Is 1000 bucks for a good shape 2007 crew cab a good deal?and how hard is a cab swap? - Ford Powerstroke Diesel Forum
 7Likes
  • 2 Post By F250_SUPER_4x4
  • 1 Post By ZMANN
  • 1 Post By White_Buffalo7.3
  • 2 Post By Heavy_GD
  • 1 Post By Cjandsons
post #1 of 9 Old 04-13-2018, 06:57 AM Thread Starter
Cjandsons's Avatar
Quoted: 4 Post(s)
I have a 2006 6.0 ccsb cabs a little tender our back rear of the truck is solid my buddy said hed sell me his 07 ccsb 5.4 for 1000 bucks runs but eats oil just wondering how hard a cab swap is and whatvelectronicly is involved
Sent from my iPhone using Tapatalk
Cjandsons is offline
post #2 of 9 Old 04-13-2018, 07:02 AM
"RLTW" Tennessee
F250_SUPER_4x4's Avatar
Quoted: 295 Post(s)
Removing a cab from a diesel is relatively easy. Gasser not sure but shouldnt be that tough. What you are trying to do is a little more difficult as you will have to transfer harnesses, gauge clusters etc.
ZMANN and john galt like this.
1974 F100 RC 351W/C4
1978 F250 Super Cab 400/C6
2015 F250 PSD CC KR 408/6R140
2017 Harley Ultra Limited 107/6SPD
F250_SUPER_4x4 is offline
post #3 of 9 Old 04-13-2018, 07:06 AM
ZMANN's Avatar
Quoted: 3934 Post(s)
interesting
i don't have a definitive answer but it got me thinking
i wonder if the front core supports would need changed?
the electronics like pcm ,abs ,cluster , harnesses and all that would need swapped and the gas probably uses vacuum brakes so all that swaps over, battery trays vacuum pump, ESOF valve
and you would be tempted to pull the windshields and do illegal vin swaps
(i think there is one on the core area also?) but if the cab is actually that much nicer than your i would be tempted also
sounds like He is almost giving you that truck
john galt likes this.
6.0 flush pdf
ZMANN is offline
post #4 of 9 Old 04-13-2018, 07:10 AM Thread Starter
Cjandsons's Avatar
Quoted: 4 Post(s)
post #5 of 9 Old 04-13-2018, 07:14 AM
White_Buffalo7.3's Avatar
Quoted: 191 Post(s)
Garage
I have zero experience but a guy i know is a mechanic and he said he can have a cab lifted off in 45 minuets, but, even if you know absolutely nothing, even if it takes 2 hours you can now do up pipes, or any job while its off. then, swap your PCM, and more than likely your gauge cluster/dash, then that should be it...
I'd go for it
180/30s,KC38R, CNC Fab Stg 2 HPOP, Sump, Walbro, Donaldson 6637, Leveled, 4'' straight to 7'' tip, 08 mirrors, 6.0 front end ect...
White_Buffalo7.3 is offline
post #6 of 9 Old 04-13-2018, 08:56 AM
Heavy_GD's Avatar
Quoted: 3129 Post(s)
Garage
Feedback Score: 4 reviews
my cousins, wifes, nephews, GFs, sisters, husband processed his own hamburger once.... I just go to Costco.
v8deuce and F250_SUPER_4x4 like this.
GD
Originally Posted by djmaguire View Post
So says the internet... ...and so it shall be.
Originally Posted by G8orFord View Post
OK, thanks for the info. To show my ignorance, what is the problem with 3 nipples...
Heavy_GD is offline
post #7 of 9 Old 04-13-2018, 09:17 AM Thread Starter
Cjandsons's Avatar
Quoted: 4 Post(s)
Ha!
Heavy_GD likes this.
post #8 of 9 Old 06-05-2018, 07:03 AM Thread Starter
Cjandsons's Avatar
Quoted: 4 Post(s)
This is in fact happening intended up getting an 04 cab and hen this truck blew up and is being given to me so we shall see I?m having a hard time finding. Info on if it?s a direct wiring swap or if I?d have to take the whole dash and wiring out and swap.
post #9 of 9 Old 06-05-2018, 07:07 AM
Heavy_GD's Avatar
Garage
Its best just to share a link to your build thread: https://www.powerstroke.org/forum/6-0...ures-prog.html
GD
Heavy_GD is offline
Closed Thread
