PHP tunes, towing with a 6.0? - Page 18 - Ford Powerstroke Diesel Forum
 281Likes
post #171 of 246 Old 09-29-2016, 07:36 AM
Quoted: 176 Post(s)
Originally Posted by 6.0vanman View Post
My base strategy I downloaded with the SCT was VXCF9A4. The initial tune from Gearhead had really screwy shifting but on the revision he did a rollback VXCF4. I also increased the rev limiter to 4500. It's 90% better but it still holds the rpms too long and the torque converter locks are jolting. I'm not exactly sure if it's a different strategy code or whatever but I believe Gearhead used UGB1. I have no idea if that included a rollback to an older strategy but the IDP tunes are labeled UGB4. It appears PHP favors VXCF4H2. I hope I'm not giving away the special sauce but figure if Bill taught all these guys how to tune the 6.0 it must be ok?
We are talking about two different things, no? A strategy (ie., that controls the PCM like VXCF4) and then the type of coding used to write that strategy (ie., UGB4)?
I liked the TSD tune which was the SPD with fuel pulled. It spooled the turbo fast with more power down low but was supposed to have the top end fuel pulled so it would make only slightly more "top end" power over stock. I didn't run it for long since I happen to like cruise control and having a speedo. My main concern with any of these tunes, especially the higher power ones, is the vans have a smaller intercooler. I don't want to cook the pistons/valves/turbo by pushing the HP too high in order to spool up the turbo. They are great on the street where you can ease into it and wait for the turbo to light to avoid the smoke but off road in 4x4 on a grade from a full stop, or say digging out from deep sand, it looks like a Chinese coal burning plant out back.
I don't mind experimenting. That's half the fun.
It is a very deep hole if we get into the conversation of strategies, which does what, which strategies are updates of one another, etc.
I can tell you that VXCF9A4 is out of an 05 E series. On the PCM itself, you will see a sticker. The PCM code on that sticker is going to be UGB4.
UGB4 is your can be viewed as a label to let your tuner know what hardware is inside of the computer.
The VXCF9A4 is your base strategy or base calibration to be modified from.
Looking into your file, I did send you a VXCF4H2 strategy. Which is actually the reason your body control module isnt responding. Your computer thinks you are running an F series pickup
We do prefer to use the VXCF4 series as the rollback because it will utilize the exhaust back pressure reading to more accurately control the VGT. VXCF7 and VXCF9 formats will actually cause the truck to run off a "inferred EBP" reading. Basically meaning the truck calculates the EBP based off several attributes.
VXCF4 runs better, in our opinion, on VGT turbos.
If you ever switch to a nonVGT, I prefer a VXCF7 strategy.
Long story made short,
I screwed the pooch and wrote your tunes to the wrong calibration.
I will rewrite your files over to a VXCF4A2. This will enable the EBP sensor to manipulate the VGT while allowing function to the body modules.
I will be sure to send over some goodies for your trouble dealing with this!
michaelaiman and SparkyF250 like this.
Chatham036 is offline
The Following 2 Users Say Thank You to Chatham036 For This Useful Post:
6.0vanman (09-29-2016)
post #172 of 246 Old 09-29-2016, 07:46 AM
jmeaby's Avatar
Quoted: 65 Post(s)
Hard to beat php customer service. Can't wait to order some tunes for the truck once it is studded
04 f250 cc sb.
colt cam stage 2, kill devil diesel heads, stage 1 pushrods, odawg s3r, bd manifolds,odawg y pipe, 4 inch turbo back ss magnaflow exhaust, CSF 6028 intercooler, mishimoto radiator, billet turbo wheel, 05 style headlights, S&B intake, XDP coolant filter, tuned with Sct by PHP and IDP, BDS Dual rear add a leaf, Firestone ride rite airbags, rough country leveling kit on 35s, 2 12 inch kicker subs, infinity rear speakers, mb quart frontdoor speakers, mb quart amp, autopumpkin Android headunit, torque pro.
check me out on youtube and follow the build at 6.0 bros
jmeaby is offline
post #173 of 246 Old 09-29-2016, 09:11 AM
Quoted: 68 Post(s)
Thanks Jay!
I'm curious how the back pressure is affected when you remove the cat? And I've always been curious wrt to the vans and the 90 less HP that Ford detuned them to. Does the 80HP increase DD tune that I have mean over a stock truck (ie., 325) or the lower HP of 235 that the vans?
05 E350 4x4 6.0 99k: DC Power XP250A, Dieselsite coolant filter, ELC coolant, IPR GEN2 EGR delete, KCturbo Stage 1.5, updated turbo drain tube/oil feed line/STC fitting/OEM oil cooler, cat delete, high-flow muffler, SCT Tuner with IDP Xstreet tune, PHP Atlas 40 FICM tune, Blue Spring, billet fuel filter cap, BPD water pump, Scanguage II, AutoMeter fuel pressure and pyro gages, Tru-Cool Max 40,000 GVW transmission cooler
6.0vanman is offline
post #174 of 246 Old 09-29-2016, 10:09 AM
Quoted: 176 Post(s)
Thanks Jay!
The back pressure is measured in the exhaust manifold before the turbo. With the turbo being the main restriction, removing the cat doesnt have much effect on the EBP. It does serve a purpose in allowing the exhaust gas to escape quicker and help retain less heat.
The fuel curves on your 80 dd tune were mapped out based off a 8,000 lb F series truck. I am making the inference here, but I would believe you should be in the 380 - 400 rwhp range with our 80 dd tune.
post #175 of 246 Old 09-29-2016, 10:33 AM
Quoted: 68 Post(s)
Cool, thanks for the info. I have headstuds and all the heat mods in place so not too worried about the reasons why Ford detuned the vans. Not sure how the small intercooler plays into that but the extra HP is definitely nice to get the thing moving. My rig is 10,000lb loaded for bear on 35" tires.
michaelaiman likes this.
post #176 of 246 Old 09-29-2016, 10:51 AM
ZMANN's Avatar
Quoted: 4014 Post(s)
You ever think of sticking a truck pcm in her ?
6.0 flush pdf
ZMANN is offline
post #177 of 246 Old 09-29-2016, 03:07 PM
Quoted: 68 Post(s)
No, Cummins maybe.
post #178 of 246 Old 10-05-2016, 08:20 AM Thread Starter
Gaius's Avatar
Quoted: 78 Post(s)
So Jay called me and talked me into some different Tunes. A 40 Heavy Tow, a 100 Daily for just the camper, and a 200 Performance for daily driving. The 200 tune is just nuts coming from a 7.3 I'm not used to this much power haha
Sent from my SM-G930V using Tapatalk
Chatham036 and junior125 like this.
05 F350 Crewcab
98 Jeep TJ - wheeler
Gaius is offline
post #179 of 246 Old 10-18-2016, 12:26 PM
Quoted: 68 Post(s)
Long story made short, I screwed the pooch and wrote your tunes to the wrong calibration. I will rewrite your files over to a VXCF4A2. This will enable the EBP sensor to manipulate the VGT while allowing function to the body modules.
My body module is just dying to try a re-written tune....if I've somehow missed an email with an attached revision let me know. Thanks!
Chatham036 likes this.
post #180 of 246 Old 10-18-2016, 12:29 PM
Heavy_GD's Avatar
Quoted: 3155 Post(s)
Garage
Feedback Score: 4 reviews
If you havent heard from him by now I would send an email or call the shop
[email protected]
@Chatham036
GD
Originally Posted by djmaguire View Post
So says the internet... ...and so it shall be.
Originally Posted by G8orFord View Post
OK, thanks for the info. To show my ignorance, what is the problem with 3 nipples...
Heavy_GD is offline
The Following User Says Thank You to Heavy_GD For This Useful Post:
6.0vanman (10-18-2016)
