Turbo recommendations - Page 2 - Ford Powerstroke Diesel Forum
 12Likes
post #11 of 17 Old 06-28-2019, 08:19 AM
G8orFord's Avatar
Quoted: 2522 Post(s)
Garage
^^What @junior125 and @drumguy said.
Dexter
2017 F-250 Lariat CCSB FX4 SRW- A few Forscan tweaks
My old Truck, now son's truck:
2004 F-250SD Lariat CCSB FX4 SRW; SCT X4 w/custom tunes (currently
SPD)
FICM;
FICM Tuner (currently Atlas40);
Stage 1.5 Turbo;
Stage 1 HPOP;
VK688 Oil Cooler Relocate with coolant re-route;
Water Pump;
O-ringed Heads; ARP Studs; Fel-Pro Gaskets;
Coolant Filter;
DashCommand on PLX Kiwi2 + iMFD with EGT & Fuel/Oil Pressure
G8orFord is offline
post #12 of 17 Old 08-13-2019, 04:58 PM
Baddestt's Avatar
Quoted: 9 Post(s)
KC turbo 1.5! It's awesome. Pulls like a freight train with my set-up. Plus the 13 blade is much quieter than the 03 turbo I had previously. I run stock injectors, and it pulls my 16k pound 5th wheel very well
Baddestt is offline
post #13 of 17 Old 08-14-2019, 03:30 AM
R&Rpowerstroke's Avatar
Quoted: 101 Post(s)
Garage
Had a KC stage 2, now have a KC stage 1. Always been on stock sticks and will remain that way. Both installs were straight forward and easy and both of the turbos I received were beautiful pieces. If I did it all over I would have went with the stage 1 to begin with but in my defense they didn't have it when I bought the stage 2. Spools quicker than stock, with my set up I see 40psi of boost, towing is an easy task, and never worry of egt's. I went with the 13 blade turbine for my dogs and for towing purposes. Stage 2 had the 10 blade, and I have never received more compliments on my truck, it sounded amazing just hurt the dogs ears.
R&Rpowerstroke is offline
post #14 of 17 Old 08-14-2019, 04:53 AM
N.S.D.Q.
HeavyAssault's Avatar
Quoted: 808 Post(s)
Feedback Score: 3 reviews
I'll defer to the latter....Before KC got running I was using a P-max/10 blade with a Barder billet compressor wheel. God knows I loved that whistle sound at idle or just cruising the parking lot. On the pedal it was a beast thru straight pipe... Cold starts in the winter were insanely loud.
If I could get that same whistle on my 6.7L I would be happier with the sound.
Don't forget other options in airflow management can get you more out of the turbo. KC can feed your habit!
Officially The Biggest Midget In The Game
HeavyAssault is offline
post #15 of 17 Old 08-24-2019, 02:35 PM
FireParadox640's Avatar
Quoted: 2 Post(s)
Garage
I am looking to save up and get a KC Stage 1 for my 2006 F-250. I saw someone earlier say that it's better to tune it to that turbo when its put in, but my question is if I'm not someone who has a tuner on my truck, is it absolutely necessary to tune it for that turbo or will it still perform well without a tune?
Thanks for y'all's time, I'm still learning more by the day, just want to be preemptive on a turbo change since even though the truck only has 69K mi on it its still on its 4th turbo (my mom believed in low mileage vehicles so it never got driven as much as it should, now its my daily driver).
FireParadox640 is offline
post #16 of 17 Old 08-24-2019, 06:07 PM
darianmacdonald's Avatar
Quoted: 23 Post(s)
Dang, 4 turbos in 70K miles, impressive.
A KC Stage 1 will be fine without a tune, not entirely necessary. But KC would be the best to talk to about that, they are super helpful in that regard and will give you an honest answer.
Sent from my iPhone using Tapatalk
letsmow10 and FireParadox640 like this.
2006 CCSB Lariat F-350
304,XXX KM
ARP studs, EGR Delete
SCT SF3 w/ GH & IDP Tunes
BW SXE 62/68/.83AR, Irate T4 Kit
4" Volant Turbo back exhaust
Driven Diesel RR w/ Fuelab Regulator
Isspro Boost, Fuel Pressure, Oil Pressure, HPOP Pressure Gauges
Edge Insight Monitor
FS2500 Oil Bypass Filtration
IDP Tuned 58V FICM
Coolant filtration
R4 Rear Air Ride
Bilstein 5100's
2-Way Compustar Remote Start/Alarm
Misc. mods
darianmacdonald is offline
post #17 of 17 Old 08-24-2019, 06:58 PM
Quoted: 2 Post(s)
Garage
Thank you, I appreciate the response, I will reach out to KC and double check. Yeah 4 turbos before I inherited it after my mom passed away and when I got it she only had 64K on her. Not a record I want to continue with, my goal is maximum longevity, I take good care of my vehicles, my mom wasn't hard on it, she just didn't drive it like it should've been unfortunately. I want to bulletproof it, put a better turbo in and make my truck last.
6.0vanman and darianmacdonald like this.
