Should I get ficm reflashed? - Ford Powerstroke Diesel Forum
 6Likes
  • 1 Post By jman37
  • 1 Post By HeavyAssault
  • 1 Post By darianmacdonald
  • 1 Post By partyman97_3
  • 2 Post By HeavyAssault
post #1 of 9 Old 05-08-2019, 04:10 AM Thread Starter
Quoted: 3 Post(s)
I have an 06 f250, bulletproof, sct x4 with IDP Ultimate X, 155/30 injectors. My truck gets outran by stock trucks (with canned tunes) all the time. So ive heard that a ficm reflash will give me my lost power. But ive also heard that some people have lost power by doing it. What do you guys suggest?
Gsale1 is offline
post #2 of 9 Old 05-08-2019, 05:35 AM
jman37's Avatar
Quoted: 317 Post(s)
Garage
Outran by what trucks exactly, another 6.0? If so, you have something wrong then. I would recommend a FICM flash. If you're going to run a super hot tune and you get a PHP tune, I wouldn't run anything but the 40 with a hot tune.
HeavyAssault likes this.
jman37 is online now
post #3 of 9 Old 05-08-2019, 07:58 AM
N.S.D.Q.
HeavyAssault's Avatar
Quoted: 767 Post(s)
Feedback Score: 3 reviews
Seems as you need more air....that means a turbo would be a better solution to your problem. Even adding a compressor wheel to a stock turbo might help. Dump in all the fuel you want, without air you ain't going anywhere fast.
Or are there other mods you failed to mention??
jman37 likes this.
Officially The Biggest Midget In The Game
HeavyAssault is offline
post #4 of 9 Old 05-08-2019, 01:33 PM Thread Starter
Quoted: 3 Post(s)
yeah I was talking about another 6.0. And if I send it to php do they give it a reflash with the tune or will I still have to take it to a dealer. If I do have to take it to a dealer do you know about how much it’d cost me?
Gsale1 is offline
post #5 of 9 Old 05-08-2019, 02:52 PM
darianmacdonald's Avatar
Quoted: 22 Post(s)
Originally Posted by Gsale1 View Post
yeah I was talking about another 6.0. And if I send it to php do they give it a reflash with the tune or will I still have to take it to a dealer. If I do have to take it to a dealer do you know about how much itíd cost me?
If you send it to PHP they will just flash it and then send it back to you. Donít have to take it to a dealer.
Places like FICMrepair offer PHP FICM tuner rentals, pay the full price for the FICM tuner ($400), they send it to you and you flash your FICM, send it back and you get $250 back. So ends up costing $150 and you have no down time on your truck donít have to worry about removing the FICM.
Sent from my iPhone using Tapatalk
jokester00 likes this.
darianmacdonald is offline
post #6 of 9 Old 05-11-2019, 04:57 PM Thread Starter
Quoted: 3 Post(s)
Update: I got the ficm tuner. Made a small difference but not $150 worth. What should I go to next? I’m tired of driving a snail
Gsale1 is offline
post #7 of 9 Old 05-11-2019, 05:09 PM
partyman97_3's Avatar
Quoted: 872 Post(s)
Garage
Sounds like @HeavyAssault hit the nail on the head. You probably need a bigger/different turbo to pump some air to keep up with the increase in fuel from the bigger sticks.
Maybe @[email protected] will chime in.
2003 F-350, CC, LB, 285/75/16, Autometer Gages, Fox 2.0's (Thanks to Corey), Sninister Bypass Coolant Filter, 4" Turbo Back,Leece-Neville 230 Amp Alternator, 6.4 litre starter
partyman97_3 is online now
The Following User Says Thank You to partyman97_3 For This Useful Post:
darianmacdonald (05-12-2019)
post #8 of 9 Old 05-12-2019, 03:41 AM
N.S.D.Q.
Quoted: 767 Post(s)
Update: I got the ficm tuner. Made a small difference but not $150 worth. What should I go to next? Iím tired of driving a snail
You didn't "loose power", you are not feeding the fuel the correct amount of air. Find a compressor wheel that you like, not expensive option since you seem to be on a budget. It's not a hard task to swap out, if you are lucky you may be able to do it on the truck.
Then you can see what changes happen which may lead you to a full Stage 2 turbo in the long run. MAYBE after that you would need to have the tuning adjusted but that's another conversation to have later.
post #9 of 9 Old 05-14-2019, 05:56 AM
Corey@CNCFAB's Avatar
Quoted: 1388 Post(s)
Feedback Score: 4 reviews
What are your boost numbers on datalogging?
[SIZE="3"]For all your ford powerstroke needs. If you dont see what you are looking for on the website, please use the contact page and shoot us a message or
Part numbers will help alot too if they are not on our site.
Similar Threads
Thread Thread Starter Forum Replies Last Post
Chasing an FICM voltage problem IdahoPowerstroke05 6.0 Motor problems 12 05-15-2019 07:38 PM
I'm getting a P0611-60 code (FICM) and not sure what to do... rsnider 6.0L Problems Forum 0 04-20-2019 08:49 AM
FICM U0105/U0306 craziness. Well... inconvenience. djmaguire 6.0 Motor problems 4 05-10-2018 11:00 AM
I was told I needed my FICM reflashed.. Big_HD_F250 6.0L Performance Parts Discussion 3 10-26-2017 04:17 PM
