Time to give up the powerstroke... - Ford Powerstroke Diesel Forum
6.0L Ford Excursion Discussion This forum is for topics relating to the excursion only.
 12Likes
post #1 of 25 Old 04-15-2017, 03:53 PM Thread Starter
Quoted: 43 Post(s)
With a growing family, its unfortunately time to sell the rig. But, I do believe it is time for an excursion!!!! Any tips or advice on the new platform?
Sent from my LG-H830 using Tapatalk
darkpassenger likes this.
et_miller_87 is offline
post #2 of 25 Old 04-15-2017, 04:23 PM
Durapig Eater's Avatar
Quoted: 163 Post(s)
Spring swap. Check the rear AC, there is a valve that likes to clog. Check the rear gate lock, key and power. Other than that it's pretty much a crew cab short bed.
Durapig Eater is offline
post #3 of 25 Old 04-15-2017, 05:06 PM
AMERICA!
Rattlesnake18's Avatar
Quoted: 1739 Post(s)
Feedback Score: 6 reviews
I moved this thread to an Excursion section.
My wife and I debated and an Excursion for her, but we decided on a 2013 Expedition for her as of last Tuesday.
2004 F250 CC Lariat 4x4
BPD FICM, BPD billet water pump, BPD VK688 oil cooler kit, S&B CAI, MTW stage 2, TSD tunes, Auto Meter gauges, Edge CTS, Sinister coolant filter, Blue spring, 6.4 banjo bolts, Straight piped w/ 6" single mitre stack, Pro Comp leveling kit, 05-07 HD headlights, Xenon-Vision 5k HIDs, Fumoto block drain valves, ELC, High idle mod
Originally Posted by djmaguire View Post
I'm guessing that you didn't lose nearly as much as it appeared. Spills are like that. The last beer that I spilled was like a million ounces.
Rattlesnake18 is offline
post #4 of 25 Old 04-15-2017, 06:32 PM
JesseKK's Avatar
Quoted: 90 Post(s)
Garage
Sounds like you need to make it a 6 door
JesseKFK
2007 F250 XLT CC 6.0 PowerStroke FX4 R.I.P. 3.6.16
Livewire TS LOoNeY
Studded
BPD 58v FICM
BPD Oil&Egr Cooler
Glow Shift Pyro,Fuel
High Idle Mod UF#4
Fog Light Mod
Harpoon Mod
Dome Override Mod
6000k Bi-neon Hids
Sinister Coolant Filter
8in Rize Ind 4 link
35" Mickeys on 20s
Blue Leds
Power Service Every Fill Up
ATV 2008 Yamaha Raptor 700 FI
KCCO
Originally Posted by Karls03 View Post
I hate Edge power products so much, I quit using Edge shaving gel
JesseKK is offline
post #5 of 25 Old 04-15-2017, 06:34 PM
AMERICA!
Originally Posted by JesseKK View Post
Sounds like to need to make it a 6 door
@h0trod .........
post #6 of 25 Old 04-15-2017, 07:58 PM Thread Starter
Quoted: 43 Post(s)
Hah! I'm all for the 6 door!!
JesseKK likes this.
post #7 of 25 Old 04-15-2017, 07:58 PM Thread Starter
Quoted: 43 Post(s)
Honestly, if I could find an old centurion in decent condition I'd take it!
post #8 of 25 Old 04-15-2017, 08:09 PM
Quoted: 693 Post(s)
Mmm those rear AC lines like to rub on the passenger valve cover and leak there too.
Pain to replace them. Not cheap either since they run damn near the length of the vehicle.
Usually customer just opts to delete the rear AC at that point
The greater danger for most of us lies not in setting our aim too high and falling short; but in setting our aim too low, and achieving our mark.
-Michelangelo
kaya is offline
post #9 of 25 Old 04-15-2017, 08:31 PM
Master_Chase's Avatar
Quoted: 518 Post(s)
Rear AC lines are a pain on my 4th set now I think and I can't delete it since I'm in South Texas I need all the cooling I can get.
Spring swap is a must in my opinion, along with a rear anti-sway bar if it doesn't have one.
kaya likes this.
E̶a̶r̶l̶y̶ ̶2̶0̶0̶3̶ ̶6̶.̶0̶ ̶E̶x̶c̶u̶r̶s̶i̶o̶n̶ ̶f̶u̶l̶l̶y̶ ̶b̶u̶l̶l̶e̶t̶p̶r̶o̶o̶f̶e̶d̶,̶ ̶1̶5̶5̶/̶3̶0̶ ̶i̶n̶j̶e̶c̶t̶o̶r̶s̶,̶ ̶K̶C̶ ̶S̶t̶a̶g̶e̶ ̶2̶,̶ ̶a̶n̶d̶ ̶a̶ ̶l̶o̶t̶ ̶o̶f̶ ̶o̶t̶h̶e̶r̶ ̶s̶t̶u̶f̶f̶.̶ Cummins swap in progress. Thanks to everyone on the forum I have learned a lot.
The EGR does to your engine what smoking does to your lungs.
Remember you can always improve on a design until the EPA gets involved.
Master_Chase is offline
post #10 of 25 Old 04-15-2017, 08:33 PM Thread Starter
Quoted: 43 Post(s)
Next question. Why are the so damned expensive!
