2006 F350 diesel fan wiring diagram - Ford Powerstroke Diesel Forum
post #1 of 7 Old 04-02-2017, 01:43 PM Thread Starter
Quoted: 8 Post(s)
I have a overheating problem. Replaced thermostat haven"t tested under load at hot day. ...I got some advice that I could ground one of the fan wires to make fan run at full speed. The fan doesn"t seem to be throwing out a lot of air. I did do a 5 mile run after putting in thermostat and temp on both gages normal.
ed2hess is offline
post #2 of 7 Old 04-02-2017, 02:07 PM
ZMANN's Avatar
Quoted: 4004 Post(s)
ground the blue wire on the engine side of the fan connector
it may throw a code but not a CEL and it will lock up the fan but only to a point
you may still hear it roar load and lessen when at higher speeds
6.0 flush pdf
ZMANN is offline
The Following 2 Users Say Thank You to ZMANN For This Useful Post:
ed2hess (04-02-2017)
post #3 of 7 Old 04-02-2017, 06:48 PM Thread Starter
Quoted: 8 Post(s)
Thank you very much for that info. It will save me a LOT of time researching!
ed2hess is offline
post #4 of 7 Old 04-04-2017, 04:32 PM Thread Starter
Quoted: 8 Post(s)
Wiring torn apart
I got shroud out so I could splice wires and want to know if Butt connectors would be a good choice. There are 5 wires running to fan but basically we are just locking up the clutch to get max.rpm?
Last edited by ed2hess; 04-04-2017 at 07:21 PM. Reason: I see that connector at clutch end can Not be removed!
ed2hess is offline
post #5 of 7 Old 04-04-2017, 08:43 PM
DMc
6.2 Convert
DMc's Avatar
Quoted: 342 Post(s)
I did this mod before I got a BPD fan clutch adapter. I just used a wire tap so I wouldn't have to cut the wire. Then run the new wire from the tap to your switch and ground the other side of the switch. When you flip the switch you'll be grounding that blue wire and the fan will come on. It may take a little time for the fan to react when you flip the switch.
2018 F250 4X4 CC LB 6.2
2004 F250 4X4 CC SB Sold (Miss you Sarah!)
DMc is offline
post #6 of 7 Old 04-05-2017, 06:05 AM
G8orFord's Avatar
Quoted: 2590 Post(s)
Garage
It's the connector at the top of the fan shroud. Tap the blue wire on the engine side of the connector inline with a Scotch-lock (or similar) and run to a switch. Run the other side of the switch to ground. Do not cut the blue wire.
Dexter
2017 F-250 Lariat CCSB FX4 SRW- A few Forscan tweaks
My old Truck, now son's truck:
2004 F-250SD Lariat CCSB FX4 SRW; SCT X4 w/custom tunes (currently
SPD)
FICM;
FICM Tuner (currently Atlas40);
Stage 1.5 Turbo;
Stage 1 HPOP;
VK688 Oil Cooler Relocate with coolant re-route;
Water Pump;
O-ringed Heads; ARP Studs; Fel-Pro Gaskets;
Coolant Filter;
DashCommand on PLX Kiwi2 + iMFD with EGT & Fuel/Oil Pressure
G8orFord is offline
post #7 of 7 Old 04-07-2017, 05:58 PM Thread Starter
Quoted: 8 Post(s)
Scotchloc
Thanks for that tip....
ed2hess is offline
