Update to IPR Coolant Filter - Page 9 - Ford Powerstroke Diesel Forum
 41Likes
post #81 of 89 Old 07-10-2018, 11:04 AM
Heavy_GD's Avatar
Quoted: 3152 Post(s)
Garage
Feedback Score: 4 reviews
be careful clocking those clamps like that, you could end up with a dent in the hood.
GD
Originally Posted by djmaguire View Post
So says the internet... ...and so it shall be.
Originally Posted by G8orFord View Post
OK, thanks for the info. To show my ignorance, what is the problem with 3 nipples...
Heavy_GD is offline
post #82 of 89 Old 07-10-2018, 11:18 AM
Quoted: 8 Post(s)
thanks. i did check it and have driven the truck since i installed the hoses. so far so good but i will double check.
i also installed a new Ford thermostat since my coolant temps would fluctuate from 200 down to 160 on the highway.
my deltas are much better now. last week on a road trip, they tended to stay at about 9-15 degrees. after the backflush, it has gotten down to 4-10 degrees.
sunofabeach is offline
post #83 of 89 Old 07-10-2018, 12:55 PM
Blow me to Bermuda!
nine9six's Avatar
Quoted: 82 Post(s)
Garage
I really need to get around to doing this. Mine is sitting in the box still. I wanted to tackle this when I was replacing my radiator and doing my flushes...so I could do the back-flush and mount this...but time was against me.
Now that I've been doing some serious pulling I got the wrench light from my Deltas getting too high and I'd like to try the back-flush / filter before I jump straight into the Oil Cooler.
Justin
2016 F250 6.7 PSD Lariat CCSB FX4 -|- 2006 F350 6.0 PSD Lariat CCSB FX4 -|- 1986 F250 6.9 IDI Lariat ECLB -|- 2008 F250 6.4 PSD XLT CCSB (sold!)
nine9six is offline
post #84 of 89 Old 02-02-2019, 09:30 PM
fetorino's Avatar
Quoted: 35 Post(s)
FWIW, I mounted mine in the same place, but since it's the newer version with the built in valves, I had to mount it filter up to get to the them.
G8orFord
I see you have a BPD remote mounted stock oil cooler. Where is the feed and return from your IPR filter Plummed to?
04 F450
Studded 6.0 PSD backed by a Torqueshift
Dually Flatbed gooseneck hauler
BPD 7.3 fan clutch adapter
Sinister Bypass and coolant filters
Blue spring upgrade
Rotella T6
Ford Gold coolant
Magnaflow 4" downpipe FTE 4"in 5" out resonator to stack
FICM fixer rebuild and stock reflash
PHP 25hp heavy tow PCM flash
fetorino is offline
post #85 of 89 Old 02-03-2019, 10:11 AM
G8orFord's Avatar
Quoted: 2593 Post(s)
Garage
See thumbnail.
Dexter
2017 F-250 Lariat CCSB FX4 SRW- A few Forscan tweaks
My old Truck, now son's truck:
2004 F-250SD Lariat CCSB FX4 SRW; SCT X4 w/custom tunes (currently
SPD)
FICM;
FICM Tuner (currently Atlas40);
Stage 1.5 Turbo;
Stage 1 HPOP;
VK688 Oil Cooler Relocate with coolant re-route;
Water Pump;
O-ringed Heads; ARP Studs; Fel-Pro Gaskets;
Coolant Filter;
DashCommand on PLX Kiwi2 + iMFD with EGT & Fuel/Oil Pressure
G8orFord is offline
post #86 of 89 Old 02-03-2019, 12:40 PM
F250SuperStealth's Avatar
Quoted: 17 Post(s)
Garage
I took a couple picks for @fetorino
I have the BPD relocate with the IPR coolant filter.
ID:	714251   Click image for larger version
2005 F250 Harley Davidson CCSB
Southeast Cylinder Heads with O-Rings
A1 Technologies H-11 Head Studs
Fel-Pro Headgaskets
River City Diesel Pushrods
Bulletproof Diesel Oil Cooler Relocate Kit
Bulletproof Diesel Billet Water Pump
PowerMax Turbo with KC Turbo's Billet Wheel
IPR Coolant Filter
SCT GTX Monitor/Tuner
Gearhead SRL+ Tune
PHP Atlas 40 FICM Tune
Autometer SPEK-Pro gauges
4" Magnaflow Exhaust
F250SuperStealth is offline
post #87 of 89 Old 02-03-2019, 01:01 PM
fetorino's Avatar
Quoted: 35 Post(s)
See thumbnail.
Ok in your signature you don't mention a ported manifold but I am guessing you welded up your EGR water outlet and that is why you go back to the degas instead of back to the EGR or EGR delete.
Or is there another reason?
How long have you been running the IPR filter in line to the BPD remote. It seems with the new gen IPR if it started clogging and the oil temp delta rose you could just flip the bypass to get home and clean it, correct?
04 F450
Blue spring upgrade
Rotella T6
Ford Gold coolant
fetorino is offline
post #88 of 89 Old 02-03-2019, 02:01 PM
G8orFord's Avatar
Garage
Freeze plug/casting plug in the front cover and a simple plate/gasket over the EGR cooler hole. I think I plugged the other coolant hole in the intake too, but can't remember exactly how right now. Maybe I didn't?
The setup has about 50k on it now, but my son adds about 140 miles a day to that since it's his truck now.
Yes, the latest IPR filter allows you to bypass the filter in case it's needed, but the main reason I upgraded to it over the original one was to simply be able to close the valves for cleaning without needing to drain the coolant down a little.
Dexter
SPD)
FICM;
Stage 1.5 Turbo;
Stage 1 HPOP;
Water Pump;
Coolant Filter;
G8orFord is offline
post #89 of 89 Old Today, 10:27 AM
Jt9
Quoted: 3 Post(s)
well I just ordered my new updated kit, external cooler and new coolant filter. Tons of info on this thread. Are they still performing like they should or are there other problems I need to address.
Jt9 is online now
