Need help! Dead pedal, no power til at operating temp - Ford Powerstroke Diesel Forum
6.0L Ford Excursion Discussion This forum is for topics relating to the excursion only.
post #1 of 2 Old 10-05-2018, 08:18 AM Thread Starter
2004 Ex 6.0 (build date of 02/2003) with 290k, monitor engine parameters with a scangauge ii.
Threw a P2285 and running rough, I changed the ICP sensor and no change. Towed to Dealership where they updated FICM, TCM & PCM. Dealer claimed “FICM passed test by small margin” & “possible FICM issue”. Found #1 & #6 injectors has no power.
Replaced all 8 injectors.
KOEO FMP is 48, FVP is 12, FLP is 12.
Master ASE friend suggested stuck turbo vane or VGT stuck. Tried a new VGT, no change. Did the VGT relearn, still no change.
Still has a dead pedal, chugs until 150į then idle smooths out. It takes until its at 165+ before it will even move in gear. It stumbles and has bad hesitation, but once it gets over 1k, it clears up and has minimal lag from a stop for maybe 10 min. Good throttle response after & has no issue getting up to 24psi.
KOEO ICV is .65v and ICP shows 447. I believe spec is .2 and 0 - would that indicate another faulty ICP/wiring issue?
Schaf5_04_6OH is offline
post #2 of 2 Old 10-05-2018, 09:49 AM
djmaguire's Avatar
Quoted: 1581 Post(s)
Garage
I vote harness issue. Because of your code and ICP/ICPv observation, I'd be looking at the ICP wiring internal to the harness.
You can read more about temperature-dependent wiring shorts here:
https://www.powerstroke.org/forum/6-...s-chafing.html
...with a small addendum here:
https://www.powerstroke.org/forum/ge...iscellany.html
2004 F550 CC Lariat
BPD oil cooler relocation and upgraded EGR cooler (spooled), BPD oil bypass filtration, aFe Magnum Force CAI, Mishi radiator, 7.3L fan clutch, EC1 ELC, XDP coolant bypass filtration, '08 trans pan/filter, PTP direct clutch solenoid, blue spring, 6.4 starter, MBRP y-pipe, BD boots/clamps, '05 intake elbow, ccv reroute, Torque Pro + OBDLinkô LX, Autometer EGT
djmaguire is offline
