6.0 Turbo - Ford Powerstroke Diesel Forum
 5Likes
post #1 of 10 Old 10-07-2019, 06:02 PM Thread Starter
6.0 Turbo
Hi! I have a 2005 F250 with the 6.0. Purchased about a month and a half ago. The egr is blocked and it has some sort of tune on it but I can't tell you what it is. 4" straight pipe and that's really all I know. About it. Well my turbo went out last night and I am looking at a powermax stage one to replace it with. Can I get some info or help if this is a good idea or not. What else I need to do or change in the truck when doing this. I will be adding a S&B at the same time as well.
Thanks, Matt
Pheasanthunter66 is offline
post #2 of 10 Old 10-07-2019, 06:16 PM
jokester00's Avatar
Quoted: 477 Post(s)
Garage
If I were you, i'd spend the extra $$ and get a Stage 1 from KC Turbos over the P-Max. You will probably want to get some sort of a custom tune/revision on your current tune for the P-MAX and/or the KC stage one when you get it.
-jokester
2005 F350 CCLB FX4 Lariat
SCT SF3 - Currently running PHP 80hp Daily Driver Tune with Atlas 40 FICM Tune
Edge Insight CTS2 monitor
Edge EAS EGT probe
Edge EAS Fuel Pressure Sensor
jokester00 is offline
post #3 of 10 Old 10-07-2019, 07:06 PM Thread Starter
I will look into that! Thanks! Since the truck is not studed and has 125k on it, is there anything else that I need to do. Mods etc. To keep the truck healthy. Will I cause any problems having the slightly larger turbo?
post #4 of 10 Old 10-07-2019, 08:11 PM Thread Starter
post #5 of 10 Old 10-08-2019, 04:56 AM
Old School
Chris's Avatar
Quoted: 43 Post(s)
Garage
+1 on the KC stage 1 and a tune. TSD is a company that KC recommends and I had good luck with them.
jokester00 likes this.
2006 F250 CCSB FX4 6 Speed Manual
KC Stage 1 Turbo, Spearco Intercooler, SCT X4 w/ Custom TSD Tunes, ARP Studs, EGR Delete, South Bend Dual Disc Clutch, AirDog II-4G Pump, AFE HD Momentum CAI, AFE CAC Pipes, AFE Intake Horn, AFE Front & Rear Dif Covers, Magnaflow 4" Turbo Back, EGR Delete, Sinister 200 Amp Alternator, Sinister Coolant Filter, BPD Radiator, BPD Water Pump, Big 3 Upgrade, Blue Spring, EDGE Insight CTS2, Morimoto BI-LED Projector Retrofit and LED Fog Lights, Bilstein 5100s
Chris is offline
post #6 of 10 Old 10-08-2019, 05:45 AM
Heavy_GD's Avatar
Quoted: 3125 Post(s)
Garage
Feedback Score: 4 reviews
@[email protected]
GD
Originally Posted by djmaguire View Post
So says the internet... ...and so it shall be.
Originally Posted by G8orFord View Post
OK, thanks for the info. To show my ignorance, what is the problem with 3 nipples...
Heavy_GD is offline
post #7 of 10 Old 10-14-2019, 02:24 PM
Corey@CNCFAB's Avatar
Quoted: 1418 Post(s)
@Pheasanthunter66
Did you find what you needed. Sorry I'm late to the party.
https://cncfab.us/i-30498170-kc-turb...ct-300243.html
[SIZE="3"]For all your ford powerstroke needs. If you dont see what you are looking for on the website, please use the contact page and shoot us a message or
Part numbers will help alot too if they are not on our site.
post #8 of 10 Old 10-14-2019, 02:43 PM Thread Starter
I haven't done anything yet. I'm trying to decide whether to spend 9k and get a t4 turbo set up, 155/30 injectors and have the top end and head gaskets done. . . I'm not sure what to do.
post #9 of 10 Old 10-14-2019, 04:25 PM
For under 600hp, which would be 205/75 injectors and smaller, I would stick with the VGT turbo. They do so much better for daily driving, towing, and fun on the streets.
jokester00 and Hydro like this.
post #10 of 10 Old 10-14-2019, 05:18 PM Thread Starter
What do you mean? I really dont know that much about any of it honestly. I'm just going with what the guys at my shop and a buddy told me.
