6.0 Tow Tune all the time - Page 2 - Ford Powerstroke Diesel Forum
 2Likes
post #11 of 15 Old 02-20-2019, 04:48 PM
cowens677's Avatar
Quoted: 26 Post(s)
I have run a tow tune and ficm tuning everyday for 5 years. I am not studded and tow regularly. I have more aggressive tunes but since I tow a 5th wheel once a month or so I just keep the tow tune loaded.
05' f250 6.0 powerstroke 4x4, KC 1.5 turbo, Odawg S2R intake, MPD CCV kit, Bulletproof 4 phase ficm, blue fuel pressure spring, dfuser coolant filter, MBRP turboback cat delete, PHP FICM tuner, SCT w/Gearhead SRL, 8k, unlimited tow, PHP 40 heavy tow tune, WPE White ghost, and Max tow. Edge CTS w/ EAS egt probe.
cowens677 is offline
post #12 of 15 Old 02-20-2019, 07:02 PM
ZMANN's Avatar
Quoted: 3949 Post(s)
Originally Posted by twood71 View Post
Do you guys that run tow tune have the what ya call jack break on?
Jake Brake
A compression release engine brake, frequently called a Jake brake or Jacobs brake, is an engine braking mechanism installed on some diesel engines. When activated, it opens exhaust valves in the cylinders, releasing the compressed air trapped in the cylinders, and slowing the vehicle.
Although Jake brake properly refers to the Jacobs brand of engine brakes, the term has become a genericized trademark and is often used to refer to engine brakes or compression release engine brakes in general, especially on large vehicles or heavy equipment.
They are often not allowed in to be used in towns as they create loud, clattering noises.
our tunes are not true Jake brakes but some mimic the behavior pretty well
6.0 flush pdf
ZMANN is offline
post #13 of 15 Old 02-21-2019, 10:33 AM
Master_Chase's Avatar
Quoted: 519 Post(s)
The truck I just picked up has a custom tow tune but the exhaust turbo what ever style jack brake is on and really sucks with it bogging down with the slightest throttle realese. Plus seems I have to push the throttle in to go more than I think it should be. Feels like half throttle needed just for normal take off.
I had the turbo brake on all the time after I found out about it, with Tow/Haul enable I often didn't need to hit the brakes till 25-30 MPH.
E̶a̶r̶l̶y̶ ̶2̶0̶0̶3̶ ̶6̶.̶0̶ ̶E̶x̶c̶u̶r̶s̶i̶o̶n̶ ̶f̶u̶l̶l̶y̶ ̶b̶u̶l̶l̶e̶t̶p̶r̶o̶o̶f̶e̶d̶,̶ ̶1̶5̶5̶/̶3̶0̶ ̶i̶n̶j̶e̶c̶t̶o̶r̶s̶,̶ ̶K̶C̶ ̶S̶t̶a̶g̶e̶ ̶2̶,̶ ̶a̶n̶d̶ ̶a̶ ̶l̶o̶t̶ ̶o̶f̶ ̶o̶t̶h̶e̶r̶ ̶s̶t̶u̶f̶f̶.̶ Cummins swap in progress. Thanks to everyone on the forum I have learned a lot.
The EGR does to your engine what smoking does to your lungs.
Remember you can always improve on a design until the EPA gets involved.
Master_Chase is offline
post #14 of 15 Old 02-21-2019, 05:13 PM
twood71's Avatar
Quoted: 66 Post(s)
Jake Brake
I'll admit I'm a bit paranoid, mainly hurting anything on this engine, this "turbo brake" was a pretty powerful feeling and so I turned it off. It just felt like it was pretty aggressive to me but the 6.0 is new to me.
A lot difference from this and my 6.7
So, I guess it really don't hurt the engine to have it on or maybe I mean hurt the turbo to have it on?
2015 Ford super Duty F-350 SRW 6.7L Power Stroke
2006 Ford Super Duty F-350 DRW 6.0 Power Stroke
twood71 is offline
post #15 of 15 Old 02-27-2019, 06:23 PM
Garage
Check how, by spraying carb cleaner around the pipe?
I am wondering how you would do this as well.
Lofar is offline
Similar Threads
Thread Thread Starter Forum Replies Last Post
KC Stage 3, stock injectors, new tune? delta17 6.0L Performance Parts Discussion 4 11-12-2018 09:49 AM
Custom Vs. Canned Tunes cody3905 99-03 7.3L General Discussion 1 09-19-2018 02:39 PM
TYRANT 0-200 SOTF ECM/TCM tune file question. harrelljr99 6.7 Performance Parts Discussion (2017-2019) 4 08-28-2018 07:16 AM
Started my delete...Tuner failed to load tune Old King Coal 6.7 Performance Parts Discussion (2011-2016) 25 11-09-2017 06:04 PM
Tune question midget General 6.7 Discussion (2011-2016) 1 02-13-2017 06:55 AM
