What Did You Do To Your Excursion Today? - Ford Powerstroke Diesel Forum
6.0L Ford Excursion Discussion This forum is for topics relating to the excursion only.
 35Likes
post #1 of 53 Old 03-15-2017, 02:44 PM Thread Starter
Quoted: 373 Post(s)
Garage
Not sure if anyone has started this thread in the past if not here we go.
So I cleaned up the wife's Ex today since it was 63 here in Montana..
Ordered air bags for the rear with 4 inch spacers and smoked led cab lights for the roof.
What did you do to your EX today?
MagnoliaTom likes this.
New 2019 F350 CCLB Platinum
Last Truck 2006 F350 CCLB KR
I'm out old man. I'm just a pecker-wood who lives in the woods with too many guns. Ya happy?"
BridgerMT is offline
post #2 of 53 Old 03-15-2017, 07:31 PM
TwinExcursions's Avatar
Quoted: 156 Post(s)
Garage
Drove it to work and back. Tried to keep lead foot out of skinny pedal due to company paying for diesel
05 Eddie Bauer
Studded/EGR delete
Kill Devil O-ring heads
Owdags intake manifold
BD Diesel exhaust manifold
58v FICM
SCT with Gearheads tunes
S&B stage 2 cold air
SD coolant bypass filter
Edge Insight CTS2 c/w EGT sensor
BD Diesel 7.3 fan clutch
4" Magna Flow stainless turbo back, cat empty shell
Heavy duty alternator (230A)
Buckstop bumper c/w Warn 16.5 winch
Warn Hubs, Eaton posi front/rear diffs
TwinExcursions is offline
post #3 of 53 Old 03-16-2017, 04:40 PM
Quoted: 25 Post(s)
Bought my wife an 05 Eddie Bauer about two weeks ago. Last Wednesday I pulled the motor to reseal the entire thing and fix the fuel in coolant issue. Found out it already had brand new ford heads and a set of injectors installed. So, I resealed the entire thing including the bedplate, put a new set of lifters in it, 6.4 push rods, studs, updated drain and feed tube, regulated fuel return, coolant filter, new intercooler pipes, new ficm board (dorman), rebuilt the turbo with the updated sealing ring and 360 thrust bearing, IPR research egr delete, new radiator and heater hoses, new coolant bottle from the fuel (shop that fixed it didn't flush it properly...) new a/c manifold line and new mode door actuator. Worked on it after work Thursday after work and Friday after work and at about 10 pm got it up and running. Threw an h&s performance single tune in it since it cost me nothing, and drove it home! Got the urge to get rid of the hideous 16s on Saturday so on Saturday it got a new set of wheels and 305/55r20 toyo AT2s. In other words, I really hope I don't have to touch this truck for a very long time beyond maintenance. Did not replace the oil cooler as it had a 0 degree split at 75. I just put a reseal kit in it and new screen. Also pulled and just gutted the cat, as it is her truck and was adamant that it was to not be as loud as mine. lol
Nickjames525 is offline
post #4 of 53 Old 03-18-2017, 01:57 PM Thread Starter
Quoted: 373 Post(s)
Garage
Finally tracked down where the rear washer fluid was going, the grommet that comes through the firewall by the passenger side kick plate hose came off WT hell...
Backyard mechanic does it again
post #5 of 53 Old 03-26-2017, 01:33 PM
Quoted: 156 Post(s)
Garage
Repeating myself but to keep spirit of thread alive
My ex new hydro boost
Wife's ex new brake lines on diff and Russel stainless from diff to frame
Sent from my SM-G930W8 using Tapatalk
05 Eddie Bauer
Studded/EGR delete
58v FICM
post #6 of 53 Old 03-28-2017, 07:20 AM
00blacky's Avatar
Quoted: 9 Post(s)
Replaced all the ugly looking factory lights inside with LED's and changed out the running boards lights to LED's also. Looks so much better now.
00blacky is offline
post #7 of 53 Old 03-31-2017, 03:34 PM Thread Starter
Quoted: 373 Post(s)
Garage
Had to order some weld on axle brackets for the air bags. For some reason the rear leaf springs spacers on the EX do not have the jounce stop on them and factory OEM spacers with them are 100 each dam. Found some weld on's both $50.00
Next weekend is air bag install.
post #8 of 53 Old 04-07-2017, 03:14 AM Thread Starter
Quoted: 373 Post(s)
Garage
Today is the day going to install air bags and cab lights on wife's EX.
Hope all goes well ...
post #9 of 53 Old 04-08-2017, 03:32 AM Thread Starter
Quoted: 373 Post(s)
Garage
All done with some more mods.
I have not seen to many Excursions with cab lights anyone here got some to post up.
ID:	613449   Click image for larger version
post #10 of 53 Old 05-07-2017, 01:38 PM Thread Starter
Quoted: 373 Post(s)
Garage
Changed fuel filters today on the Ex.
The Following User Says Thank You to BridgerMT For This Useful Post:
mad_max0204 (07-21-2019)
