealsPostLink2", "http://www.kqzyfj.com/click-8476550-13632679?sid=wg-autos-rss-20", "true",,true]); }) })(i); } document.getElementById("hotDealsDealLink2").addEventListener("click", function() { _gaq.push(["_trackEvent", "hotDealsDealLink2", "http://www.kqzyfj.com/click-8476550-13632679?sid=wg-autos-rss-20", "true",,true]); }) var hotDealsPostLink3 = document.getElementsByClassName("hotDealsPostLink3"); for(var i = 0; i < hotDealsPostLink3.length; i++) { (function(index) { hotDealsPostLink3[index].addEventListener("click", function() { _gaq.push(["_trackEvent", "hotDealsPostLink3", "http://www.kqzyfj.com/click-8476550-10399910?sid=wg-autos-rss-20", "true",,true]); }) })(i); } document.getElementById("hotDealsDealLink3").addEventListener("click", function() { _gaq.push(["_trackEvent", "hotDealsDealLink3", "http://www.kqzyfj.com/click-8476550-10399910?sid=wg-autos-rss-20", "true",,true]); }) var hotDealsPostLink4 = document.getElementsByClassName("hotDealsPostLink4"); for(var i = 0; i < hotDealsPostLink4.length; i++) { (function(index) { hotDealsPostLink4[index].addEventListener("click", function() { _gaq.push(["_trackEvent", "hotDealsPostLink4", "http://www.anrdoezrs.net/links/8476550/type/dlg/sid/wg-autos-rss-20/https://www.sears.com/craftsman-cm-2.5-ton-low/p-A031074565?plpSellerId=Sears&prdNo=2&blockNo=2&blockType=G2&sid=IAx20050830x000545&aff=Y&PID=1225267&AID=13166739&utm_medium=1122587_1225267_13166739&cjevent=1568ea9993a011e9829600980a1c0e0f", "true",,true]); }) })(i); } document.getElementById("hotDealsDealLink4").addEventListener("click", function() { _gaq.push(["_trackEvent", "hotDealsDealLink4", "http://www.anrdoezrs.net/links/8476550/type/dlg/sid/wg-autos-rss-20/https://www.sears.com/craftsman-cm-2.5-ton-low/p-A031074565?plpSellerId=Sears&prdNo=2&blockNo=2&blockType=G2&sid=IAx20050830x000545&aff=Y&PID=1225267&AID=13166739&utm_medium=1122587_1225267_13166739&cjevent=1568ea9993a011e9829600980a1c0e0f", "true",,true]); }) var hotDealsPostLink5 = document.getElementsByClassName("hotDealsPostLink5"); for(var i = 0; i < hotDealsPostLink5.length; i++) { (function(index) { hotDealsPostLink5[index].addEventListener("click", function() { _gaq.push(["_trackEvent", "hotDealsPostLink5", "http://rover.ebay.com/rover/1/711-53200-19255-0/1?ff3=4&pub=5575208979&toolid=10001&campid=5338491044&customid=&mpre=https%3A%2F%2Fwww.ebay.com%2Fe%2Fp%26a%2Fjegs-coupon", "true",,true]); }) })(i); } document.getElementById("hotDealsDealLink5").addEventListener("click", function() { _gaq.push(["_trackEvent", "hotDealsDealLink5", "http://rover.ebay.com/rover/1/711-53200-19255-0/1?ff3=4&pub=5575208979&toolid=10001&campid=5338491044&customid=&mpre=https%3A%2F%2Fwww.ebay.com%2Fe%2Fp%26a%2Fjegs-coupon", "true",,true]); }) </script> <!-- END TEMPLATE: adv_portal_vs_hotdeals_wrapper --> <!-- /HotDeals --> <!-- BEGIN TEMPLATE: adv_portal_featured_vehicle --> <!-- existing ad code goes here --> <div class="ams-vb-hook ams-328x170_FeaturedVehicle" style="width:100%; text-align:center;"><div id="Powerstroke_org_328x170_FeaturedVehicle_AUTO_Forum" style="width:auto; height:auto;"> <script type="text/javascript"> googletag.cmd.push(function() { deployads.push(function() { deployads.gpt.display("Powerstroke_org_328x170_FeaturedVehicle_AUTO_Forum"); }); }); </script> </div></div> <!-- END TEMPLATE: adv_portal_featured_vehicle --><!-- BEGIN TEMPLATE: adv_portal_auto_insurance --> <div class="ams-vb-hook ams-328x170_AutoInsurance" style="width:100%; text-align:center;"><div id="Powerstroke_org_328x170_AutoInsurance_AUTO_Forum" style="width:auto; height:auto;"> <script type="text/javascript"> googletag.cmd.push(function() { deployads.push(function() { deployads.gpt.display("Powerstroke_org_328x170_AutoInsurance_AUTO_Forum"); }); }); </script> </div></div> <!-- END TEMPLATE: adv_portal_auto_insurance --><!-- BEGIN TEMPLATE: adv_portal_module_wrapper --> <section> <table align="center" border="0" cellpadding="0" cellspacing="0" class="cmps-table" width="100%"> <thead> <tr> <td colspan="0"> <h2 class="title">Premium Vendor Showcase</h2></td> </tr> </thead> <tbody id="collapseobj_module_113" style=""> <!-- BEGIN TEMPLATE: adv_portal_premium_vendor --> <tr> <td> <div class="ams-vb-hook ams-300x120_PremiumVendor" style="width:100%; text-align:center;"><div id="Powerstroke_org_300x120_PremiumVendor_AUTO_Forum" style="width:auto; height:auto;"> <script type="text/javascript"> googletag.cmd.push(function() { deployads.push(function() { deployads.gpt.display("Powerstroke_org_300x120_PremiumVendor_AUTO_Forum"); }); }); </script> </div></div> </td> </tr> <!-- END TEMPLATE: adv_portal_premium_vendor --> </tbody> </table> </section> <!-- END TEMPLATE: adv_portal_module_wrapper --><!-- BEGIN TEMPLATE: adv_portal_wheels_and_tires --> <div class="ams-vb-hook ams-328x170_WheelsTire" style="width:100%; text-align:center;"><div id="Powerstroke_org_328x170_WheelsTire_AUTO_Forum" style="width:auto; height:auto;"> <script type="text/javascript"> googletag.cmd.push(function() { deployads.push(function() { deployads.gpt.display("Powerstroke_org_328x170_WheelsTire_AUTO_Forum"); }); }); </script> </div></div> <!-- END TEMPLATE: adv_portal_wheels_and_tires --><!-- BEGIN TEMPLATE: adv_portal_ebay_search --> <!-- eBaySearchRemoved --> <!-- END TEMPLATE: adv_portal_ebay_search --><!-- BEGIN TEMPLATE: adv_portal_module_wrapper --> <section> <table align="center" border="0" cellpadding="0" cellspacing="0" class="cmps-table" width="100%"> <thead> <tr> <td colspan="0"> <h2 class="title">Recent Discussions</h2></td> </tr> </thead> <tbody id="collapseobj_module_33" style=""> <!-- BEGIN TEMPLATE: adv_portal_recthreads_lean --> <tr> <td class="alt1 columns columns-comments"> <div class="picture main-column-picture"> <div style="padding-top:0px"><span class="sprite count">25k</span></div> </div> <div class="main-column-text-wrapper"> <div class="text main-column-text"> <div class="smallfont"> <span style="float:right"> <a href="https://www.powerstroke.org/forum/6-0l-performance-parts-discussion/246552-nuc-oil-bypass-filtration-kit-install-pics-4.html#" onclick="vba_attach_win(207523); return false"><span class="sprite inlineimg paperclip">65535 Attachment(s)</span></a> </span> <a href="https://www.powerstroke.org/forum/99-03-7-3l-general-discussion/207523-what-did-you-do-your.html" title="Well I know the 6.4 guys have a thread like this but I've never seen one for us 7.3 guys, so I figured I would start one. So like the title says what did you do to you 7.3 today? Maintenance, performance, washed the windows, whatever. I tested the coolant and found that it was in need of a..." itemprop="headline">What did you do to your...</a> <div> <span itemprop="dateModified">Today <span class="time">10:52 AM</span></span> by <a rel="nofollow" href="https://www.powerstroke.org/forum/members/542482-guitarnut.html" itemprop="contributor">guitarnut</a> <meta itemprop="author" content="late_99_PSD"> <meta itemprop="dateCreated" content="06-13-2011 08:11 PM"> </div> </div> </div> </div> </td> </tr> <!-- END TEMPLATE: adv_portal_recthreads_lean --><!-- BEGIN TEMPLATE: adv_portal_recthreads_lean --> <tr> <td class="alt2 columns columns-comments"> <div class="picture main-column-picture"> <div style="padding-top:0px"><span class="sprite count">1k</span></div> </div> <div class="main-column-text-wrapper"> <div class="text main-column-text"> <div class="smallfont"> <span style="float:right"> <a href="https://www.powerstroke.org/forum/6-0l-performance-parts-discussion/246552-nuc-oil-bypass-filtration-kit-install-pics-4.html#" onclick="vba_attach_win(1194025); return false"><span class="sprite inlineimg paperclip">319 Attachment(s)</span></a> </span> <a href="https://www.powerstroke.org/forum/firearms-discussion/1194025-all-things-pew-pew.html" title="I know this is way late.. but @jmo .. herr is ffl listing site.... just found a guy local to me, cost 25 for transfer.. 25 for dros.. and paid only a little for a stripped lower. http://www.gunbroker.com/ffl/SearchForFFL.aspx..." itemprop="headline">All things PEW PEW...</a> <div> <span itemprop="dateModified">Today <span class="time">10:49 AM</span></span> by <a rel="nofollow" href="https://www.powerstroke.org/forum/members/457945-bridgermt.html" itemprop="contributor">BridgerMT</a> <meta itemprop="author" content="onealmx11"> <meta itemprop="dateCreated" content="12-05-2016 08:50 PM"> </div> </div> </div> </div> </td> </tr> <!-- END TEMPLATE: adv_portal_recthreads_lean --><!-- BEGIN TEMPLATE: adv_portal_recthreads_lean --> <tr> <td class="alt1 columns columns-comments"> <div class="picture main-column-picture"> <div style="padding-top:0px"><span class="sprite count">14</span></div> </div> <div class="main-column-text-wrapper"> <div class="text main-column-text"> <div class="smallfont"> <a href="https://www.powerstroke.org/forum/99-03-7-3l-general-discussion/1372391-thinking-about-new-brake.html" title="I was thinking about some new front brake pads and rotors and saw these on amazon and did not know how they rate. i will be towing a 32 ft fifth wheel. The truck is a 2000 f250 powerstroke. These are the deal. Power Stop K1905 Front Brake Kit with Drilled/Slotted Brake Rotors and Z23 Evolution..." itemprop="headline">Thinking about new brake...</a> <div> <span itemprop="dateModified">Today <span class="time">10:46 AM</span></span> by <a rel="nofollow" href="https://www.powerstroke.org/forum/members/663699-airborneduckhunter.html" itemprop="contributor">airborneduckhunter</a> <meta itemprop="author" content="stroupdr"> <meta itemprop="dateCreated" content="12-03-2019 05:39 PM"> </div> </div> </div> </div> </td> </tr> <!-- END TEMPLATE: adv_portal_recthreads_lean --><!-- BEGIN TEMPLATE: adv_portal_recthreads_lean --> <tr> <td class="alt2 columns columns-comments"> <div class="picture main-column-picture"> <div style="padding-top:0px"><span class="sprite count">4</span></div> </div> <div class="main-column-text-wrapper"> <div class="text main-column-text"> <div class="smallfont"> <span style="float:right"> <a href="https://www.powerstroke.org/forum/6-0l-performance-parts-discussion/246552-nuc-oil-bypass-filtration-kit-install-pics-4.html#" onclick="vba_attach_win(1374151); return false"><span class="sprite inlineimg paperclip">1 Attachment(s)</span></a> </span> <a href="https://www.powerstroke.org/forum/general-6-7-discussion-2017-2019/1374151-fyi-recalls-i.html" title="Brought my 2017 to Ford yesterday for 3 recalls: 1) Engine block heater replacement (Field Service Action Number:19G01) 2) Unintended tailgate opening (Ford Recall number: 19S48) 3) Carpet shielding and insulation rework (Field Service Action Number:19S52) #2 is new (December 2019). I..." itemprop="headline">FYI - Recalls (that I...</a> <div> <span itemprop="dateModified">Today <span class="time">10:33 AM</span></span> by <a rel="nofollow" href="https://www.powerstroke.org/forum/members/457945-bridgermt.html" itemprop="contributor">BridgerMT</a> <meta itemprop="author" content="jd4010"> <meta itemprop="dateCreated" content="Today 05:20 AM"> </div> </div> </div> </div> </td> </tr> <!-- END TEMPLATE: adv_portal_recthreads_lean --><!-- BEGIN TEMPLATE: adv_portal_recthreads_lean --> <tr> <td class="alt1 columns columns-comments"> <div class="picture main-column-picture"> <div style="padding-top:0px"><span class="sprite count">14</span></div> </div> <div class="main-column-text-wrapper"> <div class="text main-column-text"> <div class="smallfont"> <span style="float:right"> <a href="https://www.powerstroke.org/forum/6-0l-performance-parts-discussion/246552-nuc-oil-bypass-filtration-kit-install-pics-4.html#" onclick="vba_attach_win(1374155); return false"><span class="sprite inlineimg paperclip">6 Attachment(s)</span></a> </span> <a href="https://www.powerstroke.org/forum/6-0l-electronics-discussion/1374155-2004-excursion-horn-stuck.html" title="Hi all. First post and thanks in advance for your help. I have been working on issues with an Excursion that my daughter acquired and when it came time to inspect the vehicle I realized the horn did not work. I took the wheel well off to access the horns and discovered they did not work, so..." itemprop="headline">2004 Excursion horn stuck</a> <div> <span itemprop="dateModified">Today <span class="time">10:22 AM</span></span> by <a rel="nofollow" href="https://www.powerstroke.org/forum/members/677181-ncangler.html" itemprop="contributor">NCangler</a> <meta itemprop="author" content="NCangler"> <meta itemprop="dateCreated" content="Today 06:05 AM"> </div> </div> </div> </div> </td> </tr> <!-- END TEMPLATE: adv_portal_recthreads_lean --><!-- BEGIN TEMPLATE: adv_portal_recthreads_lean --> <tr> <td class="alt2 columns columns-comments"> <div class="picture main-column-picture"> <div style="padding-top:0px"><span class="sprite count">24</span></div> </div> <div class="main-column-text-wrapper"> <div class="text main-column-text"> <div class="smallfont"> <span style="float:right"> <a href="https://www.powerstroke.org/forum/6-0l-performance-parts-discussion/246552-nuc-oil-bypass-filtration-kit-install-pics-4.html#" onclick="vba_attach_win(1374003); return false"><span class="sprite inlineimg paperclip">1 Attachment(s)</span></a> </span> <a href="https://www.powerstroke.org/forum/general-6-0l-discussion/1374003-runaway-due-neglect.html" title="Recently I experienced a runaway. I was driving home when I lost all throttle control, I pulled over and turned the truck off. once I turned it off it begun to rev out of control. It was blowing straight white smoke, then a white and black smoke(or it appeared black it was late in the afternoon)...." itemprop="headline">Runaway, due to neglect</a> <div> <span itemprop="dateModified">Today <span class="time">10:16 AM</span></span> by <a rel="nofollow" href="https://www.powerstroke.org/forum/members/28299-toomanytoys.html" itemprop="contributor">TooManyToys</a> <meta itemprop="author" content="p_stpierre"> <meta itemprop="dateCreated" content="01-12-2020 10:32 PM"> </div> </div> </div> </div> </td> </tr> <!-- END TEMPLATE: adv_portal_recthreads_lean --><!-- BEGIN TEMPLATE: adv_portal_recthreads_lean --> <tr> <td class="alt1 columns columns-comments"> <div class="picture main-column-picture"> <div style="padding-top:0px"><span class="sprite count">2</span></div> </div> <div class="main-column-text-wrapper"> <div class="text main-column-text"> <div class="smallfont"> <a href="https://www.powerstroke.org/forum/94-98-7-3l-general-powerstroke-discussion/1373975-project-plans.html" title="I wanted to run this down to everyone and see if there’s any interest in me documenting part/all of the work I plan on doing on my 1995 F350 CCLB 7.3 4X4 in the coming weeks. Please comment if there is something you want to see in detail. I’m not a mechanic, I’m borrowing someone’s shop, I’ll have..." itemprop="headline">Project plans</a> <div> <span itemprop="dateModified">Today <span class="time">09:31 AM</span></span> by <a rel="nofollow" href="https://www.powerstroke.org/forum/members/121566-patrick-feeley.html" itemprop="contributor">Patrick Feeley</a> <meta itemprop="author" content="AA Ron"> <meta itemprop="dateCreated" content="01-12-2020 10:45 AM"> </div> </div> </div> </div> </td> </tr> <!-- END TEMPLATE: adv_portal_recthreads_lean --><!-- BEGIN TEMPLATE: adv_portal_recthreads_lean --> <tr> <td class="alt2 columns columns-comments"> <div class="picture main-column-picture"> <div style="padding-top:0px"><span class="sprite count">7</span></div> </div> <div class="main-column-text-wrapper"> <div class="text main-column-text"> <div class="smallfont"> <a href="https://www.powerstroke.org/forum/general-6-0l-discussion/1374149-p0299-turbo-underboost.html" title="Hey all, itís been a long time since Iíve been on the forum, and true to firm I need some help. I have a code with no symptoms that I need to get to the bottom of. A little history first: I had an open glow plug circuit in cylinder 6 throwing a code, so two days ago I replaced all my glow..." itemprop="headline">P0299 turbo underboost</a> <div> <span itemprop="dateModified">Today <span class="time">09:10 AM</span></span> by <a rel="nofollow" href="https://www.powerstroke.org/forum/members/577105-voodooridr.html" itemprop="contributor">voodooridr</a> <meta itemprop="author" content="fuzzman"> <meta itemprop="dateCreated" content="Yesterday 07:12 PM"> </div> </div> </div> </div> </td> </tr> <!-- END TEMPLATE: adv_portal_recthreads_lean --><!-- BEGIN TEMPLATE: adv_portal_recthreads_lean --> <tr> <td class="alt1 columns columns-comments"> <div class="picture main-column-picture"> <div style="padding-top:0px"><span class="sprite count">2</span></div> </div> <div class="main-column-text-wrapper"> <div class="text main-column-text"> <div class="smallfont"> <a href="https://www.powerstroke.org/forum/general-3-0l-discussion/1374141-oil-change-3220-a.html" title="I bought a new 2018 F150 3.0 Diesel on 5-30-2019. It had 630 miles on the odometer. On 9-20-2019, at 3200 miles the "Intelligent Oil Life Monitor" (P536 of the Owners Manual ) indicated that the oil needed changed. I took it to a local Ford Dealer for an oil change. When I got home, I studied..." itemprop="headline">Oil change at 3220 and...</a> <div> <span itemprop="dateModified">Today <span class="time">08:40 AM</span></span> by <a rel="nofollow" href="https://www.powerstroke.org/forum/members/142755-justinooo9.html" itemprop="contributor">JustinOOO9</a> <meta itemprop="author" content="tmikea"> <meta itemprop="dateCreated" content="Yesterday 04:26 PM"> </div> </div> </div> </div> </td> </tr> <!-- END TEMPLATE: adv_portal_recthreads_lean --><!-- BEGIN TEMPLATE: adv_portal_recthreads_lean --> <tr> <td class="alt2 columns columns-comments"> <div class="picture main-column-picture"> <div style="padding-top:0px"><span class="sprite count">1</span></div> </div> <div class="main-column-text-wrapper"> <div class="text main-column-text"> <div class="smallfont"> <span style="float:right"> <a href="https://www.powerstroke.org/forum/6-0l-performance-parts-discussion/246552-nuc-oil-bypass-filtration-kit-install-pics-4.html#" onclick="vba_attach_win(1374161); return false"><span class="sprite inlineimg paperclip">3 Attachment(s)</span></a> </span> <a href="https://www.powerstroke.org/forum/99-03-7-3l-performance-parts/1374161-fuel-fittings.html" title="So looking at all the upgrades before making my engine swap. The fuel fittings at the heads that the fuel lines connect to. They appear to be a combination check/screen valve..?? Are the checks needed? Also odd the screens are that large , after, the fuel filter. Aftermarket fittings are just..." itemprop="headline">fuel fittings</a> <div> <span itemprop="dateModified">Today <span class="time">08:36 AM</span></span> by <a rel="nofollow" href="https://www.powerstroke.org/forum/members/142755-justinooo9.html" itemprop="contributor">JustinOOO9</a> <meta itemprop="author" content="Strkrmule"> <meta itemprop="dateCreated" content="Today 07:20 AM"> </div> </div> </div> </div> </td> </tr> <!-- END TEMPLATE: adv_portal_recthreads_lean --> </tbody> </table> </section> <!-- END TEMPLATE: adv_portal_module_wrapper --><!-- BEGIN TEMPLATE: adv_portal_sponsors2 --> <section class="text_wrapper ad box-ad"> <div class="ams-vb-hook ams-300x250_TopLeft" style="width:100%; text-align:center;"><div id="Powerstroke_org_300x250_TopLeft_AUTO_Forum" style="width:auto; height:auto;"> <script type="text/javascript"> googletag.cmd.push(function() { deployads.push(function() { deployads.gpt.display("Powerstroke_org_300x250_TopLeft_AUTO_Forum"); }); }); </script> </div></div> </section><!-- AMS ADV PORTAL SPONORS2 --> <!-- END TEMPLATE: adv_portal_sponsors2 --><!-- BEGIN TEMPLATE: adv_portal_facebook_like_box --> <section id="facebook-like" class="section"> <div align="center"> <div style="text-align:center;" class="fb-page" data-href="https://www.facebook.com/PowerStrokeorg" data-width="300" data-hide-cover="false" data-show-facepile="false" data-show-posts="false"> </div> </div> </section> <!-- END TEMPLATE: adv_portal_facebook_like_box --> </div> </aside> <div class="clear"><!-- --> </div> </div> <!-- end wrapper --> <!-- BEGIN TEMPLATE: footer --> <script type="text/javascript">ame_toggle_view({other : 'true',post : 'true',blog : 'true',group : 'true',vm : 'true',sig : 'true'});</script><!-- BEGIN TEMPLATE: ad_footer_start --> <div class="Leaderboard"> <div class="ams-vb-hook ams-728x90_Bottom" style="width:100%; text-align:center;"><div id="Powerstroke_org_728x90_Bottom_AUTO_Forum" style="width:auto; height:auto;"> <script type="text/javascript"> googletag.cmd.push(function() { deployads.push(function() { deployads.gpt.display("Powerstroke_org_728x90_Bottom_AUTO_Forum"); }); }); </script> </div></div> </div> <!-- END TEMPLATE: ad_footer_start --> <div id="footer" class="footer"> <form action="https://www.powerstroke.org/forum/" method="get" style="clear:left"> <table cellpadding="0" cellspacing="0" border="0" width="100%" class="page" align="center"> <tr> <td class="tfoot" valign="top"> <select name="styleid" onchange="switch_id(this, 'style')"> <optgroup label="Quick Style Chooser"> <!-- BEGIN TEMPLATE: option --> <option value="49" class="" selected="selected">-- Powerstroke.org (Full)</option> <!-- END TEMPLATE: option --><!-- BEGIN TEMPLATE: option --> <option value="57" class="" >-- Powerstroke.org (Classic I)</option> <!-- END TEMPLATE: option --><!-- BEGIN TEMPLATE: option --> <option value="65" class="" >-- Powerstroke.org (Classic II)</option> <!-- END TEMPLATE: option --><!-- BEGIN TEMPLATE: option --> <option value="73" class="" >-- Powerstroke.org (Mobile)</option> <!-- END TEMPLATE: option --> </optgroup> </select> </td> <td class="tfoot subnav-bottom" align="right" width="100%"> <div class="smallfont"> <strong> <a href="/forum/sendmessage.php" rel="nofollow" accesskey="9">Contact Us</a> |<a href="/forum/advertise.php" rel="nofollow" accesskey="9">Advertise</a> | <a href="https://www.powerstroke.org">Ford Powerstroke Forum</a> | <a href="https://www.powerstroke.org/forum/archive/index.php/">Archive</a> | <a href="https://www.powerstroke.org/forum/6-0l-performance-parts-discussion/246552-nuc-oil-bypass-filtration-kit-install-pics-4.html#top" onclick="self.scrollTo(0, 0); return false;">Top</a> </strong> </div> </td> </tr> </table> <br /> <div align="center"> <a rel="nofollow" href="http://www.autoguide.com/"><img class="photo" src="/forum/images/Powerstroke_org_2015/misc/spacer.gif" data-original="/forum/images/Powerstroke_org_2015/misc/footer-logo.png" border="0" height="60" width="250" alt="AutoGuide.com Group" /></a> </div> <div align="center"> <div class="smallfont" align="center"> <!-- Do not remove cronimage or your scheduled tasks will cease to function --> <!-- Do not remove cronimage or your scheduled tasks will cease to function --> </div> </form> <!-- BEGIN TEMPLATE: ad_footer_end --> <!-- END TEMPLATE: ad_footer_end --> </div> <!-- end footer --> </div></div></div><!-- end spacer_open --> </div> <!-- end container --> <script type="text/javascript"> <!-- // Main vBulletin Javascript Initialization vBulletin_init(); //--> </script> <script> if (typeof(jQuery) == 'undefined'){ document.write('<scr' + 'ipt type="text/javascript" src=" https://ajax.googleapis.com/ajax/libs/jquery/1.11.0/jquery.min.js"></scr' + 'ipt>'); } </script> <script src="https://www.powerstroke.org/forum/clientscript/vs_scripts/sticky.js"></script> <script> var $ = jQuery.noConflict(); jQuery(document).ready(function($) { $("#main-content, .sidebar").addClass('theiaStickySidebar'); $("#main-content_wrapper, #sidebar").theiaStickySidebar({ // Settings additionalMarginTop: 30 }); }); </script> <script> (function ($, window) { $("#qr_submit").click(function(e){ e.stopPropagation(); $("#qrform").trigger('submit'); }); })(jQuery, window); </script> <!-- Quick search form touchscreen fix --> <style>.stayOpened{display:block !important;}</style> <script> (function ($, window) { if ('ontouchstart' in document.documentElement){ $('#navbar_search_menu').click(function(event) { $('#navbar_search_menu').addClass("stayOpened"); }); $('#navbar_search').click(function(event) { if ($('#navbar_search_menu').hasClass("stayOpened")) $('#navbar_search_menu').removeClass("stayOpened"); }); } })(jQuery, window); </script> <!-- End Quick search form touchscreen fix--> <script> (function ($, window) { var currencySelects=$("select[name*='currency']"); if (currencySelects.length){ currencySelects.find("option:last-child").attr('selected', 'selected'); } })(jQuery, window); </script> <script src="https://www.powerstroke.org/forum/clientscript/vs_scripts/scripts-bottom.js"></script> <script src="http://www.google.com/cse/brand?form=&lang=en"></script> <script> //setTimeout(ghostwriter.loadscripts, 250); </script> <div id="update-browser">For the best viewing experience please update your browser to <a rel="nofollow" href="http://www.google.com/chrome" target="blank">Google Chrome</a></div> <!-- Toyota Inmarket Script--> <script type="text/javascript" src="//static.verticalscope.com/js/iframe-messenger/toyota-inmarketv3.js"></script> <!-- /Toyota InMarket Script--><!-- D_T_O --><!-- D_T_O --><!-- vBadvanced 1-6-4-6-9-8 --> <!-- END TEMPLATE: footer --> <!-- Adblock Check --> <div class="afs_ads"> </div> <script> (function() { var adBlockDetector = function() { setTimeout(function() { if (!document.getElementsByClassName) return; var ads = document.getElementsByClassName("afs_ads"); ad = ads[ads.length - 1]; if (!ad || ad.innerHTML.length == 0 || ad.clientHeight === 0) { _gaq.push(["_trackEvent", "Adblock", "Blocked", "true",,true]); } else { ad.style.display = "none"; _gaq.push(["_trackEvent", "Adblock", "Unblocked", "false",,true]); } }, 500); } /* Attach a listener for page load */ if (window.addEventListener) { window.addEventListener("load", adBlockDetector, false); } else { window.attachEvent("onload", adBlockDetector); //IE } })(); </script> <!-- /Adblock Check--> <!-- TOS DMCA --> <style> .tos_dmca_policy { text-align: center; } .tos_dmca_policy table { display: inline-table; width: auto; } .tos_dmca_policy table { display: inline-table; width: auto; margin: 0 10px; } </style> <div class="tfoot tos_dmca_policy"> <table cellpadding="3" cellspacing="0" border="0" class="page" align="center" width="100%"><tr><td class="tfoot" align="center" width="100%"><div class="smallfont"><strong><a rel="nofollow" href="http://www.verticalscope.com/aboutus/tos.php?site=powerstroke.org">Terms of Use</a></strong></div></td></tr></table> <!-- DMCA --><table cellpadding="3" cellspacing="0" border="0" class="page" align="center" width="100%"><tr><td class="tfoot" align="center" width="100%"><div class="smallfont"><strong><a rel="nofollow" href="http://www.verticalscope.com/copyright.html?site=powerstroke.org">Copyright</a></strong></div></td></tr></table><!-- /DMCA --> <!-- Privacy Policy --><table cellpadding="3" cellspacing="0" border="0" class="page" align="center" width="100%"><tr><td class="tfoot" align="center" width="100%"><div class="smallfont"><strong><a rel="nofollow" href="https://www.verticalscope.com/site-privacy-policy/index.php?site=powerstroke.org">Privacy Policy</a></strong></div></td></tr></table><!-- /Privacy Policy --> </div> <!-- /TOS DMCA --> <img src="http://h.nexac.com/e/a-2107/s-4400/c-637/g-2095.xgi?pkey=bijo15bijox40&chpcm=Ford&chpsg=&chpcr=&chpck=&rand=&chpth=" width="1" height="1" border="0"> <!-- Gumgum --><script>ggpid=2274;</script><script src="https://js.gumgum.com/services.js"></script><!-- /Gumgum --> <!-- Lotame --> <script src="//tags.crwdcntrl.net/c/8060/cc_af.js"></script> <!-- /Lotame --> <!-- BEGIN TEMPLATE: dbtech_vbsecurity_passwordcheck --> <script type="text/javascript"> <!-- var vBSecurity = { imageBasePath : 'https://www.powerstroke.org/forum/dbtech/vbsecurity_pro/images/', rules : { passwordLength : {phrase : 'Must be at least 10 characters', params : {passwordLength : 10 }},containsLowerCase : {phrase : 'Must contain lower-case characters'},containsUpperCase : {phrase : 'Must contain upper-case characters'},containsNumbers : {phrase : 'Must contain numbers'},containsSymbols : {phrase : 'Must contain symbols'} }, vbversion : 3 // DO NOT CHANGE THIS OR YOU WILL BREAK EVERYTHING! }; // --> </script> <script type="text/javascript"> window.jQuery || document.write('<script src="https://ajax.googleapis.com/ajax/libs/jquery/1.7.2/jquery.min.js">\x3C/script>'); </script> <!-- END TEMPLATE: dbtech_vbsecurity_passwordcheck --><link rel="stylesheet" href="https://www.powerstroke.org/forum/clientscript/vs_scripts/vs_registration/registration_v9.css?cb=9" type="text/css"> <link href="//fonts.googleapis.com/css?family=Roboto:400,400i,500,700,900" rel="stylesheet"> <script type="text/javascript" src="https://www.powerstroke.org/forum/clientscript/vbulletin_md5.js?v=388"></script> <script type="text/javascript"> var BBURL = "https://www.powerstroke.org/forum"; var forumHome = "https://www.powerstroke.org/forum/index.php"; var cookiePrefix = "bb"; var registerFile = "register.php"; </script> <script type="text/javascript" src="https://www.powerstroke.org/forum/clientscript/vs_scripts/vs_registration/registration_v8.js?cb=9"></script><script type="text/javascript"> var vs_api = vsapi.api(); var vs_o = vs_api.vbulletinInit(0, [3004949,3005292,3006544,3006560,3019883,3019892,3026115,3026125,4164530,4174370]); vs_o.addPostElement(document.getElementById("post3004949"), document.getElementById("post_message_3004949"), 3004949, 246552, 9, 114843, 0);vs_o.addPostElement(document.getElementById("post3005292"), document.getElementById("post_message_3005292"), 3005292, 246552, 9, 26502, 1);vs_o.addPostElement(document.getElementById("post3006544"), document.getElementById("post_message_3006544"), 3006544, 246552, 9, 114843, 2);vs_o.addPostElement(document.getElementById("post3006560"), document.getElementById("post_message_3006560"), 3006560, 246552, 9, 26502, 3);vs_o.addPostElement(document.getElementById("post3019883"), document.getElementById("post_message_3019883"), 3019883, 246552, 9, 130994, 4);vs_o.addPostElement(document.getElementById("post3019892"), document.getElementById("post_message_3019892"), 3019892, 246552, 9, 114843, 5);vs_o.addPostElement(document.getElementById("post3026115"), document.getElementById("post_message_3026115"), 3026115, 246552, 9, 97401, 6);vs_o.addPostElement(document.getElementById("post3026125"), document.getElementById("post_message_3026125"), 3026125, 246552, 9, 112378, 7);vs_o.addPostElement(document.getElementById("post4164530"), document.getElementById("post_message_4164530"), 4164530, 246552, 9, 144729, 8);vs_o.addPostElement(document.getElementById("post4174370"), document.getElementById("post_message_4174370"), 4174370, 246552, 9, 122633, 9); </script><script src='http://m.viglink.com/271-atma_linker.js' type='text/javascript'></script> <script type='text/javascript'> try{ var atma_linker = _atma_linker(271); } catch(err) {} </script> <br /><div style="z-index:3" class="smallfont" align="center"></div><!-- VigLink vBulletin Plugin v2.0.7.0002: http://viglink.com --> <script type="text/javascript"> var viglink_version = '2.0.7.0002'; var vglnk = {key: 'd1aa4f3f5a14e78235714f17d6ab0a00'}; (function(d, t) { var s = d.createElement(t); s.type = 'text/javascript'; s.async = true; s.src = '//cdn.viglink.com/api/vglnk.js'; var r = d.getElementsByTagName(t)[0]; r.parentNode.insertBefore(s, r); }(document, 'script')); </script> <!-- end VigLink --> <!-- Taboola Footer --> <script type="text/javascript"> window._taboola = window._taboola || []; _taboola.push({flush: true}); </script> <!-- /Taboola Footer --> <script type="text/javascript"> //<![CDATA[ window.orig_onload = window.onload; window.onload = function() { var cpost=document.location.hash.substring(1);var cpost2='';if(cpost && (typeof fetch_object != 'undefined')){ var ispost=cpost.substring(0,4)=='post';if(ispost)cpost2='post_'+cpost.substring(4);if((cobj = fetch_object(cpost))||(cobj = fetch_object(cpost2))){cobj.scrollIntoView(true);}else if(ispost){cpostno = cpost.substring(4,cpost.length);if(parseInt(cpostno)>0){location.replace('https://www.powerstroke.org/forum/showthread.php?p='+cpostno);};} } if(typeof window.orig_onload == "function") window.orig_onload(); } //]]> </script> <script> var renderVSAMSGTSearch = function() { for(var a = 0; a < vsamsgtsearches.length; a++) google.search.cse.element.render({div: vsamsgtsearches[a], tag: 'searchbox-only'}) }, startVSAMSGTSearch = function() { 'complete' == document.readyState ? renderVSAMSGTSearch() : google.setOnLoadCallback(renderVSAMSGTSearch) }; window.__gcse = { parsetags: 'explicit', callback: startVSAMSGTSearch}, function() { var cx = 'partner-pub-7865546952023728:uex3dp-be86'; var gcse = document.createElement('script'); gcse.type = 'text/javascript'; gcse.async = true; gcse.src = 'https://cse.google.com/cse.js?cx=' + cx; var s = document.getElementsByTagName('script')[0]; s.parentNode.insertBefore(gcse, s); }(); </script></body> </html>
