190/30 Injectors Supporting Mods and Tranny Questions - Ford Powerstroke Diesel Forum
post #1 of 5 Old 01-17-2020, 01:45 PM Thread Starter
cjchico4's Avatar
Quoted: 13 Post(s)
I currently have a KC stage 2 turbo, PHP FICM tuner and airdog lift pump (just the universal pump, no filters). I am planning on getting 190/30 warren injectors by summer. I know I am going to need a regulated return, but what else? I don't have the money to buy everything at once so I am going to do one thing at a time.
Where should I start? I know I'm going to need trans parts eventually, but what exactly? Warren told me the competition kit should be fine for 190/30's. At that point I'd be worried about the converter.
I was thinking of getting the regulated return, then injectors, then a mild fuel tune until I have money for the transmission parts.
Any help is greatly appreciated, thanks!
2007 F-250 CCSB 4WD 6.0 - Studded, Deleted, Coolant Filter, Sinister Piping, Blue Spring, 6" Zone Lift, 20x9 RBP's on 37" Toyo M/T's, KC stage 2 turbo, 5" Straight Pipe, CTS2, SPD, Gearhead, Warren, and Looney tunes, PHP Hercules FICM Tune, 4.56 Gears, Mag Hytec Trans Pan, Airdog Raptor Lift Pump, ...whatever else I forgot.
cjchico4 is offline
post #2 of 5 Old 01-17-2020, 02:24 PM
letsmow10's Avatar
Quoted: 124 Post(s)
Garage
You didn't mention EGT monitor so I will add that and tunes as a must even before you think about the transmission. Otherwise, as long as your HPOP is in good shape you should be fine with what you have stated already. Im running 190/30s, KC Stage 2, ODawg intake, colt stage 2 cam, adrenaline HPOP, Marty's diesel regulated return and never stranded fuel system, 4" open exhaust, and TSD tunes. I haven't done anything to the transmission and don't plan to until it gives me some sorts of signs it needs help.
Sent from my SM-G965U using Tapatalk
2003 Excursion Limited 6.0 PSD 4x4 6" lift 35x12.50x20
KDD Long block, KDD O-ringed heads, Colt stage 2 cam, Mahle .020" pistons, ARP head studs,
OE oil cooler and LPOP. OdawgS3, HD up-pipes, Performace valve springs, 190/30 WDI, Marty's Reg return & NeverStranded v2 Fuel System, Adrenaline HPOP, TSD tunes, KC Stage2
letsmow10 is offline
post #3 of 5 Old 01-17-2020, 02:29 PM Thread Starter
cjchico4's Avatar
Quoted: 13 Post(s)
Yeah I have the CTS2 for all my monitoring including EGT's. What is the never stranded fuel system? Also, did you upgrade your direct solenoid in the trans? Probably going to do that asap because my 3-5 flares every now and then when I get on it.
cjchico4 is offline
post #4 of 5 Old 01-17-2020, 06:14 PM
letsmow10's Avatar
Quoted: 124 Post(s)
Garage
https://martysdieselperformance.com/...fuel-system-2/
I have not done anything to the transmission except fluid and filter changes.
post #5 of 5 Old 01-19-2020, 08:14 PM
Quoted: 37 Post(s)
I’ve run 225/100s with all supporting mods in my wife’s excursion for 30-40k miles now. Truck has 215k, stock trans. Never misses a beat. I had an sxe369 in it for a little bit too. Definitely have your fueling supporting mods done prior to installing the.
06 King Ranch
Fass 200, Custom fuel lines, 225/100s, Thumper stage 2 hpop, WPE stage 3 intake, Mishimoto radiator, Flex a lite fans, BPD water pump, MPD oil cooler relocate kit, Intercooler pipes, Compounds built by me, etc etc etc
05 Eddie Bauer
Resealed entire motor @ 170k miles, new lifters, 6.4 push rods, studs, rebuilt the turbo, IPR egr delete, new injectors, new heads, new ficm board, coolant filter, intercooler tubes, regulated return, bunch of other new parts. Factory exhaust, cat gutted(wife's rig). Livewire with gearhead tunes. Should go a while reliably for her!
03 LB7 duramax the "daily/tow pig"
Lbz cp3, s475/stock twin kit, built trans, steel driveshft, amsoil bypass, secondary oil cooler built by me, fass, traction bars, trans cooler upgrade, dual alts, straight center link + tie rod sleeves, efi live, transfer flow/tool box tank, 5er hitch, other small upgrades.. and most importantly, STOCK HEADBOLTS! Just rolled 200k miles, twins installed @ 165k, daily driven on a "550 tune" tows 18k on a "475" tune.
Nickjames525 is offline
