Purchasing question - Ford Powerstroke Diesel Forum
6.0L Ford Excursion Discussion This forum is for topics relating to the excursion only.
 10Likes
post #1 of 13 Old 09-02-2018, 05:15 AM Thread Starter
Purchasing question
Hello, new here.
I have the opportunity to purchase a 2003 6.0 excursion limited with 59k miles on it. One owner, spent its life driving 4K miles a year between Toronto and Florida. Original window sticker and ever service record itís ever had. I have never seen a 15 year old vehicle as clean as this. The original plastic protector covers are on all the wood trim, under the floor mats, on the radio etc. Loaded without sunroof.
Primary use would be a daily driver/family hauler with occasional towing duties.
I truly know very little about the 6.0 powerstroke. I have read the horror stories and also many success stories about them.
Asking price is $21,9
Any help would be appreciated
Thank you,
Mike
Sent from my iPhone using Tapatalk Pro
Mslund1 is offline
post #2 of 13 Old 09-03-2018, 07:55 AM
Sounds like a great find! Not many left in good original condition. The only downside will be that you will still have to address all of the same 6.0 issues that we have all had. Search around the forum here for "bulletproof 6.0".
You might have good life left out of it, but historically the engines that were driven lightly are a ticking time bomb. If you are ok with having about $6k set aside for when it happens, then I say go for it. I love my Ex and couldn't be happier with it.
Sent from my SM-G930V using Tapatalk
Steamin' is offline
post #3 of 13 Old 09-03-2018, 08:00 AM
I forgot to mention, but even in top condition 21,9 seems ridiculous. If it already had reputable engine work then ok, but seems high.
Steamin' is offline
post #4 of 13 Old 09-03-2018, 08:04 AM
Spud Monkey's Avatar
Quoted: 59 Post(s)
For almost 22k you can buy something half that price and buy extra spare engine from the stealership for backup and still come out with money for goodies to bolt on. I would take that much and invest in 6.7 than a 6.0
Spud Monkey is offline
post #5 of 13 Old 09-03-2018, 12:59 PM
G8orFord's Avatar
Quoted: 2512 Post(s)
Garage
They don't make 6.7 Excursions.
I don't think $22k is TOO far out for a 4wd Excursion Limited with 60k on the clock. $18k would be more realistic though. A 2wd should probably be more like $12-$14k in that condition. They don't make 'em anymore or anything similar, so an owner that's willing to wait around a little, can get pretty much what they want for it.
As far as issues with the low mileage and rare use, assuming it has been properly maintained, the only things that would concern me would be:
The turbo - possibly seized unison ring. Easily fixed or replaced.
The coolant - Probably still Ford Gold and 15 years old.
The oil temp to coolant temp delta - relates to the previous item
The fuel system - Diesel sitting in a tank for long periods can grow algae. Easily fixed with some biodiesel and a couple of filter changes.
SparkyF250 and R&Rpowerstroke like this.
Dexter
2017 F-250 Lariat CCSB FX4 SRW- A few Forscan tweaks
My old Truck, now son's truck:
2004 F-250SD Lariat CCSB FX4 SRW; SCT X4 w/custom tunes (currently
SPD)
FICM;
FICM Tuner (currently Atlas40);
Stage 1.5 Turbo;
Stage 1 HPOP;
VK688 Oil Cooler Relocate with coolant re-route;
Water Pump;
O-ringed Heads; ARP Studs; Fel-Pro Gaskets;
Coolant Filter;
DashCommand on PLX Kiwi2 + iMFD with EGT & Fuel/Oil Pressure
G8orFord is offline
post #6 of 13 Old 09-03-2018, 01:27 PM
SparkyF250's Avatar
Quoted: 3174 Post(s)
Garage
Don't fall fot the "it needs bulletproofed right away" line. I bought my 05 with 141k on it, never tuned, original exhaust, unknown maintenance. It has 157K on now and all I've done was change the coolant, back flush the oil cooler, replaced the unison ring in the turbo, replace tie rod ends and shocks. I drive it and pull a stock trailer with it. If it blows the head gaskets I'll fix it then. I'm not taking apart a perfectly good engine to "make it better"
Like G8torFord said, they don't make em anymore so if you like it make an offer on it.
5.9and6.0, hogbody and Got Dirt? like this.
Sparky
2005 F250 CCSB KR 4x4 6.0 4" Flo-Pro,
Fox 2.0s, Toyo ATs, CTS2 Pro, Blue Spring, BPD 7.3 Fan Clutch, IPR Coolant Filter
2000 F350 SCLB Dually 4x4, 7.3 6 Speed Hydra, CTS2, S&B Air, 4'' SS Diamond Eye
2005 Explorer XLT 4x4 Mountaineer,
Toyo ATs, Wife's grocery getter
1993 F150 4x4, 302 5 speed, winter truck
SparkyF250 is offline
post #7 of 13 Old 09-03-2018, 02:28 PM
Got Dirt?'s Avatar
Quoted: 177 Post(s)
Garage
Tim do.
People are like dirt. They can either nourish you and help you grow as a person or they can stunt your growth and make you wilt and die.
Plato
2006 Super Duty F-250 Lariat CCSB: Edge CTS Insight - BPD FICM - Sinister Diesel Coolant Filter - ProComp 20" wheels - Toyo M/T 35's - ReadyLift w/ Bilstein 5100's - 4" MagnaFlow Exhaust - '08 Transmission Pan and Filter..... and a Partridge in a Pear Tree!:wink[3]:
Got Dirt? is offline
post #8 of 13 Old 09-03-2018, 04:25 PM
G8orFord's Avatar
Garage
Let me rephrase. Ford doesn't make the Excursions anymore and anyone selling a 6.7 Excursion is 1) not selling it for $22k and 2) they are mating a minimum 13 year old wrecked Excursion rear half to the newer truck front end.
But those are cool.
Dexter
SPD)
FICM;
Stage 1.5 Turbo;
Stage 1 HPOP;
Water Pump;
Coolant Filter;
G8orFord is offline
post #9 of 13 Old 09-03-2018, 04:42 PM
Got Dirt?'s Avatar
Quoted: 177 Post(s)
Garage
But those are cool.
I know I was just messing with you but they are really cool aren't they???? Sorry to highjack this thread but it's like EX porn - oh baby........
G8orFord likes this.
Plato
post #10 of 13 Old 09-04-2018, 01:06 AM
hogbody's Avatar
Quoted: 77 Post(s)
Garage
If you can afford it go for it. Just bought this 2003 with 6l a few weeks ago. 1 owner and 96 maintenance reports on carfax. Never wrecked, all original and only 295000 miles.
hogbody is offline
