Intake Removal Question - Ford Powerstroke Diesel Forum
 1Likes
  • 1 Post By dh3415
post #1 of 4 Old 01-28-2020, 06:16 AM Thread Starter
Quoted: 4 Post(s)
I did a search on the site and found many threads about removing intake but For some reason when I click on links, it goes nowhere. So forgive me for asking this as I'm sure it has been covered many times.
I am looking to remove my intake manifold while I have everything apart on the front of the motor. To me it looks like I could remove it without touching the turbo. Am I missing anything? I want to keep this as simple as possible and since the turbo and EGR cooler are new, I don't want to mess with that area. The intake is caked inside with carbon and removing it will make putting the front cover back on easier.
Thanks.
A0m397x is offline
post #2 of 4 Old 01-28-2020, 07:59 AM
Quoted: 530 Post(s)
Garage
You didn't mention the year of your truck
The earlier models had a circular intake manifold -- part went under the turbo
Later models have the U shaped intake -- so maybe can be removed with turbo in place
the front bolts on the EGT cooler can be a pain -- some take that out in one piece
Be sure to clean around the intake first -- junk can fall into the ports when you lift it off
ya know, like that 10 mm socket that is always missing out of the set
the tube has several vids showing intake removal -- go there to search
In my defense, I was unsupervised
2006 F250 Lariat FX4 cclb
Torque Pro and OBDLink MX bluetooth monitor
General note:
For all those wanting a premium silicone sealer Kubota 70000-73764 is the best your gonna find. This is a hybrid gray silicone that uses solvent rather than acid to start the curing reaction, this makes it safe for aluminum and and any surface that involves coolant.
Hydro is online now
post #3 of 4 Old 01-28-2020, 09:08 AM Thread Starter
Quoted: 4 Post(s)
Truck is a 2006. I found a PDF step by step at The Diesel Garage website. I think I'll give it a shot.
A0m397x is offline
post #4 of 4 Old 01-28-2020, 12:54 PM
dh3415's Avatar
Quoted: 7 Post(s)
I would say just pull the turbo, it's not hard. I had everything off to do a HPOP and oil cooler change and with an okay set of hand tools and SrMastertech and Dieseltechron videos for guidance I had no problems with teardown or install.
Hydro likes this.
dh3415 is offline
