How far can I go before I need studs??? - Ford Powerstroke Diesel Forum
 7Likes
post #1 of 16 Old 12-28-2017, 02:04 PM Thread Starter
Quoted: 4 Post(s)
Ok guys, I searched but could not find the answer to this. Hope you guys can tell me. How far can I go before I need to do head gasket and studs???
Recently did HPOP, Oil Cooler, EGR Delete, 4" non cat exhaust and SCTX4. Truck is running like a raped ape and is asking for more!!! LOL!!!
I want to get some PHP tunes for my X4 but I dont want to go past the point of kaboom with the head gaskets.
So what is the limit???
Thanks guys!!!
2004 F250 Crew Cab, Long Bed, 4X4, 4" MBRP Exhaust, SCT X4
paradise racing is offline
post #2 of 16 Old 12-28-2017, 02:13 PM
7.3lf550's Avatar
Quoted: 90 Post(s)
The day the truck drove off the dealers lot in 04 it needed head gaskets and studs.
TurboSpin likes this.
03 7.3l 550, FRx, 6637 mod, 4 inch turbo back, ccv delete, aih delete, HPx, Riffraffs OCR, Turbo-pyro-boost-coolant EV2 gauges, Bullydog GT tuner.
03 X 6.0 175/30 warren sticks, Livewire TS w/ warren tunes, Blue spring mod, atlas 40 ficm, 270amp dc power alt
Originally Posted by Heavy_GD View Post
goats lives matter.
7.3lf550 is offline
post #3 of 16 Old 12-28-2017, 04:50 PM
kcoyner's Avatar
Quoted: 216 Post(s)
Unless you've got a s#!+ load of money to dump in the truck right now I'd keep what you've got until you need HGs. If you're driving it like you stole it most likely it's not a question of "IF" you're going to need them, it's a question of "WHEN".
k
jokester00 likes this.
2005 F-350 Lariat DRW. WAAAAYYYY to much for 500 character limit
kcoyner is offline
The Following 2 Users Say Thank You to kcoyner For This Useful Post:
TommyW (01-02-2018)
post #4 of 16 Old 12-28-2017, 06:47 PM
backhoebill's Avatar
Quoted: 1273 Post(s)
Send a message via Yahoo to backhoebill
Talk to PHP and tell them how you drive, and let them surprise you with a safe tune.
Sent from my iPhone using Tapatalk
323flint likes this.
'06 F250 4x4, 280,xxx hard miles, ARP studded and o-ringed, Bulletproof EGR cooler, IPR coolant filter, blue spring, CSF 6028 intercooler, KC S2R, 4" turbo back, SPD & Herc FICM tune, SCT Livewire, PI converter, occasional Archoil, Mobil 1 Synthetic, Cat elc, Warn bumper and 16.5 winch in front & aftermarket mystery bumper in rear, dent in floorboard under throttle
backhoebill is offline
post #5 of 16 Old 12-28-2017, 07:33 PM
TheMadScientist's Avatar
Garage
Wouldn't that be a detuned factory tune?
backhoebill likes this.
2006 F-350 Lariat CCSB 6.0 4X4
2005 Excursion Limited 6.0 4x4
2003 F-350 Lariat CCDRW 6.0 4X4
1997 F-250 HD CCSB 7.3 4x4
1977 F-350 CCSB 4X4 12V Cummins
1972 Bronco Explorer Sport 5.0 H.O.
1972 F-350 CCSB 4x4 12V Cummins
1966 F-250 CCSB 429 4x4
1969 Mustang Fastback tubbed caged race car
1967 Mustang Fastback 427W shelby clone
1965 Mustang Fastback 347 T5 shelby clone
1956 F-100 built 429 C6
TheMadScientist is offline
post #6 of 16 Old 01-02-2018, 09:02 PM
Quoted: 8 Post(s)
Is there a specific stud or brand of stud that should be used now that I'm tuning the truck for more HP? I don't want to blow a head gasket and will be doing some upgrades this weekend, what head studs should I get that will prove to be more reliable/stronger than the stock?
TommyW is offline
post #7 of 16 Old 01-03-2018, 03:14 AM
kcoyner's Avatar
Quoted: 216 Post(s)
For me there is only brand. ARP, Match the studs to your HP goals.
k
kcoyner is offline
TommyW (01-03-2018)
post #8 of 16 Old 01-03-2018, 07:17 AM
Master_Chase's Avatar
Quoted: 520 Post(s)
ARP 625s are supposedly the best but they'll cost you
Are you taking the heads off and having them checked or just swapping the bolts for studs?
E̶a̶r̶l̶y̶ ̶2̶0̶0̶3̶ ̶6̶.̶0̶ ̶E̶x̶c̶u̶r̶s̶i̶o̶n̶ ̶f̶u̶l̶l̶y̶ ̶b̶u̶l̶l̶e̶t̶p̶r̶o̶o̶f̶e̶d̶,̶ ̶1̶5̶5̶/̶3̶0̶ ̶i̶n̶j̶e̶c̶t̶o̶r̶s̶,̶ ̶K̶C̶ ̶S̶t̶a̶g̶e̶ ̶2̶,̶ ̶a̶n̶d̶ ̶a̶ ̶l̶o̶t̶ ̶o̶f̶ ̶o̶t̶h̶e̶r̶ ̶s̶t̶u̶f̶f̶.̶ Cummins swap in progress. Thanks to everyone on the forum I have learned a lot.
The EGR does to your engine what smoking does to your lungs.
Remember you can always improve on a design until the EPA gets involved.
Master_Chase is offline
post #9 of 16 Old 01-03-2018, 09:19 AM
jokester00's Avatar
Quoted: 502 Post(s)
Garage
"Need" is relative term... Some of these trucks go their whole lifetime with the factory head bolts. Some of them didn't make it past the first few oil changes. It all depends on the truck and your right foot controlling the skinny pedal Studs are not a need, however, they do make the truck that much more reliable.
If I were in your shoes, like @kcoyner said, drive the thing and keep an eye on your engine parameters for now. While you're doing that, start putting $$ away in your rainy day fund for when you actually NEED HG's and stud it then!
-jokester
2005 F350 CCLB FX4 Lariat
SCT SF3 - Currently running PHP 80hp Daily Driver Tune with Atlas 40 FICM Tune
Edge Insight CTS2 monitor
Edge EAS EGT probe
Edge EAS Fuel Pressure Sensor
jokester00 is offline
The Following 2 Users Say Thank You to jokester00 For This Useful Post:
TommyW (01-04-2018)
post #10 of 16 Old 01-03-2018, 09:23 AM Thread Starter
Quoted: 4 Post(s)
ARP Head Studs are simply the best.
ARP 2000s are good, 625s are better.
625s are only required if your going balls to the walls!!!
The Following User Says Thank You to paradise racing For This Useful Post:
TommyW (01-04-2018)
