better Themostat for the 6.0? - Ford Powerstroke Diesel Forum
 2Likes
post #1 of 11 Old 04-20-2019, 12:33 PM Thread Starter
Hartwig's Avatar
Quoted: 35 Post(s)
Hello,
does anyone know a thermostat for the 6.0 that opens more/wider, or can I machine it, for more opening at operating temperature?
My coolant is since the EGR delete approx. 10F colder in comparison with EGR cooler. (coolant pressure now 0-7 psi, with EGR cooler up to 18psi)
My camper is very heavy with 6.5 metric tons.
Today I measured the temperatures at the upper and lower radiator hose. At ECT 84C (183F) on the display there is only 66C (151F) on the upper hose and 44C (111F) on the lower hose. I think, the thermostat does not open completely. When I remove the thermostat, the engine warms up very slowly.
Is there a thermostat that opens further, so let more coolant to the radiator?
Thanks from Germany
Hartwig is offline
post #2 of 11 Old 04-20-2019, 04:23 PM
Quoted: 75 Post(s)
What is your end goal ? Rad temp does not matter engine temp does .
Sent from my LG-H915 using Tapatalk
jahcure04 is offline
post #3 of 11 Old 04-20-2019, 05:25 PM
Quoted: 13 Post(s)
Not an expert here so will also say that the speed of coolant is also important as it needs time to move it so this is why it may not be fully opening. So have worked with heat exchangers and more plate cooler so if you do tow a lot and it is warm when you do this you may also want to look at a bigger radiator or should I say one with more cores. The thing to be watching is the difference in oil and water temp towing or just normal driving. I hope this helps in your thinking.
tab57 is offline
post #4 of 11 Old 04-20-2019, 05:37 PM
Quoted: 244 Post(s)
Garage
The infrared gun may not read correctly -- different texture and color surfaces will affect the accuracy, a contact thermometer would be best. The thermostat should not open until 90c (195f) -- some heat transfer thru thermo siphon will happen in the upper hose, so it may seem to be passing coolant when it is not.
In my defense, I was unsupervised
2006 F250 Lariat FX4 cclb
Torque Pro and OBDLink MX bluetooth monitor
General note:
For all those wanting a premium silicone sealer Kubota 70000-73764 is the best your gonna find. This is a hybrid gray silicone that uses solvent rather than acid to start the curing reaction, this makes it safe for aluminum and and any surface that involves coolant.
Hydro is offline
post #5 of 11 Old 04-20-2019, 11:27 PM
repalmer's Avatar
Quoted: 396 Post(s)
Go with an OEM thermostat. The flow will be ok with it. There's a lot of us that tow heavy with the OEM one.
repalmer is offline
post #6 of 11 Old 04-21-2019, 12:51 AM Thread Starter
Hartwig's Avatar
Quoted: 35 Post(s)
I want to drive with lower coolant and oil temps. Under load EOT reaches over 212*F. Want to reduce this, better for HPOP, Injectors, O-rings...
Oil cooler is brand new.
Hartwig is offline
post #7 of 11 Old 04-21-2019, 05:05 AM
G8orFord's Avatar
Quoted: 2421 Post(s)
Garage
212 oil is fine. Some might say perfect under load conditions.
djmaguire and Hydro like this.
Dexter
2017 F-250 Lariat CCSB FX4 SRW- A few Forscan tweaks
My old Truck, now son's truck:
2004 F-250SD Lariat CCSB FX4 SRW; SCT X4 w/custom tunes (currently
SPD)
FICM;
FICM Tuner (currently Atlas40);
Stage 1.5 Turbo;
Stage 1 HPOP;
VK688 Oil Cooler Relocate with coolant re-route;
Water Pump;
O-ringed Heads; ARP Studs; Fel-Pro Gaskets;
Coolant Filter;
DashCommand on PLX Kiwi2 + iMFD with EGT & Fuel/Oil Pressure
G8orFord is offline
post #8 of 11 Old 04-21-2019, 06:50 AM
fetorino's Avatar
Quoted: 35 Post(s)
^^Agree. There is no reason to try and keep it cooler than that. Even poor quality oil doesn’t shear at that temp and could be run constantly at that temp.
04 F450
Studded 6.0 PSD backed by a Torqueshift
Dually Flatbed gooseneck hauler
BPD 7.3 fan clutch adapter
Sinister Bypass and coolant filters
Blue spring upgrade
Rotella T6
Ford Gold coolant
Magnaflow 4" downpipe FTE 4"in 5" out resonator to stack
FICM fixer rebuild and stock reflash
PHP 25hp heavy tow PCM flash
fetorino is offline
post #9 of 11 Old 04-21-2019, 06:26 PM
Quoted: 244 Post(s)
Garage
^^^Agree. The diesel engine runs more efficient at higher temperatures, 195F on the coolant is fine
General note:
Hydro is offline
post #10 of 11 Old 04-22-2019, 12:04 AM Thread Starter
Hartwig's Avatar
Quoted: 35 Post(s)
Most O-rings have a maximum working temperature of 110*C (230*F). I am dangerously close to this value. I suspect that the O-rings dies earlier in the HPO system than at low temperatures.
Hartwig is offline
