Bad FICM computer cause low oil pressure? - Ford Powerstroke Diesel Forum
 9Likes
post #1 of 12 Old 01-22-2020, 09:48 PM Thread Starter
Hi, I have a question about my truck(03 F350). No start issue.
when I disconnect the FICM, the high pressure can go to 800 or 1000 PSI when cracking.
but when I plug FICM in, now matter how I crank, I can only get ~400psi. hence now start.
The FICM voltage is good at 48.5 and FICM sync is 1.
Initially, with old injectors, if I unplug 2 injectors from driver side with FICM plug in, the truck can start and run but very rough. So, I thought I have injector leaks, I replaced all four driver side injectors. With new injectors, I can't start at all with FICM plug in.
I am thinking I have a bad FICM computer and is messing up with injector timing cause lower high pressure PSI, Is this even possible? Or my issue is really a weak HPOP pump? If it's the HPOP pump, why I can get 1000psi without FICM plug in?
Thanks.
Bill G Zhou is offline
post #2 of 12 Old 01-23-2020, 03:21 AM
Quoted: 517 Post(s)
Please get the ICP pressure, ICP voltage, ICP desired, and IPR % duty cycle when cranking.
Do this with and without the FICM plugged in.
Patriot likes this.
Mark
06 F250CC SB FX4 Lariat; ARP studs; OEM gaskets; Banks exhaust; DynaTrac Ball joints; RACCCV6000; JimmiJammers; Ravelco; SynchroMax in trans case; Fumoto valves; Harpooned; Blue regulator spring; DashDAQ; PHP FICM; RiffRaff boots; DCPower 270AXP; Power Inverter; Bilstein shocks; BPD EGR cooler, radiator, water pump; SCT w/ SRL+; Rotella ELC Ultra Coolant; X2Power AGM batteries
No-start thread:
bismic is offline
post #3 of 12 Old 02-19-2020, 04:44 PM Thread Starter
quick update, I think my issue is still HPOP, it's not consistent each time I check the ICP pressure. it works sometimes and sometimes not...
I plan to replace a new HPOP and check it again when get a chance...
will update here later.
post #4 of 12 Old 02-19-2020, 05:46 PM
Quoted: 517 Post(s)
Didn't want to post data? It can help prevent spending unnecessary $$'s.
Also, an air test can usually help pinpoint issues in the high pressure oil system.
SparkyF250 likes this.
Mark
No-start thread:
bismic is offline
post #5 of 12 Old 02-19-2020, 05:55 PM Thread Starter
No, not that I don't want to post data. It's that when I go back to record the data with/without FICM plugged in, I barely getting any pressure on either case anymore. It's very strange. I was able to get the engine running roughly before and getting high pressure from ICP without FICM plugged in also.
I don't have air hose IPR tool nor I can't get the IPR valve off the truck. as you can see, I am a newbie just messing around.
So, my conclusion is that I have a HPOP that was kind of working but due to my cranking, went completely dead. I am going to replace a new HPOP but it's going to take me a while to able to take the turbo off.
it's really a work in progress...
post #6 of 12 Old 02-19-2020, 06:11 PM
Quoted: 517 Post(s)
You are going to need to get the IPR valve out one-way-or-another. I would pull it first and inspect/test. While it is out - get the test fitting and do an air test.
Getting the HPOP out isn't nearly as easy as the IPR removal.
One reason I asked for ICP volts is that it might help explain the low/variable pressure .......
Patriot and SparkyF250 like this.
Mark
No-start thread:
bismic is offline
post #7 of 12 Old 02-19-2020, 06:15 PM Thread Starter
Ok, post data tomorrow first thing... get a full night of charge on battery.
post #8 of 12 Old 02-20-2020, 04:27 PM Thread Starter
Here is with FICM plugged in: FICM Sync=1 FMP=49 voltes, HPOP= 9.1 PSI , IPR 83.9% ICP-V 0.2 volts, MAP -0.2 PSI.
without FICM plugged in, the number is basicly the same except FMP=0 volts.
post #9 of 12 Old 02-20-2020, 04:53 PM
Quoted: 517 Post(s)
Were you cranking when you took the data?
jokester00 likes this.
Mark
No-start thread:
bismic is offline
post #10 of 12 Old 02-20-2020, 04:59 PM Thread Starter
yes. the snap shot of the screen when cranking.
Tags
03 6.0 , ficm , hpop
