SCT tuners-FYI - Page 2 - Ford Powerstroke Diesel Forum
 4Likes
post #11 of 18 Old 06-06-2019, 01:33 PM
Quoted: 17 Post(s)
I just received my new x4. Will it be ok to use as is, without any updates?
Mcflyfyter is offline
post #12 of 18 Old 06-06-2019, 05:48 PM
G8orFord's Avatar
Quoted: 2591 Post(s)
Garage
That's about the only way you'll want to use it assuming you are deleted.
Dexter
2017 F-250 Lariat CCSB FX4 SRW- A few Forscan tweaks
My old Truck, now son's truck:
2004 F-250SD Lariat CCSB FX4 SRW; SCT X4 w/custom tunes (currently
SPD)
FICM;
FICM Tuner (currently Atlas40);
Stage 1.5 Turbo;
Stage 1 HPOP;
VK688 Oil Cooler Relocate with coolant re-route;
Water Pump;
O-ringed Heads; ARP Studs; Fel-Pro Gaskets;
Coolant Filter;
DashCommand on PLX Kiwi2 + iMFD with EGT & Fuel/Oil Pressure
G8orFord is offline
post #13 of 18 Old 06-07-2019, 07:37 PM
Quoted: 17 Post(s)
Thank you, I just wanted to be sure and thought that might be worth a stupid question.
post #14 of 18 Old 06-10-2019, 11:33 AM
Quoted: 3 Post(s)
Ok, have a used SCT X4 that just arrived at home, probably has an older version so thanks for this update.
One question - if I put a tune like SRL on it, can I use the X4 to "delete" the EGR also. According to Gary @ SD, the tune doesn't include EGR delete. The EGR cooler has been physically deleted.
LooyvilleLarry is offline
post #15 of 18 Old 06-10-2019, 12:51 PM
Quoted: 13 Post(s)
Garage
Its more likely it can still be done with custom tunes BUT which custom tuner wants to be known for it and put the EPA crosshairs on themselves, probably not a good long term business plan. Guessing there may be a few more people trying to learn how to tune their own vehicles, This might start some interesting threads and hurt a few more pockets with the learning curve.
Teazr is offline
post #16 of 18 Old 06-11-2019, 12:54 PM
custom4584's Avatar
Quoted: 11 Post(s)
I spoke with a tuner today, he confirmed this is only for the canned tunes from sct. Any custom tuner is still able to tune out a check engine light for the egr. There will be a soft code but no check engine light.
jokester00 likes this.
2006 f-250 CC short box king ranch
custom4584 is offline
The Following 3 Users Say Thank You to custom4584 For This Useful Post:
jokester00 (06-11-2019), LooyvilleLarry (06-17-2019)
post #17 of 18 Old 06-12-2019, 06:07 AM
Heavy_GD's Avatar
Quoted: 3152 Post(s)
Garage
Feedback Score: 4 reviews
Do all tuners a favor and stop posting things like that in open forums.
GD
Originally Posted by djmaguire View Post
So says the internet... ...and so it shall be.
OK, thanks for the info. To show my ignorance, what is the problem with 3 nipples...
Heavy_GD is online now
post #18 of 18 Old 06-12-2019, 06:50 AM Thread Starter
Jjorgis5569's Avatar
Quoted: 79 Post(s)
There will always be a work around. No different from the when the gov mandated secondaries on 4 barrels couldn’t open 100%. Were just in an age of electronics. If there’s enough $ to be made, it will happen.
Jjorgis5569 is offline
