How To Get More Than 8 To 7 Quarts - Page 2 - Ford Powerstroke Diesel Forum
 4Likes
post #11 of 52 Old 03-04-2011, 10:51 PM
Thanks for the write up. I was wondering if the torque converter has a drain plug? Also, where is the best place to buy tranny fluid?
6.0ops is offline
post #12 of 52 Old 03-05-2011, 07:49 AM Thread Starter
smokersteve's Avatar
Quoted: 21 Post(s)
Thanks! There is no plug in the TQ.
Call the dealerships arround you and get some prices.
(LV) This was $3.92 but was recently changed to $4.07. I am glad I got the fluid when I did...
Ryder
(SP) same here, this was $4.69, now $5.39.
Ryder
$5.49
Diesel Transmission Fluids - [XT-6-QSP] Motorcraft MERCON® SP Automatic Transmission Fluid - Quart - Diesel Filters,Additives,brake rotors, and brake pads for Chevy, Dodge and Ford Diesel Trucks
Motorcraft TorqShift fluid XT-6-QSP Mercon SP
13Q Trans Fluid Flush
FICM Testing Videos
smokersteve is offline
post #13 of 52 Old 03-23-2011, 12:31 PM
Very nice, looking forward to doing this!
dava92 is offline
post #14 of 52 Old 04-06-2011, 01:28 PM
CaptnKirk's Avatar
Originally Posted by PGreenSVT View Post
I have seen a procedure for doing this yourself that involved removing the lines from the external filters and using hose to extend them temporarily. You need 2 buckets, one marked in qt graduations that is at least the capacity of the system. You place the hose from the filter in line into this bucket to collect the used fluid. The hose on the output line that goes back into the transmission is put into the second bucket which you put the new fluid in. Then you start the truck and let the trans suck the new fluid up while it pumps the old stuff out.
Now because of the thermostat on the cooler line you need to do this while the trans is at operating temp. So get all you gear lined up and ready to go, get the truck up to temp. and then work quickly and be careful with the hot lines.
Just because I'm a lazy sob and this is a just one of those jobs I choose not to do mysyself, I'll just take my fluids to the dealer and let them reverse flush it it.
A quick question - I had the dealer do mine but was not smart enough to ask if they use synthetic. Is that what the Ford spec calls for that the dealer would/should have used?
Kirk
CaptnKirk is offline
post #15 of 52 Old 05-02-2011, 06:21 PM
police251's Avatar
nice post thanks.....
police251 is offline
post #16 of 52 Old 05-02-2011, 06:31 PM
What are you guys using for trans fluid? What ford recomenneds or other?
bones427 is offline
post #17 of 52 Old 05-02-2011, 07:03 PM Thread Starter
Quoted: 21 Post(s)
Mercon sp or mercon lv for the trans. A very very small % would say other.
FICM Testing Videos
post #18 of 52 Old 05-08-2011, 01:49 PM
dnf12908's Avatar
Quoted: 47 Post(s)
Another method that Amsoil recommends is; after draining what you can, removing the pan, changing the filters, reinstalling the pan, replacing with new fliuid the amount that came out, then - disconnecting a cooling line into a bucket, with the engine running have someone pour new fluid into the dipstick tube at the same rate that it is draining from the cooler line until the fluid changes color or until the known capacity is reached.
Has anyone done this? I'm going to change my fluid soon. Going with Amsoil synthetic SP equivalent.
Darrell
'03 F-350 6.0L C/C SB FX4 SRW
SCT X3 w/tunes by MKM
MBRP exhaust-turbo back
EGR delete
ARP studs
OEM gaskets
ELC coolant & filter
MTW Stage 1 turbo w/billet wheel
FPR (blue spring)
'04 upgraded front cover
BPD fan clutch adapter/w 7.3 fan
stator delete
All-aluminum intercooler(upgraded OEM unit)
Amsoil bypass oil filter
Edge Insight monitor
Harley headlights w/BPS Lighting 5000k HID's
2008 rear diff. cover
EnviroSave powertrain treatment,
dnf12908 is offline
post #19 of 52 Old 05-18-2011, 11:57 PM
TexasKingRanch's Avatar
I was about to post thinking you had made a major mistake using LV, but I'm impressed with the spec sheet. I hadn't educated myself on the new LV fluid yet, and SP being a high quality fluid I was a bit skeptical!
The Ford Motorcraft Mercon LV actually has a higher Viscosity Index (VI) than Amsoil ATL. Hard to believe. LV 155, Amsoil 152.
The viscosity at 40C and 100C is almost IDENTICAL as well. GOOD STUFF.
Needless to say I will be using Mercon LV when I change the fluid in my KingRanch's Torqshift. If it is still $4/quart that is a real affordable price, too!
It is AT LEAST a synthetic blend of GROUP III and PAO.
TexasKingRanch is offline
post #20 of 52 Old 05-19-2011, 07:55 AM Thread Starter
Quoted: 21 Post(s)
Interesting, thanks for the info!
FICM Testing Videos
