Stage 2 Turbo w/ Stock Injectors FICM Tune - Page 2 - Ford Powerstroke Diesel Forum
 9Likes
post #11 of 16 Old 06-19-2019, 10:53 AM
ChrisSki's Avatar
Quoted: 588 Post(s)
If you contact KC Turbos directly, you'll get an honest answer. I contacted KC recently about my turbo and he talked me out of buying a turbo I did not need.
peixinho, john galt and SparkyF250 like this.
2005 F250, 189,000 Miles
Bullet Proof HD Oil Cooler w/ Cold Weather Kit, Bullet Proof EGR, Bulletproof Water Pump, 7.3 Fan Clutch
Airlift 5k Airbags and Wireless Air
Edge CTS w/ EGT probe and Fuel Pressure Sensor.
15 MPG slick; 10 MPG towing 11k fifth wheel
Ravelco
6.0 Flush Procedure:
Good 6.0 Reading:
ChrisSki is offline
post #12 of 16 Old 06-19-2019, 11:23 AM
Heavy_GD's Avatar
Quoted: 3152 Post(s)
Garage
Feedback Score: 4 reviews
@[email protected]
@peixinho
GD
Originally Posted by djmaguire View Post
So says the internet... ...and so it shall be.
Originally Posted by G8orFord View Post
OK, thanks for the info. To show my ignorance, what is the problem with 3 nipples...
Heavy_GD is offline
post #13 of 16 Old 06-19-2019, 12:02 PM
Quoted: 22 Post(s)
I currently have the KC stage 2 on a completely stock fuel system and also run the SPD tune and their tow tune. I love it and had the intentions that you currently do. I figured get the most air moving so when/if I started adding fuel I already had the air. If I'm not mistaken you should be able to go up to 190/30s quite easily with that turbo. I personally didn't notice much difference in spool up time but I also very rarely used my truck in the kind of manner that that was an issue. I do tend to tow heavy whenever I am hooked up and I feel like this turbo and the tuning I had with it paired very nicely and hardly ever got high on the EGTs.
2016 F250 SRW Crew Cab. All stock so far.
Sold 2005 F250 SRW Crew Cab
AFE Cold Air Intake, KC Stage 2 Turbo, ARP Studs, 4" turbo back exhaust, and SCT with TSD tunes.
kbnw15 is offline
post #14 of 16 Old 06-19-2019, 01:42 PM
R&Rpowerstroke's Avatar
Quoted: 107 Post(s)
Garage
Originally Posted by cjchico4 View Post
I don't tow but there's always a chance I would and I'd just throw a tow tune on with a lower ficm tune if I had to. I don't beat the piss out of my truck but sometimes I do rip on it. Is the stage 2 louder than the stage 1?
To me it's worth the extra ~$200 for the stage 2 because then if I ever upgrade my injectors I'll already have it. I don't plan on upgrading injectors anytime soon, though. I'd rather have quicker spool and better mileage, but I also want the most power for the money.
Stage 2 is based off 03- early 04 10 blade and yes it is louder, stage 1 comes with 13 blade but can get the 10 blade. If you plan on upgrading whenever you need injectors then sure go right ahead. I ran Atlas 80 with GH tow tune on the stage 2 and egts were 1250 pulling a grade at 70-75 mph, weighing 24,000 and had plenty of power. The stage 1 with stock sticks is quicker off the line running the same tunes I never had them redone between the turbos. I will never go larger than stock sticks and stage 1 suits me better but I did enjoy the stage 2. Be ready to replace your intercooler I blew mine apart at 40+ psi of boost as have many. You really can't go wrong with either of them to be honest if you plan on upgrading go stage 2, if not then go stage 1 or if you plan on towing max weight go stage 1. I would consider changing up pipes at the same time, don't be surprised if you see yours have been leaking at the bellows when you pull the turbo.
03 250 ccsb blue spring, UCF ported and polished heads, Odawg SR3, ficm tuner, SCT x4 with custom tunes, 4" turbo back to 6" tip, Magtec diff covers, Amsoil fluids, ARP 625's, Airlift bags, Kc stage 1, Dieselsite hpop, Vision Hauler 19.5's, No Limit intake, full on board air with 8.5 gallon tank, train horns, Sinister degas, DieselSite water pump, Big Wig rear sway bar, 7.3 clutch fan, BPD adapter
Wife's new ride 2019 F450 Lariet Ultimate CCLB 4x4
R&Rpowerstroke is offline
post #15 of 16 Old 06-19-2019, 05:45 PM
Corey@CNCFAB's Avatar
Quoted: 1457 Post(s)
Or there is the stage 1.5.
[SIZE="3"]For all your ford powerstroke needs. If you dont see what you are looking for on the website, please use the contact page and shoot us a message or
Part numbers will help alot too if they are not on our site.
post #16 of 16 Old 06-19-2019, 06:18 PM Thread Starter
cjchico4's Avatar
Quoted: 13 Post(s)
Yes but they don't offer it in a 10 blade which I want for the sound.
2007 F-250 CCSB 4WD 6.0 - Studded, Deleted, Coolant Filter, Sinister Piping, Blue Spring, 6" Zone Lift, 20x9 RBP's on 37" Toyo M/T's, KC stage 2 turbo, 5" Straight Pipe, CTS2, SPD, Gearhead, Warren, and Looney tunes, PHP Hercules FICM Tune, 4.56 Gears, Mag Hytec Trans Pan, Airdog Raptor Lift Pump, ...whatever else I forgot.
cjchico4 is offline
