Need help please! Redhead steering box - Ford Powerstroke Diesel Forum
post #1 of 4 Old 09-21-2019, 12:53 PM Thread Starter
Wareagle0817's Avatar
I was having a lot of steering play on my 05 SD and decided to replace with a redhead. Well, I was able to get everything changed out and went for a drive. After returning I looked underneath the truck and what did i see, yes atf! Well jumped back on it removed lines and called my buddy at Ford and he told me there are two teflon seals that go on the fittings. WTH redhead didn't mention this just the two seals. Anyway, I'm confused as to do we use the o rings or the teflon seals. Anyone that has installed one please help. Thanks
-Travis
2005 F250 6.0 CCSB XLT 4x4, EGR Delete, ARP Studs, Internals is Ford OEM, AMP Power Steps, 2008-10 Factory Rims, and Ready-lift level kit, Bilstein 5100.
Wareagle0817 is offline
post #2 of 4 Old 09-21-2019, 05:54 PM
voodooridr's Avatar
Quoted: 962 Post(s)
The part number on those Teflon rings is 388898-S
2004 F250 CCSB 4X4
4" Skyjacker lift
3:73 gears
35x12.5x18 Nitto Ridge Grapplers on Method MR309 wheels
KDD heads, ARP studs, BD exhaust manifolds, DieselSite up pipes, Mishimoto degas bottle
PHP Insight PRO
PHP Atlas 40 FICM tune
voodooridr is offline
post #3 of 4 Old 09-26-2019, 03:27 AM
Old School
Chris's Avatar
Quoted: 40 Post(s)
Garage
Did the steering box clean up the slop in your steering?
2006 Ford F250 CCSB FX4 6 Speed Manual
KC Stage 1 Turbo, Spearco Intercooler, SCT X4 w/ Custom TSD Tunes, ARP Studs, South Bend Dual Disc Clutch SFDD3250-6.0, AirDog II-4G Pump, AFE HD Momentum CAI, AFE CAC Pipes, AFE Intake Horn, AFE Front and Rear Dif Covers, Magnaflow 4" Turbo Back, EGR Delete, Sinister 200 Amp Alternator, Sinister Coolant Filter, BPD Radiator, BPD Water Pump, Big 3 Upgrade, Blue Spring, EDGE Insight CTS2, Morimoto BI-LED Projector Retrofit, Morimoto LED Fog Lights, Bilstein 5100s
Fast, cheap, reliable...pick two.
Chris is offline
post #4 of 4 Old Today, 10:27 AM Thread Starter
Hey Chris, Sorry it took this long to respond to your question but to tell you it is night and day difference. I just got back from a 1700 mile trip and it worked flawlessly. No back and forth like I used to do on any trip so, if you are on the fence about the redhead box go for it.
-Travis
