New Excursion Owner - Ford Powerstroke Diesel Forum
6.0L Ford Excursion Discussion This forum is for topics relating to the excursion only.
post #1 of 5 Old 02-18-2019, 05:44 AM Thread Starter
New Excursion Owner
So I jumped in water and ventured into the Excursion hype. I have a 2003 6.0 Excursion. It has an EGR delete that the previous Owner had done. The only thing I've done to it is put an S&B cold air intake on it. I've bought a coolant filter along with an aluminum gas bottle from dk engine parts. I'll see if this link to a picture of my truck works...http://imgur.com/a/7ifrldz
AstrosFan is offline
post #2 of 5 Old 02-18-2019, 06:07 AM
Thesoulless's Avatar
Quoted: 8 Post(s)
Garage
That's a good looking truck! The PO was nice enough to put on the newer mirrors and 20s for you (also the powerstroke badge adds 5hp!). There was a post on here somewhere about the cap coming with the aluminum degas bottles not performing to OEM specs, I believe it was a Mishimoto, so that'd be something to look out for (it was either here or on PowerstrokeNation, and could have been an isolated incident). The best upgrade I did to my Ex was adding a rear sway bar, made a world of difference. Enjoy it, and I hope you've already got something like the Torque app or Forscan running gauges.
2003 Excursion 6.0, 2004 front cover, Stock head bolts, unknown EGR delete, 4" Diamond Eye turbo back exhaust, Magnaflow 60110 catalytic converter (makes the '03 whistle livable), Hellwig Sway bar, Roadmaster Active Suspension, Gearhead tunes - 8k tow or SRL depending on my level of 6.0 paranoia, unknown work by previous owners...
Thesoulless is offline
post #3 of 5 Old 02-18-2019, 06:26 AM Thread Starter
Thesoulless thank you, Yes, the PO or the dealer hooked me up. I want to get a cts2 insight to be able to monitor every and I have looked into the torque pro app. Another update that I want to do is the blue spring. I don't know if it already has it. I guess the only way to find is to to take it apart.
post #4 of 5 Old 02-18-2019, 06:53 AM
Quoted: 8 Post(s)
Garage
If you're able to check fuel pressure that will tell you if you need it, just make sure you check while driving - the pressure will dip as the go pedal is pushed but shouldn't get below 45psi. I did the blue spring, but the kit was by Dorman and I may swap it out for an OEM one, my fuel pressure reads in the mid 80's. I can' speak for the Insight, I had an old cellphone lying around (I buy cheap phones) and use that for Torque and Forscan.
post #5 of 5 Old 02-18-2019, 07:08 AM Thread Starter
Thesoulless, that's a Texas size 10-4.
Similar Threads
Thread Thread Starter Forum Replies Last Post
First Time 6.0L Excursion owner Luisv Introductions 1 01-20-2018 01:23 PM
Yes, another new Excursion owner abakos 6.0L Ford Excursion Discussion 0 04-05-2017 05:37 PM
Another new Excursion owner Michael Mann 6.0L Ford Excursion Discussion 6 03-15-2017 06:50 PM
Proud new owner of 2003 Excursion 6.0 lightfoot6337 Introductions 1 02-05-2017 09:24 PM
New Excursion owner Barfbag Introductions 2 01-25-2017 08:45 PM
