Code P0270 but FICM is good? - Page 2 - Ford Powerstroke Diesel Forum
post #11 of 20 Old 03-27-2012, 11:13 AM Thread Starter
07 Ford 6.0's Avatar
Thanks, I have not started it today and will test it when my son gets home from school.
07 Ford 6.0 is offline
post #12 of 20 Old 03-27-2012, 11:21 AM Thread Starter
I am going to order a ScanGuageII for now due to it being more affordable than the Edge. Great suggestion. I may have seen this problem coming earlier if I had been monitoring and am sure it will be a good tool to have. Thanks.
post #13 of 20 Old 03-27-2012, 01:00 PM Thread Starter
Tested FICM Cold
I tested the FICM completely cold, key on engine off, cranking, and running. All were 48+ volts. Any other suggestions would be appreciated, thanks.
post #14 of 20 Old 03-27-2012, 01:06 PM
FJuanfiddy mod
Dave's Avatar
Quoted: 12 Post(s)
If the FICM tests good and you constantly get P0270 Injector number 4 is bad.
Guys a bad FICM usually throws multiple injector codes or one or two that bounces to different injectors.
If you have an injector code that stays on one particular injector at all times and the FICM tests good. Its the injector
Email:
2006 F250 ECSB Lariat 4x4
Edge Insight CTS
Coolant filter
Dave is offline
The Following User Says Thank You to Dave For This Useful Post:
JIMCO1958 (02-26-2019)
post #15 of 20 Old 03-27-2012, 03:19 PM Thread Starter
Thanks!
Thanks to all of you that replied. Looks like I will be learning how to change my first injector. I'm sure it's going to take me a while but I should be able to do it with all the good information and videos here. Thanks again.
post #16 of 20 Old 03-29-2012, 04:32 PM Thread Starter
Truck is at the shop now.
After changing the injector I am still getting the same code and it still shakes/shudders. Dropped it off at reputable Diesel shop and they are getting the same code as cheap auto parts store but they belive it is going to be the FICM or harness, not the injector. I should know tomorrow.
post #17 of 20 Old 03-30-2012, 05:02 AM
mdub707's Avatar
FWIW, I have several FICM's on my bench now that read 48V at all conditions but are just junk. Really rough cold starts, barely keep it running in some cases.
DamnKids Motorsports
2006 F-250 6.0 4x4
Innovative Diesel Tuning 466/772 7/19/08
VEGISTROKED
mdub707 is offline
post #18 of 20 Old 03-30-2012, 02:37 PM Thread Starter
Truck is fixed now.
Just got the truck back and it's running great again. FICM was bad in other area than the voltage output. Valuable and expensive lessons learned but am glad it's back now. Thanks to all, including AZ's Affordable Diesel Tech that did the work at a fair price. Jason and the other guys there were great.
post #19 of 20 Old 12-11-2014, 02:11 PM
Having same problem checked ficm KOEO, cranky (cold) and running ficm good but still have p0270 circuit low cylinder 4 and shakes bad when taking off from stop or cruising at 50 and have no idea where to turn for what my problem could be,please help any info would hel, thanks you in advance
Tim R
Stroke77power is offline
post #20 of 20 Old 02-26-2019, 07:34 PM
JIMCO1958's Avatar
Quoted: 2 Post(s)
I know this is an old thread but I just bought a 2003 F350 6.0 with a P0270 CODE. i have read lots of old posts and have learned a lot. This post say's it real simple Bad FICM " Multiple injector codes , same injector code, bad injector " helps me narrow it down. Still lots more to learn..............
JIMCO1958 is offline
