5R110W Pan Gasket: Is there a trick to it? - Page 4 - Ford Powerstroke Diesel Forum
 19Likes
post #31 of 39 Old 05-24-2019, 07:07 AM
ZMANN's Avatar
Quoted: 3910 Post(s)
Also. The w is for. Wide gear range. You usually see that reserved for describing later units. And not 03/07 trucks
jokester00 and lhejl like this.
6.0 flush pdf
ZMANN is offline
post #32 of 39 Old 05-24-2019, 07:25 AM
Quoted: 17 Post(s)
Yep the 5r110 was introduced with the 6.0 I believe. The 4r100 was an upgrade from the E4OD and was in production from 98 to 03 IIRC.
Sent from my LG-LS993 using Tapatalk
5J's is offline
post #33 of 39 Old 05-28-2019, 11:28 AM Thread Starter
Quoted: 4 Post(s)
Just wanted to update, got the new pan in with the larger filter. No leaks with >100 miles. Thanks for the assistance everyone!
ID:	719337   Click image for larger version
ID:	719339   Click image for larger version
lhejl is offline
post #34 of 39 Old 05-29-2019, 04:51 PM
Quoted: 14 Post(s)
So my ford dealer wants vin number all the time as there system is setup so you get only the part that came with the truck. So must be not all dealers do this?
tab57 is offline
post #35 of 39 Old 05-29-2019, 06:29 PM
Quoted: 17 Post(s)
Not the dealer here. I gave him the year model of the truck I wanted a pan and he gave me what I needed. He didn't ask me any questions.
5J's is offline
post #36 of 39 Old 06-04-2019, 10:42 AM
You can get both the Pan (8C3Z-7A194-B) for $73 and the filter (FT-180) $38.00 via Amazon Prime.
Also, not 100% sure on this but I think the original pan does not have a drain plug however the new one does.
Mike
Mike Bartlett is offline
post #37 of 39 Old 06-04-2019, 03:46 PM
ZMANN's Avatar
my old one had a drainplug
i just did this swap again Friday the OEM pan held just shy of 9 quarts if you let it drain overnight
my new pan was 16 quarts to full .. the new pan i used hold 7 qt more than stock
SparkyF250 likes this.
6.0 flush pdf
ZMANN is offline
post #38 of 39 Old 06-04-2019, 04:51 PM
Quoted: 22 Post(s)
I see that in the state of California this pan may cause cancer. Thankfully I do not live in CA and am therefore considering purchasing it. Question @ZMANN does the derale pan simply bolt in or does the crossmember need to be loosened t install it ?
Larry Grogan is offline
post #39 of 39 Old 06-04-2019, 05:00 PM
ZMANN's Avatar
direct bolt on
the bolts near the cross member are best started by hand after you have two bolts holding the pan in place , then start all the bolts by hand
do not use the cork gasket included just use or get a new OEM reusable unit
BTL likes this.
6.0 flush pdf
ZMANN is offline
Similar Threads
Thread Thread Starter Forum Replies Last Post
My Cab-On Head Gasket Project...*PICS* iqraceworks General 6.0L Discussion 75 09-14-2019 07:12 AM
High pressure oil pump gasket leak Symonds 94-98 7.3L Problem Forum 5 01-09-2019 08:47 AM
thermostat gasket question Ratrod36 99-03 7.3L General Discussion 9 07-19-2018 12:23 PM
97 7.3 thermostat gasket fixitforfree1 94-98 7.3L General Powerstroke Discussion 2 06-27-2018 06:06 AM
