05 6.0 speedometer - Ford Powerstroke Diesel Forum
 2Likes
  • 2 Post By ZMANN
post #1 of 5 Old 11-20-2019, 08:59 AM Thread Starter
Quoted: 14 Post(s)
05 6.0 speedometer
So just recently the speedo on my truck has periodically started half *** working, It will go up to 50kmh slowly even if I'm doing 100kmh. But then other days it will work accurately. Any ideas? I have a livewire ts chip in it.
Thanks.
Brandyn54321 is offline
post #2 of 5 Old 11-20-2019, 02:50 PM
JustinOOO9's Avatar
Quoted: 1679 Post(s)
Garage
Feedback Score: 3 reviews
Thanks.
if im remembering correctly the rear speed sensor called a VSS or something is on the rear dif. Look at it and check the wire and wire clip connection. They do fail sometimes.
Also from research shows it was a common problem with 05 trucks and required the cluster to be replaced in some cases.
-99 F250, 4X4, 6.0 trans cooler, 08 mirrors, 05 grill, AIS Intake, lvl kit, JW Vbody, cncfab hpop lines, WW2.
04 Excursion Modified, 04 F350 Modified, 06 F350 Modified
Interested in learning something new?
"Its like me getting five 5 gallon bucks and throwing regular, mid, premium, #2 diesel and offroad diesel and then shooting a roman candle at each one to show which ones burns better."
JustinOOO9 is offline
post #3 of 5 Old 11-20-2019, 06:07 PM Thread Starter
Quoted: 14 Post(s)
Yeah the rear abs sensor has been shot since I bought the truck over 2 years now. I replaced both the front ones awhile ago. So I guess gauge cluster?
post #4 of 5 Old 11-20-2019, 07:33 PM
ZMANN's Avatar
Quoted: 4014 Post(s)
only the rear does the speedo what do you mean it is shot ?
jokester00 and Hydro like this.
6.0 flush pdf
ZMANN is offline
post #5 of 5 Old 11-23-2019, 01:50 PM Thread Starter
Quoted: 14 Post(s)
You need 2 out of 3 in order for the speedo to work. I broke both the front ones when I replaced my balljoins and the speedo did not work until I replaced both of the front ones. The rear one has been cut for 2 years and the speedo works without it.
