4x4 not working - Ford Powerstroke Diesel Forum
 3Likes
post #1 of 12 Old 01-24-2020, 05:46 AM Thread Starter
ryansmith2213's Avatar
Quoted: 2 Post(s)
4x4 not working
I believe my issue lies in the transfer case shift module located in the glove box. Does anyone know how to check it? I'd sure hate to buy one and that not be my problem. I've been through all my fuses and check the shift motor on the transfer case and it moves when voltage is applied.
ryansmith2213 is offline
post #2 of 12 Old 01-24-2020, 05:56 AM
G8orFord's Avatar
Quoted: 2607 Post(s)
Garage
The diagnostics and testing procedures are attached. Pick the one that matches your year model.
jokester00 and Hydro like this.
Dexter
2017 F-250 Lariat CCSB FX4 SRW- A few Forscan tweaks
My old Truck, now son's truck:
2004 F-250SD Lariat CCSB FX4 SRW; SCT X4 w/custom tunes (currently
SPD)
FICM;
FICM Tuner (currently Atlas40);
Stage 1.5 Turbo;
Stage 1 HPOP;
VK688 Oil Cooler Relocate with coolant re-route;
Water Pump;
O-ringed Heads; ARP Studs; Fel-Pro Gaskets;
Coolant Filter;
DashCommand on PLX Kiwi2 + iMFD with EGT & Fuel/Oil Pressure
G8orFord is offline
The Following User Says Thank You to G8orFord For This Useful Post:
nine9six (01-24-2020)
post #3 of 12 Old 01-24-2020, 08:51 AM
JustinOOO9's Avatar
Quoted: 1702 Post(s)
Garage
Feedback Score: 3 reviews
Are your front hubs in the auto or lock position when you switch to 4x4 hi or low on the dash in cab? Also hvac controls working fine as in the air isn't stuck on defrost mode etc?
-99 F250, 4X4, 6.0 trans cooler, 08 mirrors, 05 grill, AIS Intake, lvl kit, JW Vbody, cncfab hpop lines, WW2.
04 Excursion Modified, 04 F350 Modified, 06 F350 Modified
Interested in learning something new?
"Its like me getting five 5 gallon bucks and throwing regular, mid, premium, #2 diesel and offroad diesel and then shooting a roman candle at each one to show which ones burns better."
JustinOOO9 is offline
post #4 of 12 Old 01-24-2020, 09:12 AM Thread Starter
Quoted: 2 Post(s)
All the air works great and the lights for 4x4 work. They just dont come on when engaging the switch. I bought a new switch thinking that was my problem and it wasn't. I have auto hubs and manual locking. I can lock them in and still nothing changes. Ice read other forums and have check most everything. I'm assuming it's in the control module just not sure of a way to troubleshoot it. I cant find any manuals online.
post #5 of 12 Old 01-24-2020, 09:30 AM
Quoted: 527 Post(s)
Garage
Forscan to read the codes and operate the t-case
you didn't mention if there were codes
fuses?, relays?, shift motor?
there is a lot more to getting the t-case to shift positions
Are you good with a test light and meter?
year and model of the truck would help
In my defense, I was unsupervised
2006 F250 Lariat FX4 cclb
Torque Pro and OBDLink MX bluetooth monitor
General note:
For all those wanting a premium silicone sealer Kubota 70000-73764 is the best your gonna find. This is a hybrid gray silicone that uses solvent rather than acid to start the curing reaction, this makes it safe for aluminum and and any surface that involves coolant.
Hydro is offline
post #6 of 12 Old 01-24-2020, 10:43 AM Thread Starter
Quoted: 2 Post(s)
It's a 2007 f350 srw. Relays are good and the fuses all check good. I can use a meter at the connector for the shift motor and I dont get a voltage change on the pins. That's why I assume the module is bad. From what i read that is what controls the transfer case after the relays get the signal from the switch to change into 4 hi or 4 lo. If I could find a pin out for the connector to the module i believe i could troubleshoot it with that to determine if it is bad or not. I found a diagram for which fuses and relays are for 4x4. I dont have a manual for my truck so I used what I found in forums. And the only codes I have are for my egr which was deleted by the previous owner.
post #7 of 12 Old 01-24-2020, 11:26 AM
Quoted: 527 Post(s)
Garage
The switch gives a different resistance value for each position to the 4x4 module
the module in turn operate which ever relay is needed
The position sensor on the shift motor then returns a signal
Does the troubleshooting info that @G8orFord posted not give enough info?
what are you using to pull codes?
General note:
Hydro is offline
post #8 of 12 Old 01-24-2020, 02:21 PM Thread Starter
Quoted: 2 Post(s)
They wouldn't open on my phone I'll have to give them a try when I get off work.
post #9 of 12 Old 01-24-2020, 02:26 PM
Quoted: 527 Post(s)
Garage
Standard .pdf files ...you must have one of those old flip phones
ZMANN likes this.
General note:
Hydro is offline
post #10 of 12 Old 01-24-2020, 02:52 PM Thread Starter
Quoted: 2 Post(s)
Galaxy s9+
