18mm or 20mm head gaskets? - Ford Powerstroke Diesel Forum
 10Likes
post #1 of 44 Old 01-24-2020, 10:44 AM Thread Starter
I have a problem with my degas bottle pressurizing and have come to the conclusion my head gaskets need to be replaced. I’m trying to order everything that’s needed before I start to minimize down time. I’m having trouble with ordering heads and head gaskets because the first question is, “are they 18 or 20mm?” I’ve called several Ford parts counters and even they don’t agree. My truck is a 2006 and has a 12/06/2005 build date. The last 6 digits of the VIN is C20640. Is there any way to be sure without starting the job and then ordering the parts?
rpfxst is offline
post #2 of 44 Old 01-24-2020, 10:55 AM
voodooridr's Avatar
Quoted: 1084 Post(s)
Assuming that there's a 6E at the front of your C20640
HVBOM says that Ford put 20mm gaskets on your truck
Sent from my SM-G960U using Tapatalk
2004 F250 CCSB 4X4
4" Skyjacker lift
3:73 gears
35x12.5x18 Nitto Ridge Grapplers on Method MR309 wheels
KDD heads, ARP studs, BD exhaust manifolds, DieselSite up pipes, Mishimoto degas bottle
PHP Insight PRO
PHP Atlas 40 FICM tune
voodooridr is offline
post #3 of 44 Old 01-24-2020, 10:56 AM
Quoted: 518 Post(s)
Pretty sure they are 18mm. The commonization began Jan 11, 2006.
The way to check easily:
The 18mm heads have 28mm core plugs and the 20mm heads have 32mm core plugs on the front of the heads
voodooridr likes this.
Mark
06 F250CC SB FX4 Lariat; ARP studs; OEM gaskets; Banks exhaust; DynaTrac Ball joints; RACCCV6000; JimmiJammers; Ravelco; SynchroMax in trans case; Fumoto valves; Harpooned; Blue regulator spring; DashDAQ; PHP FICM; RiffRaff boots; DCPower 270AXP; Power Inverter; Bilstein shocks; BPD EGR cooler, radiator, water pump; SCT w/ SRL+; Rotella ELC Ultra Coolant; X2Power AGM batteries
No-start thread:
bismic is online now
The Following 2 Users Say Thank You to bismic For This Useful Post:
Vegasmax777 (01-26-2020)
post #4 of 44 Old 01-24-2020, 11:14 AM Thread Starter
Yes the VIN is 1FTWW33P76EC20640
rpfxst is offline
post #5 of 44 Old 01-24-2020, 11:16 AM
voodooridr's Avatar
Ford did some shifty things right before the switch
2004 F250 CCSB 4X4
4" Skyjacker lift
3:73 gears
PHP Insight PRO
post #6 of 44 Old 01-24-2020, 11:25 AM
Vaughn715's Avatar
Quoted: 4 Post(s)
If you have a December 05 build date, then your motor probably has an October-ish build date. That is the date you are really looking for. I would say that you have the 18mm dowels. But that's just my way of thinking. My 06 has an October 05 build date and I am about 3 days from starting my tear down and I have already bought 18mm heads and gaskets and I'm not scared. On the other hand, I'm also not that close to the date of commonization. I dont think I would be scared to order 18mm stuff if I were in your boat. But that's just me! Best of luck on your build and let us know what you find!
In fire you can plan everything out to the minute, and a minute before that everything changes.
Vaughn715 is offline
post #7 of 44 Old 01-24-2020, 12:09 PM
Quoted: 518 Post(s)
Interesting!
I would sure like to know the core plug diameter!
Mark
No-start thread:
post #8 of 44 Old 01-24-2020, 02:49 PM Thread Starter
Can someone tell me what HVBOM stands for? Thank you all for the info!
rpfxst is offline
post #9 of 44 Old 01-24-2020, 02:51 PM
voodooridr's Avatar
Historical Vehicle Build Of Material
Its a list of parts Ford used on a given VIN#
2004 F250 CCSB 4X4
4" Skyjacker lift
3:73 gears
PHP Insight PRO
post #10 of 44 Old 01-24-2020, 06:27 PM
ZMANN's Avatar
Quoted: 4035 Post(s)
My 06 with Nov build vin 6EC28861 has 18mm
16.12.2005
F250/350/450/550 Super Duty
Double Cab (3/4 Door)
250 Series
6.0 flush pdf
ZMANN is offline
