Rear window - Ford Powerstroke Diesel Forum
 3Likes
  • 1 Post By 1NastySS
  • 2 Post By fordsvtparts
post #1 of 7 Old 08-23-2019, 06:12 PM Thread Starter
1NastySS's Avatar
Quoted: 24 Post(s)
Rear window
In an effort to rid myself of potential leaks I want to replace the sliding rear window with a solid one.Im trying to find an oem one but all I am seeing are clear ones.Is there a source for an oem tinted back window?
1NastySS is offline
post #2 of 7 Old 08-24-2019, 09:30 AM
jokester00's Avatar
Quoted: 537 Post(s)
Garage
@fordsvtparts
@voodooridr
-jokester
2005 F350 CCLB FX4 Lariat
SCT SF3 - Currently running PHP 80hp Daily Driver Tune with Atlas 40 FICM Tune
Edge Insight CTS2 monitor
Edge EAS EGT probe
Edge EAS Fuel Pressure Sensor
jokester00 is offline
post #3 of 7 Old 08-24-2019, 10:06 AM
voodooridr's Avatar
Quoted: 1084 Post(s)
If I'm not mistaken there were no "privacy glass " solid windows, i believe they were all the green tint (clear)
Sent from my SM-G960U using Tapatalk
2004 F250 CCSB 4X4
4" Skyjacker lift
3:73 gears
35x12.5x18 Nitto Ridge Grapplers on Method MR309 wheels
KDD heads, ARP studs, BD exhaust manifolds, DieselSite up pipes, Mishimoto degas bottle
PHP Insight PRO
PHP Atlas 40 FICM tune
voodooridr is online now
post #4 of 7 Old 08-25-2019, 05:40 PM Thread Starter
1NastySS's Avatar
Quoted: 24 Post(s)
That surely seems to be the case,thanks.
1NastySS is offline
post #5 of 7 Old 08-25-2019, 05:51 PM
ZMANN's Avatar
Quoted: 4035 Post(s)
are you using your truck as a submarine?
I have had my slider 13 years without a leak issue
I am sure you could find someone with a tinted solid to swap you
they are a little bit of a pain to remove but the rope / soap and back in
I am not sure but i would check I think the glass only version may take a different gasket because of the frame on the slider makes it thicker ?
6.0 flush pdf
ZMANN is offline
post #6 of 7 Old 08-25-2019, 06:01 PM Thread Starter
1NastySS's Avatar
Quoted: 24 Post(s)
Not a submarine but trust me Ive thought about driving it off a bridge, the slider is no match for the rainshine states almost daily downpours.Truck also has a rain roof,so Im over water leaks.
You are correct the glass only one does take a different seal.I found an aftermarket tinted solid window that comes with the seal,so Im gonna give that one a go.
ZMANN likes this.
1NastySS is offline
post #7 of 7 Old 08-26-2019, 05:50 PM
fordsvtparts's Avatar
Quoted: 146 Post(s)
As others have mentioned, the solid glass was not available as the privacy version for this generation.
ZMANN and Hydro like this.
We are Autonation Ford of White Bear Lake selling all OEM Ford parts at employee prices (formerly Tousley)
Call us at 1-800-328-9552 (be sure to mention this website when calling)
OR check out our website
I'll meet or or beat any price on OEM parts
fordsvtparts is offline
The Following 2 Users Say Thank You to fordsvtparts For This Useful Post:
1NastySS (08-28-2019)
