My 6.0 is in the shop - Ford Powerstroke Diesel Forum
 5Likes
post #1 of 4 Old 06-17-2019, 01:29 PM Thread Starter
Quoted: 3 Post(s)
So my 6.0 has 190k miles on her and she is bone stock. She just went into the shop for the the usual Head studs, egr delete, oil cooler replace, heads redone if not cracked, all the normal gaskets replaced .....
I decided on some other extras suck as 4inch turbo back exhaust, act tuner installed with a hand full of tunes. FASS fuel system, bigger radiator, ficm upgrade...
My question for you guys is I have the option now to do injectors and turbo.
MY concern with that is will my stock tire size be good enough to hold the power, and will my transmission hold up as well as my drive shaft. Im not looking to hot rod in the truck. How ever with that much power who knows what will happen.
Godshands00 is offline
post #2 of 4 Old 06-17-2019, 01:58 PM
letsmow10's Avatar
Quoted: 115 Post(s)
Garage
Transmission and driveshaft will be ok for 190/30s and a stage 2 turbo. Tire size is easy enough to change but just roll into the throttle vs just going WOT and you will be fine. Its all in what you want and what you intend to do with the truck honestly. IMHO if I had the extra money for injectors and turbo I would go for it.
Sent from my SM-G965U using Tapatalk
BTL likes this.
2003 Excursion Limited 6.0 PSD 4x4 6" lift 35x12.50x20
KDD Long block, KDD O-ringed heads, Colt stage 2 cam, Mahle .020" pistons, ARP head studs,
OE oil cooler and LPOP. OdawgS3, HD up-pipes, Performace valve springs, 190/30 WDI, Marty's Reg return & NeverStranded v2 Fuel System, Adrenaline HPOP, TSD tunes, KC Stage2
letsmow10 is offline
post #3 of 4 Old 06-18-2019, 04:57 AM
Heavy_GD's Avatar
Quoted: 3099 Post(s)
Garage
Feedback Score: 4 reviews
If you are spending money, get a KC turbo.
@[email protected]
[email protected] likes this.
GD
Originally Posted by djmaguire View Post
So says the internet... ...and so it shall be.
Originally Posted by G8orFord View Post
OK, thanks for the info. To show my ignorance, what is the problem with 3 nipples...
Heavy_GD is offline
The Following 2 Users Say Thank You to Heavy_GD For This Useful Post:
[email protected] (06-18-2019)
post #4 of 4 Old 06-18-2019, 02:25 PM
Corey@CNCFAB's Avatar
Quoted: 1389 Post(s)
This would be the charger to go perfect with those 190/30's.
https://cncfab.us/i-30498075-kc-turb...tg2-03-07.html
I've got everything else your potentially looking for too.
ZMANN, Kryptic_361 and SparkyF250 like this.
[SIZE="3"]For all your ford powerstroke needs. If you dont see what you are looking for on the website, please use the contact page and shoot us a message or
Part numbers will help alot too if they are not on our site.
