low coolant alarm 6,0 - Ford Powerstroke Diesel Forum
 3Likes
  • 1 Post By Hartwig
  • 1 Post By Hartwig
  • 1 Post By Hartwig
post #1 of 5 Old 05-10-2019, 11:32 AM Thread Starter
Hartwig's Avatar
Quoted: 35 Post(s)
Unfortunately the 6.0 has no low coolant alarm. I have now found a solution with a capacitive sensor.. I made an experimental setup. In the F350 a combined lamp with buzzer will be installed, as soon as the coolant level is too low, you hear and see the alarm, in a few weeks I will report when everything is ready...
djmaguire likes this.
Hartwig is offline
post #2 of 5 Old 06-09-2019, 07:59 AM Thread Starter
Hartwig's Avatar
Quoted: 35 Post(s)
done
SparkyF250 likes this.
Hartwig is offline
post #3 of 5 Old 06-09-2019, 07:15 PM
Quoted: 8 Post(s)
Any more info? That is pretty slick, and I can think of several applications depending on the cost.
Mcflyfyter is online now
post #4 of 5 Old 06-11-2019, 11:09 PM Thread Starter
Hartwig's Avatar
Quoted: 35 Post(s)
Hi, it's an programmable Sensor
https://autosen.com/de/Article?s=ac004&sort=6
You only need additionaly a standard relais and a buzzer/lamp
Hartwig is offline
post #5 of 5 Old 06-12-2019, 12:19 AM Thread Starter
Hartwig's Avatar
Quoted: 35 Post(s)
The sensor can be programmed for "close function" and "opening function" (sorry, don't know the words in english). With an adapter it can also be mounted on a hoose. It works with any kind if plastic container/coolant bottle. Fine stuff!
Hartwig is offline
Similar Threads
Thread Thread Starter Forum Replies Last Post
Brand new motor, first fire, fill coolant then coolant everywhere! Help! 97PSD7.3L 6.0 Motor problems 18 03-27-2019 03:32 AM
EOT/ECT, oil cooler, egr cooler, coolant flush RustyCal1 6.0 Motor problems 6 02-24-2019 12:47 PM
Please Help. Coolant Reservoir Puking and No Heat Jacob Auvil General 6.4L Discussion 19 11-06-2018 08:19 AM
Hoping coolant was over full but expecting head gaskets. NUTNDUN 6.0 Motor problems 11 09-08-2016 07:30 AM
Check Coolant Additive Dealer Lack of testing LeanderF250 6.7 Problems Forum (2011-2016) 1 08-17-2016 10:42 AM
