Excursion steering play fix? - Ford Powerstroke Diesel Forum
6.0L Ford Excursion Discussion This forum is for topics relating to the excursion only.
post #1 of 6 Old 03-27-2019, 06:59 AM Thread Starter
ochencho's Avatar
Has anyone replace their steering box with a red head or PSC box? Which one would be better. My understanding RH only changes bearings and seals, not the gears! In the other hand PSC is a different design in itself . Beefier shaft as we値l . Any feedback would be appreciated it?
ochencho is offline
post #2 of 6 Old 03-27-2019, 04:07 PM
DieselDC's Avatar
Quoted: 682 Post(s)
Didn稚 know pcs made one. I know they have a Saginaw pump but not an actual steering gear like RH. People swear by. I don稚 read too many complaints or any at all about rh. Blue top is another good brand (worked at rh then branched out on their own). I have a Blue top and it works fantastic. Tighter and little play. Maybe I値l try a rh when I get a chance.
覧覧耀ignature覧覧
~Don稚 overthink something simple~
...:uptight people suck:...
DieselDC is offline
post #3 of 6 Old 03-31-2019, 01:16 PM
Fighting The Good Fight's Avatar
Quoted: 2 Post(s)
I️ replaced My steering box with a red head. It was one of the best things I️ ever did. Took all the play out of the steering and it is smooth. I️ put It in my Ex in 2012. It is still going strong.
04 Excursion
ATS Stage 3 Trans.
Industrial 190/75
KC Stage 3 Turbo
Odawg S3R Intake
Mishimoto Intercooler
58 Volt FICM
MBRP 4 Exhaust
Bulletproof EGR Deleted
ARP studs
SCT Livewire EDP Tunes
Sinister Diesel Regulated Return
Superduty front end swap 33s leveled
05 front bumper
S&B cold air intake
So much more I can稚 list it all.
Fighting The Good Fight is offline
post #4 of 6 Old 03-31-2019, 01:42 PM
Quoted: 2 Post(s)
Also depending on the application, such as big tires, AGR makes a rock ram with hydraulic stabilizer, gear box and power steering pump that is awesome. I️ had One on a lifted 04 F250.
04 Excursion
ATS Stage 3 Trans.
Industrial 190/75
KC Stage 3 Turbo
Odawg S3R Intake
58 Volt FICM
MBRP 4 Exhaust
ARP studs
05 front bumper
S&B cold air intake
post #5 of 6 Old 04-04-2019, 01:57 PM
Redbliss's Avatar
I tightened up the play on the gearbox a whole turn and lost my wheel return. Brought it back a 1/2 turn and took some of the play out but still has some play and wanders on the highway. 160,000 miles and running 35's. Replaced everyrhing but the gearbox. Guess its time.
Redbliss is offline
post #6 of 6 Old 04-06-2019, 09:39 AM
I'd call up PSC and ask if they have any more info they can give you. There is no info online that gives conclusive evidence what is internal.
Motorwagen is offline
Similar Threads
Thread Thread Starter Forum Replies Last Post
3rd Steering Stabilizer in 1 month... six.blow530 6.0 Drivetrain problems 2 10-12-2018 02:00 PM
Steering wheel play ablackwell87 99-03 7.3L General Discussion 5 04-13-2018 02:14 PM
Steering Pump Bad.....Round 3! -Falcon- 6.0L Problems Forum 2 02-06-2018 08:49 AM
2014 F350 steering play ??? lindner115 General 6.7 Discussion (2011-2016) 21 04-07-2017 04:18 AM
steering wheel more play left than right? saleen9973 Suspension & Steering 3 08-21-2016 04:14 PM
