Turbo choice for elevation - Ford Powerstroke Diesel Forum
 9Likes
post #1 of 20 Old 11-13-2019, 01:05 PM Thread Starter
Quoted: 5 Post(s)
Hey all, new here. I love my 7.3 Excursion, but I need a truck, so I picked up a gorgeous 07 F250 FX4 CCSB with about 130k on it. Supposedly has a blown head gasket, and as a result I got it for $4000. Considering there is no way I will own a 6.0 without studding it, I jumped at it.
So I'm gonna pull off the cab and stud it, new oil cooler, coolant filter, and a Sinister EGR cooler (emissions on diesels where I live). Then an exhaust and probably an SCT Livewire.
While I'm at it I might have a little fun with it and throw in some 155/30s and a turbo. I'm not looking to go nuts on power. I want it to stay reliable and not need a built transmission. I tow a couple times a month. Usually between 5000 and 8000 pounds, once in a great while 10,000.
I'm looking at a KC stage 1, stage 1.5, or a BD stage 1. I think any stage 2 will be too much.
Here is why: I live in Colorado Springs and I'm at 6000' elevation and sometimes go up higher. Lag is an accepted part of life here, but I don't need to go making it a whole lot worse on purpose.
So does anyone who lives at fairly high elevation have experience with a setup like what I am planning, and have any insight as to which turbo to go for? I called BD and KC, and it seemed like they obviously know their turbos, but don't really know too much about elevation and how it affects it. I'm looking for at least 400 rwhp on a tow tune, and a little more on a hot tune.
Will the stage 1 get me there? Will the 1.5 be significantly more laggy? KC or BD?
Thanks!
Crashandburn is offline
post #2 of 20 Old 11-14-2019, 12:34 PM
Old School
Chris's Avatar
Quoted: 49 Post(s)
Garage
I went with a KC stage one with the 13 blade wheel to reduce lag as much as possible since I have a manual transmission. It has worked as well or better than expected.
2006 F250 CCSB FX4 6 Speed Manual
KC Stage 1 Turbo, Spearco Intercooler, SCT X4 w/ Custom TSD Tunes, ARP Studs, EGR Delete, South Bend Dual Disc Clutch, AirDog II-4G Pump, AFE HD Momentum CAI, AFE CAC Pipes, AFE Intake Horn, AFE Front & Rear Dif Covers, Magnaflow 4" Turbo Back, EGR Delete, Sinister 200 Amp Alternator, Sinister Coolant Filter, BPD Radiator, BPD Water Pump, Big 3 Upgrade, Blue Spring, EDGE Insight CTS2, Morimoto BI-LED Projector Retrofit and LED Fog Lights, Bilstein 5100s
Chris is offline
post #3 of 20 Old 11-14-2019, 12:38 PM
jokester00's Avatar
Quoted: 483 Post(s)
Garage
I think a KC Stage 1 will fit just fine. @peixinho can answer your question better than I can though.
Not turbo related, but FWIW, I would spend the extra money on a BPD EGR cooler 10x over the Sinister EGR cooler. If you're gonna do it, do it right...do it once!
-jokester
darianmacdonald likes this.
2005 F350 CCLB FX4 Lariat
SCT SF3 - Currently running PHP 80hp Daily Driver Tune with Atlas 40 FICM Tune
Edge Insight CTS2 monitor
Edge EAS EGT probe
Edge EAS Fuel Pressure Sensor
jokester00 is offline
post #4 of 20 Old 11-14-2019, 04:25 PM Thread Starter
Quoted: 5 Post(s)
Any idea how much HP/TQ you're making? What's your elevation?
post #5 of 20 Old 11-14-2019, 04:53 PM
G8orFord's Avatar
Quoted: 2565 Post(s)
Garage
You are not going to get 400 rwhp from a 6.0 on a tow tune without serious upgrades. Not just a turbo. A performance tune, sure, but not a tow tune. 190/30's and a Stage 1.5 or Stage 2 and a very hot tow tune might get you close, but your towing will suffer with that much tune.
If you want a good tow vehicle that's fun to drive at elevation, get the KC Stage 1 one and drive on. If you want a little more, get the Stage 1.5 and some injectors. IMO, the 1.5 needs a little more injector than stock to really shine. I have one, so I'm speaking from my personal experience.
Dexter
2017 F-250 Lariat CCSB FX4 SRW- A few Forscan tweaks
My old Truck, now son's truck:
2004 F-250SD Lariat CCSB FX4 SRW; SCT X4 w/custom tunes (currently
SPD)
FICM;
FICM Tuner (currently Atlas40);
Stage 1.5 Turbo;
Stage 1 HPOP;
VK688 Oil Cooler Relocate with coolant re-route;
Water Pump;
O-ringed Heads; ARP Studs; Fel-Pro Gaskets;
Coolant Filter;
DashCommand on PLX Kiwi2 + iMFD with EGT & Fuel/Oil Pressure
G8orFord is offline
post #6 of 20 Old 11-14-2019, 05:56 PM Thread Starter
Quoted: 5 Post(s)
155/30s should get me there according to Warren, BD and a couple others. I'm more concerned with getting the turbo to spool.
post #7 of 20 Old 11-15-2019, 04:18 AM
Old School
Chris's Avatar
Quoted: 49 Post(s)
Garage
Honestly, no idea and I really don't care. I have done more upgrades than what's in my signature. To me the most important thing is it's reliable and has all the power I need. I push the throttle down and the 9k pound truck rockets off. Elevation is 500-1500 above sea level at any given time.
jokester00 and letsmow10 like this.
Chris is offline
post #8 of 20 Old 11-15-2019, 06:35 AM
G8orFord's Avatar
Garage
I won't argue with the experts, but are you sure they said "rear wheel HP" and tow tune?
Dexter
SPD)
FICM;
Stage 1.5 Turbo;
Stage 1 HPOP;
Water Pump;
Coolant Filter;
G8orFord is offline
post #9 of 20 Old 11-15-2019, 07:00 AM Thread Starter
Quoted: 5 Post(s)
Yup, I asked twice to be sure. The only thing that I can't really get a great answer on is the turbo. And I get it, there are a lot of variables. But it seems like they are afraid to overpromise. One guy recommended not going over stock! He couldn't believe me when I told him that I hear that Powermax whistle that you can pick out a mile away, all the time.
Like I said before, some turbo lag is expected here in CO. Bigger turbos lag more. But injectors and tuning will spool a turbo. The question is how much?
I currently drive a 7.3 Excursion with a DP tuner. It spools as well as you could hope for. At sea level it's better. But it still does fine at elevation, and that's without VGT.
post #10 of 20 Old 11-15-2019, 07:03 AM Thread Starter
Quoted: 5 Post(s)
Fair enough. If you're happy with how it runs, who cares what number shows up on a graph?
Chris likes this.
