Necessary upgrades for 6.0 Excursion - Page 2 - Ford Powerstroke Diesel Forum
6.0L Ford Excursion Discussion This forum is for topics relating to the excursion only.
 2Likes
post #11 of 21 Old 04-04-2018, 04:59 PM
Originally Posted by 6.0Castle View Post
I know it ain't glamorous, but getting the extended-length struts for the back glass hatch made such a huge difference. If you go back there a lot and you are on the taller side, very necessary.
I can't agree more to this. We put longer struts on and it made all the difference! I no longer hit my head on the hatch plus it's back to its original strength in the colder weather. Can't beat that for just over $20.
Pazzle Dazzle is offline
post #12 of 21 Old 04-08-2018, 09:52 AM
jamierayo's Avatar
Quoted: 9 Post(s)
My ‘03 is a 7.3, so I can’t comment on your drivetrain needs.
The extended struts for the rear hatch are well worth it. Tow mirrors are also a great addition if you don’t have them. Even if you do, the ‘08 style mirrors are a big improvement over the ‘03 tow mirrors.
A winter front & some kind of high idle switch is nice if you’re somewhere cold.
For the suspension, I put RAS on the rear & Timbrens on the front. The RAS is great, & imo negates the need for new springs or a rear sway bar . No sag when towing, plus less sway & more travel all the time. The Timbrens are a nice improvement over stock, but new front springs would be even better.
Rancho Shocks likes this.
His:
1999.5 F350 XLT Crew Cab Dually Flatbed 4x4 7.3L
PHP Hydra, S&B Intake, MBRP 4" Exhaust, Gauges, Harpoon mod, Hutch mod, 6.0 Cooler, Airbags, 08 Mirrors, Brush Guard w/2 9" HID's & 2 4" Lightforce, 100 gal Transfer Tank
Hers:
2003 Excursion XLT 4x4 7.3L
PHP Hydra, S&B intake, MBRP 4 Exhaust, SPX 5+5 Wheel, Gauges, 6.0 Cooler, 08 Mirrors, RAS, Timbrens
jamierayo is offline
post #13 of 21 Old 05-08-2018, 07:38 AM Thread Starter
Best Suspension/Exhaust for 03 4x4 Excursion
Hey guys..i'm in desperate need of upgrading my factory suspension. I've looked into upgrading the leaf springs and shocks to the v code and b code but economically, it looks like I can invest in a 2" lift kit that will replace the front leaf springs and they'll block the rear. Also the lift will replace the shocks. Rough Country has a kit that is around $699 and I was wondering if any of you had any experience with them. My truck is not a performance truck, just a kid/boat/camper hauler that is bone stock except for the EGR delete. Any suggestions on suspension upgrades that aren't crazy expensive? Also, it has the factory exhaust system that I would like to upgrade...any suggestions on that? Thanks for your help!
mhmathias3 is offline
post #14 of 21 Old 05-08-2018, 07:43 AM
Heavy_GD's Avatar
Quoted: 3044 Post(s)
Garage
Feedback Score: 3 reviews
@[email protected] is your guy. @ZMANN @Rancho Shocks
GD
Originally Posted by djmaguire View Post
So says the internet... ...and so it shall be.
Originally Posted by G8orFord View Post
OK, thanks for the info. To show my ignorance, what is the problem with 3 nipples...
Heavy_GD is offline
The Following User Says Thank You to Heavy_GD For This Useful Post:
ZMANN (05-08-2018)
post #15 of 21 Old 05-08-2018, 09:55 AM
ZMANN's Avatar
Quoted: 3756 Post(s)
rough country is pretty low on the lift quality Totem pole
i would be looking at maybe a little better grade but no matter what you do I would skip the included shocks ( might have to piece a kit)
the shocks will really impact the ride quality
6.0 flush pdf
ZMANN is offline
post #16 of 21 Old 10-26-2018, 09:54 AM
BigCountry916's Avatar
Quoted: 8 Post(s)
Garage
Where did you get those??
2004 Excursion Eddie Bauer
ARP Head Studs
Bullet Proof Air Cooled Oil Cooler
Upgraded EGR
AFE Stage 2 Intake
4" Turbo Back MBRP Exhaust
Bullet Proof Billet Water Pump
2005 Grille (Paint Matched All White)
Black Oak 20" LED Light Bar
2.5 " Leveling Kit (I want the Icon 5" Lift)
Bilstein Shocks
Moto Metal 20x10" Wheels
33" Atturo Trail Blade X/T Tires
BigCountry916 is offline
post #17 of 21 Old 10-26-2018, 10:02 AM
6.0Castle's Avatar
Quoted: 18 Post(s)
Garage
http://www.liftsupportsdepot.com/
Like I said before, you will see a big improvement. Might want an extra hand for the back glass, it's shockingly heavy!
2004 Excursion
183K and purring, Toyo R/T 285s, 4" Flo Pro, Atlas-40 FCIM tune, SCT X4 with looney, RiffRaff coolant filter/CAC boots, Hewitt/Marshall gauges (Pyro/Turbo/Fuel/EOT/ECT), Nations TAD-185 alternator, Big 3 cable/zoodad mods, Mobile 1, Delo ELC, when does it end?!?
6.0Castle is offline
post #18 of 21 Old 10-26-2018, 10:09 AM
Master_Chase's Avatar
Quoted: 514 Post(s)
If you want it to go up even higher the struts for an Audi TT 2 door coupe 2000 trunk lift support also fit and I have the StrongArm 6421 on my lifted excursion, only downside to them is my sister has to do a little jump to grab the handle.
E̶a̶r̶l̶y̶ ̶2̶0̶0̶3̶ ̶6̶.̶0̶ ̶E̶x̶c̶u̶r̶s̶i̶o̶n̶ ̶f̶u̶l̶l̶y̶ ̶b̶u̶l̶l̶e̶t̶p̶r̶o̶o̶f̶e̶d̶,̶ ̶1̶5̶5̶/̶3̶0̶ ̶i̶n̶j̶e̶c̶t̶o̶r̶s̶,̶ ̶K̶C̶ ̶S̶t̶a̶g̶e̶ ̶2̶,̶ ̶a̶n̶d̶ ̶a̶ ̶l̶o̶t̶ ̶o̶f̶ ̶o̶t̶h̶e̶r̶ ̶s̶t̶u̶f̶f̶.̶ Cummins swap in progress. Thanks to everyone on the forum I have learned a lot.
The EGR does to your engine what smoking does to your lungs.
Remember you can always improve on a design until the EPA gets involved.
Master_Chase is offline
post #19 of 21 Old 11-23-2018, 07:21 PM
Cruzeraj's Avatar
I have had my 05, 6.0, 4x4 for just over 3 years. Here are my upgrades. 1- longer wiper blades 2- EGR delete & new oil cooler x2 (1st cooler was Ebay junk) & coolant filter 3- Rancho 9000 adjustable shocks on all four corners 4- SCT Live wire tuner with a EGT probe 5- new exhaust from down pipe back with new muffler but no cat. Also wrapped the down pipe with lava heat wrap 6- 2" Rough Country leveling kit (no shocks about $100 from Rough country's website) 7- 33x12.50R18 Nitto Ridge Grappler 8- rebuilt front end & add dual steering stabilizers.
Next year I plan on doing 08 + power folding/tow mirrors, rear F250 spring, Bluetooth radio and remote start.
Good luck
Cruzeraj is offline
post #20 of 21 Old 11-24-2018, 06:45 AM
voodooridr's Avatar
Quoted: 833 Post(s)
The Motorcraft WW-2200-PC 22" wiper blades work
Ridge Grapplers are great tires (so far)
Sent from my SM-G960U using Tapatalk
2004 F250 CCSB 4X4
4" Skyjacker lift
3:73 gears
35x12.5x18 Nitto Ridge Grapplers on Method MR309 wheels
KDD heads, ARP studs, BD exhaust manifolds, DieselSite up pipes, Mishimoto degas bottle
PHP Insight PRO
PHP Atlas 40 FICM tune
voodooridr is offline
