05 F350 Fwd front axle tube dust seal? - Ford Powerstroke Diesel Forum
 16Likes
post #1 of 19 Old 09-22-2019, 02:20 PM Thread Starter
Quoted: 46 Post(s)
I'm doing my ball joint on my truck and I'm having a heck of a time finding this seal. No one seems to be able to get me a part number as any of the local auto parts stores.
I have the big seal that requires the special giant install tool, but there is a second inner seal that goes on the actual axle tube. I think it's just a dust seal, but I can seem to find a part number for it and every seal I look at is different..
Anyone know which one it is? It's the one that always breaks in half and rolls around on the axle shaft behind the universal joint. I'm trying to fix a replacement.
This is a picture I found online.. and these part numbers but it's a different looking seal..
BRS-170
AC3Z-1S175-A
DAV!D is offline
post #2 of 19 Old 09-22-2019, 03:15 PM
partyman97_3's Avatar
Quoted: 913 Post(s)
Garage
Iirc, there is an updated seal for that. Not sure of the number, but @voodooridr , will probably know.
The following website is a nice part number listing, also.
https://www.powerstroke.org/forum/ge...rnational.html
john galt and john galt like this.
2003 F-350, CC, LB, 285/75/16, Autometer Gages, Fox 2.0's (Thanks to Corey), Sninister Bypass Coolant Filter, 4" Turbo Back,Leece-Neville 230 Amp Alternator, 6.4 litre starter
partyman97_3 is offline
The Following 2 Users Say Thank You to partyman97_3 For This Useful Post:
DAV!D (09-22-2019)
post #3 of 19 Old 09-22-2019, 03:37 PM
jokester00's Avatar
Quoted: 530 Post(s)
Garage
Your picture is the old seal. Like mentioned above, there is a new seal and a new P/N. Let me see if I can find it...standby
-jokester
2005 F350 CCLB FX4 Lariat
SCT SF3 - Currently running PHP 80hp Daily Driver Tune with Atlas 40 FICM Tune
Edge Insight CTS2 monitor
Edge EAS EGT probe
Edge EAS Fuel Pressure Sensor
jokester00 is offline
The Following 2 Users Say Thank You to jokester00 For This Useful Post:
DAV!D (09-22-2019)
post #4 of 19 Old 09-22-2019, 03:55 PM
voodooridr's Avatar
Quoted: 1082 Post(s)
The AC3Z-1S175A is the correct seal, Ford re-engineered the seal and it looks nothing like the original
The new seal presses into the axle tube now
2004 F250 CCSB 4X4
4" Skyjacker lift
3:73 gears
35x12.5x18 Nitto Ridge Grapplers on Method MR309 wheels
KDD heads, ARP studs, BD exhaust manifolds, DieselSite up pipes, Mishimoto degas bottle
PHP Insight PRO
PHP Atlas 40 FICM tune
voodooridr is online now
The Following 2 Users Say Thank You to voodooridr For This Useful Post:
DAV!D (09-22-2019)
post #5 of 19 Old 09-22-2019, 04:49 PM Thread Starter
Quoted: 46 Post(s)
Ok, so I bought one of the AC3Z-1S175A seals at a local store because I don't have time to order it.. Is it supposed to get pressed into the axle shaft? Seems like it fits loosely in the opening unless it's supposed to get rammed up inside.. The other issue is the inner opening is extremely tight on my axle shaft. I mean it's tight just going over the very end which is smaller in diameter than further up the shaft where the seal will ride.. No way the axle will spin inside this seal, is the entire seal supposed to spin with the axle?
I took a picture to show how it compared to the shaft..
Last.. I ordered the outer seal for what was supposed to fit my truck. (the vacuum seal for the hubs) Clearly as you can see in my pictures it's not the right seal. The one from my truck is much bigger around and totally different than the one I bought. Also the seal tool I bought (2005 up) is very tight going into the hub and I think it would get stuck inside if I try to install a seal with it.
Everything I bought was supposed to fit the 2005 & up F350 but seems my stuff is different. Do I not have a 2005 front axle?
ID:	723419   Click image for larger version
ID:	723421   Click image for larger version
DAV!D is offline
post #6 of 19 Old 09-22-2019, 05:10 PM
voodooridr's Avatar
That vacuum hub seal looks like one for a 99-04 not the 05/
I've never seen an Oreally dust seal in person but something looks wrong about that one
john galt and jokester00 like this.
2004 F250 CCSB 4X4
4" Skyjacker lift
3:73 gears
PHP Insight PRO
post #7 of 19 Old 09-22-2019, 06:17 PM Thread Starter
Quoted: 46 Post(s)
Do you mean my new one in the bag looks like the 99-04 or the old one on the axle? The O'riely seal is what cross references for the Ford OEM PN#. Is it supposed to be really tight on the shaft or is the shaft supposed to spin inside it?
DAV!D is offline
post #8 of 19 Old 09-22-2019, 06:55 PM
voodooridr's Avatar
The seal in the bag (new one) looks like a 99-04 seal
2004 F250 CCSB 4X4
4" Skyjacker lift
3:73 gears
PHP Insight PRO
DAV!D (09-22-2019)
post #9 of 19 Old 09-22-2019, 07:05 PM
Quoted: 695 Post(s)
The inner dust seal spins with the shaft. The metal portion remains fixed in the tube. It's a two piece design.
At least the oem one is.
The greater danger for most of us lies not in setting our aim too high and falling short; but in setting our aim too low, and achieving our mark.
-Michelangelo
kaya is offline
The Following 2 Users Say Thank You to kaya For This Useful Post:
DAV!D (09-22-2019)
post #10 of 19 Old 09-22-2019, 07:12 PM
california deplorable
john galt's Avatar
Quoted: 3181 Post(s)
the best advice i can offer with regards to buying superduty parts at orealies...
DON'T!
a leason i learned very much the hard way
I like mead
early 04 f350 6.0 cclb lariat sr
Bulletproof oil &egr, elc, sct x3, edge CTS, afe intake, blue spring, t-500, MTW stage 2, Vivians looney, 305 x55x20 bfg at ko's, 4 inch cat back, 4"BDS fox shocks and steering stabilizer, tri pilar gauge set, coolant filter, riff raff boots, new headliner, 7 inch touch screen w/back up, new carpet, near whole new interior,
FederalOwnershipRespectfullyDeclined
john galt is offline
