Need input on monitor - Ford Powerstroke Diesel Forum
post #1 of 6 Old 05-25-2019, 01:53 PM Thread Starter
Quoted: 9 Post(s)
So I have an 07 that needs a monitor. I have pretty much decided on an edge cts2 as it seems to be the only real choice.
Is there a reason not to go with the juice? I am pretty sure it will automatically defuel for high egt, and has lots of other programmable features.
I guess I am just wondering why everyone recommends the insight with a separate tuner.
Mcflyfyter is offline
post #2 of 6 Old 05-25-2019, 03:12 PM
darianmacdonald's Avatar
Quoted: 23 Post(s)
Edge’s tuning is not good at all. The juice in particular doesn’t tune the transmission either so they just rip transmissions apart.
There’s a reason why everyone goes with a monitor then an X4, as all the custom tunes available are far superior to any canned tuning. (Tunes that come with a device pre-loaded)
Sent from my iPhone using Tapatalk
2006 CCSB Lariat F-350
304,XXX KM
ARP studs, EGR Delete
SCT SF3 w/ GH & IDP Tunes
BW SXE 62/68/.83AR, Irate T4 Kit
4" Volant Turbo back exhaust
Driven Diesel RR w/ Fuelab Regulator
Isspro Boost, Fuel Pressure, Oil Pressure, HPOP Pressure Gauges
Edge Insight Monitor
FS2500 Oil Bypass Filtration
IDP Tuned 58V FICM
Coolant filtration
R4 Rear Air Ride
Bilstein 5100's
2-Way Compustar Remote Start/Alarm
Misc. mods
darianmacdonald is offline
post #3 of 6 Old 05-25-2019, 03:26 PM Thread Starter
Quoted: 9 Post(s)
Is there any tunes available that won't melt down pistons, or would I be stuck with stock tuning to be safe?
post #4 of 6 Old 05-25-2019, 03:45 PM Thread Starter
Quoted: 9 Post(s)
Ok, I guess the biggest question is how long does it take to flash tunes with the x4? Is it a 30 second thing, or a drawn out song and dance?
post #5 of 6 Old 05-25-2019, 04:45 PM
Quoted: 23 Post(s)
Pretty dang simple, probably takes a total of a couple minutes all said and done. And lots of safe tunes out there, just get them from a reputable dealer. Not going to melt pistons by any means.
304,XXX KM
IDP Tuned 58V FICM
Coolant filtration
R4 Rear Air Ride
Bilstein 5100's
Misc. mods
post #6 of 6 Old 05-25-2019, 08:03 PM Thread Starter
Quoted: 9 Post(s)
Well, I guess I will run with the insight. I will use the free accessory for a 100psi pressure gauge and I should be good to go. How do I get a stock flash with egr delete?
Similar Threads
Thread Thread Starter Forum Replies Last Post
Gauge pods or monitor ?? What do you monitor? Pstroke6.4 6.4L Performance Parts Discussion 3 11-14-2016 11:18 AM
Trouble with PSD dtc # 1316 bubba 1541 99-03 7.3L Powerstroke Problems 23 09-09-2009 06:23 AM
Glossery of Terms and Values mschn99 Dieselmann's Links 0 12-12-2006 08:38 AM
Trouble Codes Marty 99-03 7.3 Repair Help 0 11-19-2006 06:35 PM
Bully Dog and Edge monitor mix 06TWO50Diesel 6.0L Performance Parts Discussion 2 11-20-2005 05:15 AM
