Blue smoke - Ford Powerstroke Diesel Forum
6.0L Ford Excursion Discussion This forum is for topics relating to the excursion only.
post #1 of 3 Old 03-10-2019, 04:18 PM Thread Starter
Blue smoke
I have an excursion as a family vehicle it has about 70k miles on it. I use it rarely to tow my camper but its mainly just a leisure vehicle on the weekends for the family. I’ve realize that whenever I tow the camper on long drives it starts puffing blue smoke. Should I be worried? I’ve read it could be injectors or head gaskets, just wanted to see some input. Keep in mind I dont know much about diesels at all.
Longislford is offline
post #2 of 3 Old 03-10-2019, 05:07 PM
G8orFord's Avatar
Quoted: 2591 Post(s)
Garage
Blue smoke is usually oil. Probably not injectors or headgaskets.
Dexter
2017 F-250 Lariat CCSB FX4 SRW- A few Forscan tweaks
My old Truck, now son's truck:
2004 F-250SD Lariat CCSB FX4 SRW; SCT X4 w/custom tunes (currently
SPD)
FICM;
FICM Tuner (currently Atlas40);
Stage 1.5 Turbo;
Stage 1 HPOP;
VK688 Oil Cooler Relocate with coolant re-route;
Water Pump;
O-ringed Heads; ARP Studs; Fel-Pro Gaskets;
Coolant Filter;
DashCommand on PLX Kiwi2 + iMFD with EGT & Fuel/Oil Pressure
G8orFord is online now
post #3 of 3 Old 03-28-2019, 06:55 PM
6.0Castle's Avatar
Quoted: 19 Post(s)
Garage
If you use it rarely, I would "burn that candle" when it is up and running. Sounds like oil burning off the turbo, after sitting for too long...just a hunch
cheers
2004 Excursion
183K and purring, Toyo R/T 285s, 4" Flo Pro, Atlas-40 FCIM tune, SCT X4 with looney, RiffRaff coolant filter/CAC boots, Hewitt/Marshall gauges (Pyro/Turbo/Fuel/EOT/ECT), Nations TAD-185 alternator, Big 3 cable/zoodad mods, Mobile 1, Delo ELC, when does it end?!?
6.0Castle is offline
Similar Threads
Thread Thread Starter Forum Replies Last Post
Another Blue smoke question, injectors?? TSmylie78 99-03 7.3L General Discussion 16 01-15-2020 06:17 PM
Faint Blue Smoke Stroked96 99-03 7.3 Motor Problems 1 07-02-2018 10:38 PM
Blue smoke tony013 99-03 7.3L Powerstroke Problems 9 09-26-2017 01:55 PM
Previous: Blue smoke start up when cold. Now blue at startup when warm too iamnotatwork 99-03 7.3 Motor Problems 6 10-07-2016 01:51 PM
