Tuner doing "weird" things to the truck? - Ford Powerstroke Diesel Forum
 2Likes
  • 1 Post By Lilpooh
  • 1 Post By backhoebill
post #1 of 7 Old 08-04-2017, 12:24 PM Thread Starter
CSDRacing's Avatar
Quoted: 15 Post(s)
Has anyone experienced "weird" behavior with having a custom tune? I have an SCT SF3 with an innovative diesel tune that i've had since 2013 and i am experiencing weird things with it. Such as once in awhile when i cold start my truck the truck will act gutless with the tune on, producing a lot of black smoke and no power. Return to stock and truck runs great. Shut the truck off, turn it back on and it'll be fine. Also I noticed recently the truck would stall while driving only when cold. It would fire right back up. All my pressures are good and also voltages are good. Returned to stock and the truck no longer stalled. So does anyone know of any issues like this? Thanks.
2003 Ford F-250 6.0 King Ranch
8'' lift on 38x14.5R20s
MotoMetal 962s
Fabtech traction bars
2007 Harley Davidson front end conversion
EGR delete
4'' turbo back to 7'' stacks
XDP coolant filtration system
L.E.D lights all around
Boss head unit
Power Acoustik GT42600
2 12'' Rockford Fosgate P1 subwoofers
Rhino lined front and rear bumpers
SCT tuner with a custom tune from Innovative Diesel
CSDRacing is offline
post #2 of 7 Old 08-04-2017, 02:28 PM
backhoebill's Avatar
Quoted: 1274 Post(s)
Send a message via Yahoo to backhoebill
I once experienced similar issues while running Looney at elevation. But I know my unison ring would stick after a while with Looney. So I had Vivian add a vane sweep, and it was cured. With the info you gave , that's all I can think of. Can you monitor VGT % cycles?
Sent from my iPhone using Tapatalk
'06 F250 4x4, 280,xxx hard miles, ARP studded and o-ringed, Bulletproof EGR cooler, IPR coolant filter, blue spring, CSF 6028 intercooler, KC S2R, 4" turbo back, SPD & Herc FICM tune, SCT Livewire, PI converter, occasional Archoil, Mobil 1 Synthetic, Cat elc, Warn bumper and 16.5 winch in front & aftermarket mystery bumper in rear, dent in floorboard under throttle
backhoebill is offline
post #3 of 7 Old 08-08-2017, 06:02 PM
Quoted: 4 Post(s)
EOT has to be above 150 degrees to get full power out of the truck. Maybe this is the issue?
6.0CopterPilot is offline
post #4 of 7 Old 08-08-2017, 11:13 PM
Powerstroke Techie
Lilpooh's Avatar
Quoted: 22 Post(s)
Feedback Score: 3 reviews
Did you check for any codes with a good scan tool, something that will read Ford's enhanced codes?
Adding tunes will bring out the gremlins in the motor, where as a stock tune will not.
jokester00 likes this.
2004 F350 CC DRW King Ranch
X-3 tunes by DJ'S,QT,GH,ID. Gryphon FICM tunes, ARP studs,Stage 1turbo,ATS coolant recirc lines,Swamp's 48v ficm,coolant filter,AD2,Snow Perf stage II,EGR delete,4" turbo back straight pipe,S&Bintake,Quad "A" pillar autometer gauges,Suncoast Tri Disk Conv.,Billet input shaft,Suncoast superduty rebuild kit,Trans-go shift kit,Mag-Hytec trans pan,CFM+ elbow,ccv mod,15K reese 5er,17" LCD TV/DVD,Cobra 29 Nitewatch CB
Lilpooh is offline
post #5 of 7 Old 08-09-2017, 06:12 AM
Flexybronc's Avatar
Quoted: 58 Post(s)
Garage
I agree with the above about getting it on a good scan tool that can do the enhanced tests and all codes. Kind of sounds like the unison ring sticking but not sure that would make it die. Definitely the lack of power and smoke. Maybe even a exhaust back pressure issue. May want to pull the sensor quick and make sure the tube is open down to the manifold. Also make sure ebp sensor isn't plugged itself.
05 CCSB 6.0 Bullet Proofed, 575rwhp 980rwtq Warren 190/75's, Barder 2.5, Warren and Gearhead tunes.
Sumped,6.7pump,Custom RR by ME
Full Billet Andy Warren Trans, 2" lift 35's
06 MazdaSpeed6-Access port, cobb stuff 13.8/101 26mpg
93 Wrangler 3/4 ton. 38's, Lockers, chromo shafts
98 Chevy 1500 5.7 ECSB mud tires. RIP chevy
Flexybronc is offline
post #6 of 7 Old 08-09-2017, 05:12 PM Thread Starter
CSDRacing's Avatar
Quoted: 15 Post(s)
I haven't had the lack of power issue in awhile, just seemed like it would happen once in awhile with only the tuner active. The only codes i have are for the egr delete, other than that the truck runs great with the programmer. It just acts weird sometimes, don't know why. Was just seeing if anyone had similar issues.
MotoMetal 962s
EGR delete
Boss head unit
post #7 of 7 Old 08-09-2017, 07:58 PM
Good to see that you are still around Rich.
Lilpooh likes this.
