Early Lockup - How's it work? - Ford Powerstroke Diesel Forum
post #1 of 4 Old 01-17-2020, 07:23 PM Thread Starter
cjchico4's Avatar
Quoted: 13 Post(s)
Question Early Lockup - How's it work?
I recently got an early lockup tune. I have an edge CTS2 and it only shows locked converter in 5th and 6th like this tune has normally been. It feels like it doesn't lock until 5th either. It shifts 1-2-3-5-5L-6L. I have tested throttle position and Tow Haul too, they don't make a difference. Any ideas? I was thinking maybe the Edge isn't showing it locked in 3rd, but it should to my knowledge.
cjchico4 is offline
post #2 of 4 Old 01-17-2020, 07:30 PM
comvet42's Avatar
Quoted: 22 Post(s)
Who did you get tunes from?
Sent from my iPhone using Tapatalk
2004 F250 King Ranch
ARP Headstuds
HD Fan Clutch
BPD Egr
BPD Heavy Duty oil cooler
Blue Spring
4" MBRP Turbo Back Exhaust
Stock Everywhere Else
comvet42 is offline
post #3 of 4 Old 01-17-2020, 09:48 PM Thread Starter
cjchico4's Avatar
Quoted: 13 Post(s)
Gearhead's SRL Extreme. I emailed them about it, waiting for a response. I've been running that and SPD a lot.
2007 F-250 CCSB 4WD 6.0 - Studded, Deleted, Coolant Filter, Sinister Piping, Blue Spring, 6" Zone Lift, 20x9 RBP's on 37" Toyo M/T's, KC stage 2 turbo, 5" Straight Pipe, CTS2, SPD, Gearhead, Warren, and Looney tunes, PHP Hercules FICM Tune, 4.56 Gears, Mag Hytec Trans Pan, Airdog Raptor Lift Pump, ...whatever else I forgot.
cjchico4 is offline
post #4 of 4 Old 01-19-2020, 08:10 PM
Quoted: 39 Post(s)
That’s how my 6.0 tunes have been in all three trucks. It’s early compared to the factory. I think it’s perfect for the 6.0s
06 King Ranch
Fass 200, Custom fuel lines, 225/100s, Thumper stage 2 hpop, WPE stage 3 intake, Mishimoto radiator, Flex a lite fans, BPD water pump, MPD oil cooler relocate kit, Intercooler pipes, Compounds built by me, etc etc etc
05 Eddie Bauer
Resealed entire motor @ 170k miles, new lifters, 6.4 push rods, studs, rebuilt the turbo, IPR egr delete, new injectors, new heads, new ficm board, coolant filter, intercooler tubes, regulated return, bunch of other new parts. Factory exhaust, cat gutted(wife's rig). Livewire with gearhead tunes. Should go a while reliably for her!
03 LB7 duramax the "daily/tow pig"
Lbz cp3, s475/stock twin kit, built trans, steel driveshft, amsoil bypass, secondary oil cooler built by me, fass, traction bars, trans cooler upgrade, dual alts, straight center link + tie rod sleeves, efi live, transfer flow/tool box tank, 5er hitch, other small upgrades.. and most importantly, STOCK HEADBOLTS! Just rolled 200k miles, twins installed @ 165k, daily driven on a "550 tune" tows 18k on a "475" tune.
Nickjames525 is offline
