Stock 6.0 turbo upgrade - Ford Powerstroke Diesel Forum
 2Likes
  • 1 Post By 50dan
  • 1 Post By mpholland
post #1 of 5 Old 08-25-2019, 03:22 PM Thread Starter
Quoted: 10 Post(s)
I’m gearing up to do an EGR delete with a dummy EGR cooler and replacing my oil cooler. Truck is ‘03 F350 has 104k Miles was well maintained by original owner. Otherwise truck is stock. Can I upgrade to a better turbo without doing head studs and gaskets?
50dan is offline
post #2 of 5 Old 08-25-2019, 03:53 PM
jokester00's Avatar
Quoted: 530 Post(s)
Garage
I hate to sound like Captain Obvious, but...
Anytime you go above and beyond stock parameters, you're rolling the dice. You might be fine for YEARS down the road, or not... that's the hard part about this question because no one can really say. Just be prepared and start setting money aside for the "just in case" fund!
-jokester
2005 F350 CCLB FX4 Lariat
SCT SF3 - Currently running PHP 80hp Daily Driver Tune with Atlas 40 FICM Tune
Edge Insight CTS2 monitor
Edge EAS EGT probe
Edge EAS Fuel Pressure Sensor
jokester00 is offline
post #3 of 5 Old 08-25-2019, 04:00 PM Thread Starter
Quoted: 10 Post(s)
-jokester
Yeah that’s kinda what I figured LOL.
I was thinking since I thought most of the head gasket issues were the result of an oil cooler/EGR cooler failure, it would be okay since I’m replacing them.
jokester00 likes this.
50dan is offline
post #4 of 5 Old 08-25-2019, 04:09 PM
jokester00's Avatar
Quoted: 530 Post(s)
Garage
Originally Posted by 50dan View Post
Yeah thatís kinda what I figured LOL.
I was thinking since I thought most of the head gasket issues were the result of an oil cooler/EGR cooler failure, it would be okay since Iím replacing them.
You are correct about the EGR/oil cooler failures leading to a lot of HG issues. However, I would still never tell you that you're going to be fine just because you only changed the turbo
-jokester
Edge EAS EGT probe
post #5 of 5 Old 08-25-2019, 05:08 PM
mpholland's Avatar
Quoted: 204 Post(s)
Garage
I'm with Jokester on this.
I have a stock turbo, but run a 100HP PHP tune as a daily driver on stock TTY bolts. No signs of leaking yet at 130K, but I also have 10K set aside for when it does. Compare that to 65K for a new truck and its a no brainer to me.
darianmacdonald likes this.
ďAnyone who is capable of getting themselves made President should on no account be allowed to do the job.Ē Douglas Adams
mpholland is offline
