Exhaust leak at cat - Ford Powerstroke Diesel Forum
post #1 of 3 Old 06-04-2017, 11:15 AM Thread Starter
cowens677's Avatar
Quoted: 26 Post(s)
Exhaust leak at cat
I have a mbrp turbo back exhaust and noticed I noticed I have a small leak at the cat and down pipe connection. I used to have to switch between test pipe and cat when I was due for smog and I need to order a new gasket to fix it. But what I was wondering is would this small leak cause loss in performance?
cowens677 is offline
post #2 of 3 Old 06-04-2017, 11:21 AM
Your Local Windex Brewer
CrazyS0b's Avatar
Quoted: 599 Post(s)
No, unless a cat is clogged you really aren't going to have issues at all. In emissions states they will throw a hissy fit, but the truck doesn't care. You could rip it out and just weld in a pipe and you would get a slight increase in performance (but again, back to the emissions testing thing...)
Pre-DPF diesels aren't really affected by the cat other than a slight increase in back pressure and a leak in or around it won't cause any issues.
2015 F350 SRW CCSB Lariat - Stock, for now
2008 F350 SRW CCSB FX4 - Airaid CAI, FloPro 5" straight pipe, Egr delete with BD intake elbow, SCT X4 with tunes from Tyrant Diesel, Monitored by CTS, Fox 2.0s. - SOLD
-Matthew
CrazyS0b is offline
The Following User Says Thank You to CrazyS0b For This Useful Post:
cowens677 (06-04-2017)
post #3 of 3 Old 06-04-2017, 11:34 AM Thread Starter
cowens677's Avatar
Quoted: 26 Post(s)
The cat is just for looks anyway there is nothing inside of it. I got sick of switching it back and forth so a pipe and a sledge hammer found its way inside of it. I did notice that the hairdryer noise out the end of the exhaust has been gone for awhile would a leak cause that not to be as prominent?
