Low oil pressure reading - Ford Powerstroke Diesel Forum
 3Likes
  • 2 Post By knotreel
  • 1 Post By bismic
post #1 of 5 Old 01-26-2020, 10:12 PM Thread Starter
Question Low oil pressure reading
I have an 06 6.0 and sometimes at idle (usually at a stop light) the oil pressure gauge goes all the way down and the alert goes off. When I rev it up or take off the pressure goes back up to normal. I'm not a complete dummy but this is most likely a oil pump problem right?
dave
diamondave2 is offline
post #2 of 5 Old 01-26-2020, 11:05 PM
Quoted: 527 Post(s)
Garage
The gauge is not really a pressure gauge -- merely a feel good indicator
the pressure switch trips at 5-7 psi
so if you are seeing the 'gauge' drop at idle, you have less than 5 psi oil pressure
There is a pressure port on the front of the oil cooler housing, that you could connect a real gauge
metric threads, would need an adaptor
One thing you could check is the pressure regulator -- looking at the crank pulley -- about 8 o'clock
take the plunger out and see if it is stuck/scored or any debris in the bore
How many miles on the engine?
seem to idle smoothly?
any thumping in the intake or exhaust?
In my defense, I was unsupervised
2006 F250 Lariat FX4 cclb
Torque Pro and OBDLink MX bluetooth monitor
General note:
For all those wanting a premium silicone sealer Kubota 70000-73764 is the best your gonna find. This is a hybrid gray silicone that uses solvent rather than acid to start the curing reaction, this makes it safe for aluminum and and any surface that involves coolant.
Hydro is online now
post #3 of 5 Old 01-27-2020, 03:41 PM
Quoted: 5 Post(s)
did you change oil recently? what oil filter? some after market filters and cap could interfere with the valving in the filter housing. Be sure to use OEM filter (motorcraft) and cap.
jokester00 and Hydro like this.
knotreel is offline
post #4 of 5 Old 01-27-2020, 11:24 PM Thread Starter
Engine has around 135,000 miles. Yes it idles smoothly and no odd noises. I will check the pressure regulator and see what's going on in there. No recent oil changes....
post #5 of 5 Old 01-28-2020, 04:02 AM
Quoted: 514 Post(s)
As knotreel asked, are you using Motorcraft oil filters and do you have the OEM oil filter cap? The OEM cap sits about 1 inch above the housing. The aftermarket caps are at least twice that tall. Several good youtube videos on this and the issues they can cause.
Hydro likes this.
Mark
06 F250CC SB FX4 Lariat; ARP studs; OEM gaskets; Banks exhaust; DynaTrac Ball joints; RACCCV6000; JimmiJammers; Ravelco; SynchroMax in trans case; Fumoto valves; Harpooned; Blue regulator spring; DashDAQ; PHP FICM; RiffRaff boots; DCPower 270AXP; Power Inverter; Bilstein shocks; BPD EGR cooler, radiator, water pump; SCT w/ SRL+; Rotella ELC Ultra Coolant; X2Power AGM batteries
No-start thread:
bismic is online now
