BD Diesel Uppipes V.S. Delete Pipe on a Stock 03 6.0L - Ford Powerstroke Diesel Forum
 2Likes
post #1 of 17 Old 11-21-2018, 06:03 PM Thread Starter
frozenpepper70's Avatar
Quoted: 7 Post(s)
Garage
Hi all,
I am not sure if I should go with the BD Upipe kit or retain my stock Y pipes and use the delete pipe (likely from Sinister or another quality brand). I would like to go with BD for the one piece design and quality. I read too many stories of delete pipes not fitting correctly.
However, in a stock truck, I may not see any benefit in using the BD system and, I would still need to purchase the coolant reroute tube. Further, the BD system might not be cost effective if I purchase a good delete kit.
What are your thoughts? Thanks!
frozenpepper70 is offline
post #2 of 17 Old 11-22-2018, 08:03 AM
323flint's Avatar
Quoted: 476 Post(s)
I would go with the bd, I’ve ran stock on my truck with a delete and still broke. If you have a 2003 make sure you get the bd up pipe for the 2003. It will come with the heat shield.
323flint is offline
post #3 of 17 Old 11-22-2018, 08:06 AM
323flint's Avatar
Quoted: 476 Post(s)
If you can update ur OIL FILTER COVER/ADAPTER to so you can run the updated turbo feed line
https://ktperformance.net/i-22629559...IaAtcZEALw_wcB
323flint is offline
post #4 of 17 Old 11-22-2018, 09:03 AM
R&Rpowerstroke's Avatar
Quoted: 101 Post(s)
Garage
Not trying to hijack this thread, but is this an easy install, and if I already own the updated line is there anything else I need to do this?
R&Rpowerstroke is offline
post #5 of 17 Old 11-22-2018, 09:47 AM
323flint's Avatar
Quoted: 476 Post(s)
It wasn’t bad, to me it one of those update that need to be done on the 2003, it comes with all the gaskets.
R&Rpowerstroke likes this.
323flint is offline
post #6 of 17 Old 11-22-2018, 10:23 AM Thread Starter
Quoted: 7 Post(s)
Garage
Wow! Thanks for the link. I do need to do that update as well. The quick connect fitting is starting to weep oil.
post #7 of 17 Old 11-22-2018, 10:24 AM Thread Starter
Quoted: 7 Post(s)
Garage
Okay, I will be sure to get the heat shield version.
Can you not pull the 03 heat shield and place it on the BD uppipes?
post #8 of 17 Old 11-22-2018, 10:27 AM
323flint's Avatar
Quoted: 476 Post(s)
Anything is possible lol
frozenpepper70 likes this.
323flint is offline
post #9 of 17 Old 11-23-2018, 07:20 PM
323flint's Avatar
Quoted: 476 Post(s)
Hi all,
Go on eBay look up item number 401552791082 its a y pipe from Rudy’s diesel sell looks just like bd
323flint is offline
post #10 of 17 Old 11-24-2018, 03:20 AM Thread Starter
Quoted: 7 Post(s)
Garage
Hi all,
Holy ****... Those prices are insane! Thanks! Will be shopping there from now on.
