HPODS valve covers - CCV reroute - Ford Powerstroke Diesel Forum
post #1 of 6 Old 09-10-2019, 01:43 PM Thread Starter
Quoted: 15 Post(s)
Gearing up to install the DieselSite HPODS system with valve covers from PSP Motorsports.
Both covers have -12AN fittings with screens. Does anyone know if I can run the CCV reroute to the catch can from the passenger side or does it have to stay on the driver side? Catch can goes to a venturi welded to the exhaust, and both catch can and venturi will be mounted behind cab passenger side.
2005 F550 Camper KDD Stage 2 Long Block, PSP Lifters, WDI 155/30, ATS Coolant Recirc, BPD EGR Cooler, Oil Cooler, & Water Pump, Odawgs S2.0 Intake, BD Exhaust Manifolds, No-Limit CAI, Catch Can, & CAC, KC Stage 1.5 Turbo, Driven Diesel Regulated Return & Dual Bosch Fuel System, MBRP 4" Turbo Back Exhaust & HD Up Pipes, Mishimoto Thermostat & Hoses, IPR High-Flow Coolant Filter, PSP Degas Tank, 7.3 Fan Clutch, DC Power 270XP Alternator, Fluidampr, Insight CTS2, Titan Tank, Bean Sump, SCT X4
RideFalkor is offline
post #2 of 6 Old 09-10-2019, 04:45 PM
BBBRRRRRTTTTT
powerstrokeshellback's Avatar
Quoted: 600 Post(s)
Feedback Score: 11 reviews
It doesn't matter which side.
2016 F-250 Super Crew XLT 6.7L
2007 F-250 Super Cab XL 6.0L (sold)
C-A-P-S CAPS! CAPS! CAPS!
powerstrokeshellback is offline
The Following 2 Users Say Thank You to powerstrokeshellback For This Useful Post:
RideFalkor (09-11-2019)
post #3 of 6 Old 09-24-2019, 08:04 PM
You can even run your breather from your oil fill tube if it makes things more simple for you
Sonoma6Leaker is offline
post #4 of 6 Old 09-25-2019, 06:04 PM Thread Starter
Quoted: 15 Post(s)
DieselSite sells that as an add-on to the HPODS, but then I wouldn't be able to see the magnificent machining that is the No Limit Catch Can
post #5 of 6 Old 10-07-2019, 03:44 PM
PSD POWER007's Avatar
Quoted: 11 Post(s)
Send a message via AIM to PSD POWER007
Did you get this installed? I’m interested to hear some real feedback on this system.
PSD POWER007 is offline
post #6 of 6 Old 10-09-2019, 07:47 PM Thread Starter
Quoted: 15 Post(s)
Part of a larger build - the cab went back on this afternoon. If all goes to plan the first start will be late tomorrow. I have 1500 miles to drive over the next two weeks and will add first impressions.
IMPORTANT: These covers are quite thick and require 2 additional extension fittings for the oil rails (same one as used in connection to HPOP). $20/ea also from DieselSite. Ask for Dan as he is familiar with the issue.
I'll post some pictures when all the plumbing is connected & routed cleanly.
