Long Block vs Crate Engine - Ford Powerstroke Diesel Forum
 13Likes
post #1 of 22 Old 08-01-2019, 08:10 AM Thread Starter
hlg0607's Avatar
Quoted: 3 Post(s)
Good morning all,
So my truck recently took a sh** and it was caused from wearing on the roller/ cam and expansion and a crack in both my heads (about .006"). (see attached) So im in a dilemma of whether I should buy a new crate or turn key motor or just do a "long block" and transfer my parts from my old motor. I'm having the work done by a mechanic, i am not doing the work myself. Orrrr should i have them go through strip and rebuild the current motor I have. Keeping in mind it will more than likely be needing a flushed oil pan,a hot plunge, new oil pump, front over, rod bearings, camshaft, roller/lifters, crankshaft... Lord only knows what else.
What are your guys opinions?
Thanks in advance
ID:	721359   Click image for larger version
hlg0607 is offline
post #2 of 22 Old 08-01-2019, 08:20 AM
ZMANN's Avatar
Quoted: 3847 Post(s)
I would look at an Ashville long block
long blocks are easier to get warranty than a short and your heads and assembly
hlg0607 likes this.
6.0 flush pdf
ZMANN is online now
post #3 of 22 Old 08-01-2019, 08:23 AM
ZMANN's Avatar
that roller spit it's bearings ? it looks semi intact
hlg0607 likes this.
6.0 flush pdf
ZMANN is online now
post #4 of 22 Old 08-01-2019, 08:24 AM Thread Starter
hlg0607's Avatar
Quoted: 3 Post(s)
I think they only have remans and if i buy anything i would prefer it to be new.
hlg0607 is offline
post #5 of 22 Old 08-01-2019, 08:27 AM Thread Starter
hlg0607's Avatar
Quoted: 3 Post(s)
Yeah im not 100% what happened the truck just wouldn't start one day, and i brought it in, but i was out of town when the mechanic called with a diagnostic so im not sure how truthful he was. but on another note, I would say it was impacted somehow and yes the bearing split.
hlg0607 is offline
post #6 of 22 Old 08-01-2019, 01:17 PM
F350R's Avatar
Quoted: 17 Post(s)
I am with zmann. I have a Asheville .20 over with a stage II cam studs KC stage II turbo BPD oil cooler and 7.3 fan clutch. It's a very strong running motor. Asheville will treat you right and stand behind their product.
Sent from my Pixel 3 XL using Tapatalk
2004 F-350 CC LB Lariat FX4, SCT Erics Street tune, BPD EGR Cooler, BPD oil cooler, Empty CAT, Snows Water / Meth, Coolant & Oil bypass filters, 265x70x19.5 on American Force wheels, On board air system, Firestone air bags in cab regulator, dual air horns
F350R is offline
post #7 of 22 Old 08-01-2019, 01:27 PM
ZMANN's Avatar
you won't find an all new Ford /IH 6.0 motor unless it is NOS and been lying around with seals drying out
SparkyF250 likes this.
6.0 flush pdf
ZMANN is online now
post #8 of 22 Old 08-01-2019, 02:00 PM Thread Starter
hlg0607's Avatar
Quoted: 3 Post(s)
NOS? Like Nitrous Oxidized? You can order new models from FORD im fairly certain. But im just trying to find the best route, so a reman is not a voided option by any means.
hlg0607 is offline
post #9 of 22 Old 08-01-2019, 02:09 PM
voodooridr's Avatar
Quoted: 891 Post(s)
Only remans from mother Ford
Sent from my SM-G960U using Tapatalk
2004 F250 CCSB 4X4
4" Skyjacker lift
3:73 gears
35x12.5x18 Nitto Ridge Grapplers on Method MR309 wheels
KDD heads, ARP studs, BD exhaust manifolds, DieselSite up pipes, Mishimoto degas bottle
PHP Insight PRO
PHP Atlas 40 FICM tune
voodooridr is online now
post #10 of 22 Old 08-01-2019, 02:21 PM
SparkyF250's Avatar
Quoted: 3128 Post(s)
Garage
If you don't like Ashville, there's this https://killdevildiesel.com/collecti...oke-long-block
Sparky
2005 F250 CCSB KR 4x4 6.0 4" Flo-Pro,
Fox 2.0s, Toyo ATs, CTS2 Pro, Blue Spring, BPD 7.3 Fan Clutch, IPR Coolant Filter
2000 F350 SCLB Dually 4x4, 7.3 6 Speed Hydra, CTS2, S&B Air, 4'' SS Diamond Eye
2005 Explorer XLT 4x4 Mountaineer,
Toyo ATs, Wife's grocery getter
1993 F150 4x4, 302 5 speed, winter truck
1991 F350 4x4, 7.3 IDI Flatbed, 5 speed...sold
2008 F250 SCLB 6.4...Sold
SparkyF250 is offline
