Probably beating a dead horse. - Page 2 - Ford Powerstroke Diesel Forum
6.0L Ford Excursion Discussion This forum is for topics relating to the excursion only.
 1Likes
post #11 of 13 Old 03-20-2019, 06:01 PM Thread Starter
deltabygod's Avatar
Quoted: 2 Post(s)
I agree it is not all the injectors, i was able to get a computer on the truck and it was reading codes on injectors 3 and 5. As well as a code for glow plug 1.
deltabygod is offline
post #12 of 13 Old 03-20-2019, 06:23 PM
djmaguire's Avatar
Quoted: 1581 Post(s)
Garage
This situation is somewhere between tragic and mysterious. I say mysterious because shops tend to have outcomes that are either very simple (i.e., good) or soap opera-ish. This is obviously soap opera-ish and that always makes me wonder if it is by their design.
Check to make sure that your FICM connectors are solidly seated. I could see someone leaving them loose in order to "fix" it for you later with either a new FICM or a new set of injectors.
...or they made a mistake. Under the circumstances... I'd certainly believe that to be possible, too.
2004 F550 CC Lariat
BPD oil cooler relocation and upgraded EGR cooler (spooled), BPD oil bypass filtration, aFe Magnum Force CAI, Mishi radiator, 7.3L fan clutch, EC1 ELC, XDP coolant bypass filtration, '08 trans pan/filter, PTP direct clutch solenoid, blue spring, 6.4 starter, MBRP y-pipe, BD boots/clamps, '05 intake elbow, ccv reroute, Torque Pro + OBDLinkô LX, Autometer EGT
djmaguire is offline
post #13 of 13 Old 03-20-2019, 06:32 PM Thread Starter
deltabygod's Avatar
Quoted: 2 Post(s)
I never thought of that. So i did call this shop amd of coarse they can get me injectors in affordably.
The odd part is that the problem has been intermitent. When i asked him about that he said it is the fuel side which is the worst possible case cause it will cause the injector to stay open and weld a piston.
I never honostly thought of checking the ficm plugs and will do that tomorrow.
