External oil cooler for performance - Ford Powerstroke Diesel Forum
 6Likes
post #1 of 11 Old 07-15-2019, 11:46 AM Thread Starter
Anyone out here running an external oil cooler? Iím wondering if they offer more oil cooling capacity than the stock internal unit.
Hereís my situation. Iíve owned my truck for 6 months. Iíve replaced the internal cooler twice, thoroughly disassembled and flushed the coolant system & added a coolant filter. During low speed driving, the EOT and ECT remain in the normal range ([email protected] and [email protected]). Once I hit highway speeds, the EOT climbs to 235😬. The temp will fall back down when I slow down.
I canít keep changing the cooler every 2 months. I know that there are 3rd party external oil cooler kits. Is anyone running one successfully?
Cortney Koning is offline
post #2 of 11 Old 07-15-2019, 11:54 AM
JustinOOO9's Avatar
Quoted: 1518 Post(s)
Garage
Feedback Score: 3 reviews
Bulletproof diesel is the ONLY TRUSTED AND QUALITY oil cooler kit for the 6.0L period. Any research would show that. It eliminates the need for monitoring the oil and coolant temp difference and just works. Yes its pricey but no one has developed such a quality kit that has the research and development. I didn't even run one but my temps were great after the flush and stud job etc.
PLEASE DONT waste time with these ebay kits they will not function and work like they describe. More users may post but most will see your question and there just isn't an alternative (quality and function wise) to the air cooled buylletproof diesel kit.
junior125 likes this.
-99 F250, 4X4, 6.0 trans cooler, 08 mirrors, 05 grill, AIS Intake, lvl kit, JW Vbody, cncfab hpop lines, WW2.
04 Excursion Modified, 04 F350 Modified, 06 F350 Modified
Interested in learning something new?
Justin
JustinOOO9 is online now
post #3 of 11 Old 07-16-2019, 11:11 AM
ChrisSki's Avatar
Quoted: 542 Post(s)
I have an air cooled BPD oil cooler and oil temps are not a worry anymore. I'm not saying the oil won't get hot, but there's no concern about delta. Delta in a OEM cooler means its clogged, and there's no worry about a clogged cooler. My oil temps now that I've put in a mechanical 7.3 clutch will not reach 200 slick and maybe 210 tops when towing uphill, all in 100į ambient air temps. The fan pulls so much more air across the BPD oil cooler, the air condenser, the intercooler and the radiator. Prior to the mechanical clutch, I'd have 205-210į slick in 100į weather. Towing up a hill EVT would be 220 and EOT would be 238į and the electric fan would kick on and cool it way down. The only complaint about the BPD air cooled cooler may be in extreme cold temps, like in the winter north, the oil temps won't get up to operating temps, even with the thermostat kit installed and closed, unless the oil radiator has a blanket over it.
So, is the cooling capacity more? IMO they designed a 100,00 BTU cooler (thanks to @DJM cguire for that number), which is the same as the OEM, but my opinion is that it may cool a little less idling in the heat without the airflow over the radiator and in normal driving conditions down the road, but cools more in extreme winter temps.
2005 F250, 189,000 Miles
Bullet Proof HD Oil Cooler w/ Cold Weather Kit, Bullet Proof EGR, Bulletproof Water Pump, 7.3 Fan Clutch
Airlift 5k Airbags and Wireless Air
Edge CTS w/ EGT probe and Fuel Pressure Sensor.
15 MPG slick; 10 MPG towing 11k fifth wheel
Ravelco
6.0 Flush Procedure:
Good 6.0 Reading:
ChrisSki is offline
post #4 of 11 Old 07-16-2019, 11:53 AM
N.S.D.Q.
HeavyAssault's Avatar
Quoted: 767 Post(s)
I love oil cooler conversations that forget the water pump and tstat play a part in potential sources of the problem. Since you didn't say either of those were checked the first two times....make it three? But hey...$pend that money.
fordsvtparts likes this.
Officially The Biggest Midget In The Game
HeavyAssault is offline
post #5 of 11 Old 07-16-2019, 09:24 PM
djmaguire's Avatar
Quoted: 1581 Post(s)
Garage
It seems to me that he is asking about oil cooler relocations. If so, I have been running a BPD oil cooler relocation for a few years now. Works perfectly fine.
You can read about the installation here:
https://www.powerstroke.org/forum/po...iscellany.html
2004 F550 CC Lariat
BPD oil cooler relocation and upgraded EGR cooler (spooled), BPD oil bypass filtration, aFe Magnum Force CAI, Mishi radiator, 7.3L fan clutch, EC1 ELC, XDP coolant bypass filtration, '08 trans pan/filter, PTP direct clutch solenoid, blue spring, 6.4 starter, MBRP y-pipe, BD boots/clamps, '05 intake elbow, ccv reroute, Torque Pro + OBDLinkô LX, Autometer EGT
djmaguire is offline
post #6 of 11 Old 07-17-2019, 02:07 AM
N.S.D.Q.
Quoted: 767 Post(s)
I know what he was asking about, an external cooler.
What he described doesn't mean his current system is functioning 100%. It reads just like a problem exists and a BPD cooler will only mask a problem that may get uglier down the road. Fix the OEM stuff to get it working 100% then do mods.
fordsvtparts and djmaguire like this.
post #7 of 11 Old 07-17-2019, 03:37 AM
Unapologetically American
2006PSDSD's Avatar
Quoted: 110 Post(s)
Feedback Score: 4 reviews
What kind of gearing do you have? How fast are you going on the hwy?
I drive a towboss with 4.30 gears and I know mine runs at a higher temp at 70mph than the same truck with 3.73 due to the higher rpm range. The proper test (65mph, no load, after hitting OP temp) can't be done with my truck without some modification to the speed.
2006 F350 King Ranch
ARP Studs
Kill Devil Diesel o-ringed heads
Fel-pro HG's
6.4 pushrods
Stage 1 (61mm x 13 blade) DIY turbo from KCturbo's
ODAWG S3R
Bulletproof 53v FICM
Rotella ELC
No Limit intake
CCV reroute
Originally Posted by mhatlen View Post
Oh yea real men have 4Ē down pipes
2006PSDSD is offline
post #8 of 11 Old 07-17-2019, 09:04 AM
djmaguire's Avatar
Garage
Originally Posted by HeavyAssault View Post
I know what he was asking about, an external cooler. ...
Yeah, I reread it and now see it the same way that you do. I'm not quite sure what made me think relocation on the first read. Maybe beer.
Good point to mention. I have a similar thing going on. My recommendation is 1900RPM rather than 65mph.
HeavyAssault likes this.
2004 F550 CC Lariat
post #9 of 11 Old 07-18-2019, 03:21 AM
2006PSDSD's Avatar
Quoted: 110 Post(s)
That's the way we should be looking at it instead of just going off our speed, although I didn't know the specific rpm for a 3.73 geared truck at 65. Thanks
djmaguire likes this.
ARP Studs
Fel-pro HG's
6.4 pushrods
ODAWG S3R
Rotella ELC
No Limit intake
CCV reroute
post #10 of 11 Old 07-27-2019, 04:16 PM
repalmer's Avatar
Quoted: 527 Post(s)
Just to stir it a little. There's also the IPR kit that uses a factory cooler that just relocates it out of the valley and puts a full flow coolant filter before the cooler
After addressing any other malfunctions of course
repalmer is offline
